Xbox live u Srbiji?
Dovoljno je da ti banuju MAC adresu konzole, tu ne pomaze nikakav format HD.
Nisi me skapirao. Ja od update-a, koji sam uradio najvise zbog Force 2, posle skidanja iste, vise nisam ukljucivao LAN kabl u konzolu. Igrao kopije, jesam naravno.
Dakle, ako bih formatirao HD, da li bi MS mogao da "provali" da su se na toj konzoli ikada pustale kopije. Jer, ako je firmware zaista "stealth", onda MS jedino ima neku varijantu da novi firmware moze da provali na neki nacin da li se radi o kopiji ili originalu!
Eto, valjda sam sada jasniji...
By the way, ne radi mi console-news.org vec par dana???
Opet kazem, HDD nema nikakve veze sa bilo cim, i mozes da ga prenosis na koju god konzolu hoces.
Oni te hakuju po fw-u, cipu ili kopiji igre. Iako te banuju, ostaje ti gamertag, i HDD netaknuti.
@driver
To je i neko moje misljenje...
Evo zadnjih vesti sa http://www.xboxscene.com/, o mogucim nacinima detekcije modovanih konzola.
Xbox360 LIVE Bans Info and iXtreme Online FW WIP
>> Here are some details about the Xbox360 LIVE bans I got directly and indirectly from GaryOPA, Commodore4eva (C4E), Iriez and others. Of course don't take any of this info as 100% confirmed, noone knows exactly based on what data MS is banning ... it's just an analysis of what they think is happening and what MS might/can be checking.
C4E thinks MS is probably detecting and banning consoles from LIVE by tracking usage of backups via timing of the challenge response (c/r) on the drive over the last few weeks or months. A modified FW will reply much faster to the the Challenges requests (stored in a table) than an original firmware (seek on drive). They probably do this test more than once and can ban you if you're above a certain average.
FuzzyLogic also found that microsoft is sometimes doing additional checks on discs: PFI/DMI (so images without these sectors (or if using an old FWs without support for PFI/DMI) can probably be detected easily), drive inquiry (reads ascii string from drive), and capacity (reports capacity of disc) are requested. Strange thing here is MS requests 0x8000 bytes for PFI and DMI, while it should normally be 0x0800 bytes. TheSpecialist pointed out that the remaining 0x7800 bytes contains the relocated SS and PFI on burned discs ... which would make it very easy to detect backups for MS. C4E however told us this would not work on TS drives as its cut off to 0800 even if more data is asked, it's unconfirmed how modified HLG FWs drives respond to this atm.
The "read capacity check" will also work as detection on HLG because, unlike the newest TS FWs, it doesn't have true 'stealth media' yet, these drives are reporting back the burned disc based size of PFI instead of the correct PFI.
Apparently there's also an issue with SS (Security Sector) extracted from Hitachi-LG, some necessary data is screwed ... which means that probably only the Toshiba-Samsung / kreon setup has been extracting correct SS.
Another thing they are probably detecting (but probably not using yet to decide to ban or not) and log/flag is if you ever booted your Xbox360 with DVD SATA cable not connected to your Xbox360 (E64). Many people did this to power their drive when they wanted to flash it (power connected to 360, SATA to PC). So it's highly suggested to use an external power to flash next time.
It's also possible MS also bans based on stuff like bad credit card info for your country, running a NTSC machine with euro-address/credit card (or inverse), having out-of-region (arcade) games and demos on your HDD, unofficial 360 HDD, internet downloaded gamesaves etc. There's no clear view on all this yet.
For now, C4E believes Microsoft is not detecting modified FWs or detecting FW changes/updates. Using a special FW they did not detect any debug commands sent to the drive by MS (they went through the dash/kernel updates with the special FW as well and did not detect any debug commands there either). So they think either:
A/ MS is not doing any FW detection right now, and only previously (maybe on request of MS servers while playing on LIVE?), or
B/ MS is banning based only on the timings of the drive, ss/pfi/dmi checks, capacity, drive inquiry and c/r verification.
We also got information C4E is working on an "iXtreme Online" FW for Toshiba-Samsung drives, a Hitachi-LG version and maybe even BenQ version might follow later.
The new FW will have less features than the current Xtreme FWs: no single-layer (DVD5) support, no ripping of games (0800 mode), but more features to safely play from burned discs (emulate the exact speed and timings of the original games) and prevent booting from un-safe discs (without PFI and DMI or bad SS - so discs not passing the 'Stealth Check' (using Xbox Backup Creator(info)(info) for example) are not going to boot on the new firmware), or images that aren't exact dumps of the original.
There's no official ETA (maybe this weekend though for TS drives), and of course no guarantee MS will never ban you based on new checks (that's the risk it takes if you want to be part of the modding community ;)) The HLG FW will take a bit longer as it'll require true 'Stealth media' etc added.
This new FW will of course be made mostly for new consoles being modded, because even if you're not banned from LIVE yet there's no way to know if MS already has info/logs on your console ID regarding timings or other stuff so even changing to this new firmware in the near future may not stop that console ID from being banned in the next wave of MS bans.
If your console is not banned yet, it's highly suggested you don't boot any burned discs, originals should be ok, even when offline (MS might be storing results of some checks in flash), until the release of the new FW.
If your console is already banned this will of course not help you ... just enjoy the offline playing on that console for now (with some games you could try using 3rd party networks like XLink Kai(info)) and maybe some day a new exploit will allow you to do more with that console.
To end with ... X-Scene's obvious tip of the month: don't buy 2nd hand Xbox360 consoles ;)
Ljudi jel moze da se napravi novi THREAD za Gamertag-ove, pa da svako lepo ostavi svoj, da se dodamo na liste, i igramo medjusobno?
poz
Jel ti chitash o chemu se pishe u thraeadu ? :) Vecina ljudi (ili svi) ubrzo nece ni moci online :D
Jel ti vidis ko je napravio thread?
Bez obzira sta bude, trebao bi biti jedan sticky, gamertag thread.
Ja cu moci, moja nije modovana.....:D
Dosta kupaca koji nisu ni znali sta je modovana konzola dobili su ban, ne brini popices i ti jedan kad tada :p .
hehe
Aj da vidim i to, mada ovde je MS podrska strasno dobra, bilo sta da se desi samo ih nazoves i problem resen, posto imaju predstavnistvo ovde.
Pazite sad ovo.
Moja konzola je kupljena pre mesec dana, imam jos oko godinu dana garancije, medjutim od prvih dana je ostavljala tek, tek, veoma malu ogrebotinu na dvd-u. Cim sam primetio istog danas sam ih nazvao prijavio kvar i poslao konzolu na popravku. Za 7 dana sam dobio konzolu nazad sa besplatnom igrom ( kad sam nazvao, mogao sam da biram koju hocu hehe) i besplatnom pretplatom na "live" od mesec dana. Sve to za pretrpljeni stres....:D
Posle toga nazovem ja njih da ima kazem da mi nesto krstic ne radi na kontroleru kako treba, kazu oni, nema problema gospodine, posaljite nam vas kontroler mi cemo vam poslati novi. Ja, reko, ok. Dan posle skontam ja da sam bio samo utripovao, i da je sa krsticem sve u redu, kad ono par dana posle kuca postar na vrata i donosi NOVI WIRELESS kontroler, hahaha, vilica do zemlje. Tako da mi je ostao moj stari koji radi i dobio sam novi za dz.....
Eto to je moje iskustvo sa MS ovde na Novom Zelandu, ali inace 360 je ovde veoma poznat po tome da se mnogo njih jako cesto kvare, i stalno im neki djavo fali. Svaki dan mislis, e dal ce danas mi rikne, bukvalno tako je ovde.
poz
@banenz: citam ja tvoj post i razmisljam ma ovaj MS je stvarno dobar, dok nisam dosao do zadnjeg odeljka kad si rekao da si na Novom Zelandu :D rek'o ma 'de je dobar, ovde ti ne bi ni posle godinu dana vratili konzolu kad bi je odneo na poprvaku :D :D e a kamoli da ti postar donosi joysticke na vrata
Ma da.....
Na zalost tako je, u Srbiji samo da se nadas ne rikne nesto, inace mislim da bi morali da saljete u madjarsku, ili negde jos severnije na popravku, naravno to govorim za MS, sigurno ima neko u srbiji ko bi se ponudio da popravi, ali cim je nego drugi otvori osim MS, oni vise nece ni da cuju za nju, i ako je garancija istekla.
Mislim smesne su tu neke stvari kuci, bas me kum pitao pre neki dan da mu posaljem cip za PS2 da ga moduje, posto ovde kosta $20 = 10 EU, a u Novom Sadu mu traze 80 Eura.....strasno.
poz
Ja i dalje ziv i zdrav, modovana konzola, od pocetka banovanja online igram samo originale...
I sretnem se sa BaneNZ-om skoro svaku noc:)
Takođe, uz ispravku da imam Xtreme 5.2, a ne 5.0. Izgleda da ta kombinacija sa Samsung 28-icom nije banovana, bar ne po onoj listi. Ali kao što rekoh, totalno je nebitno, i dalje je Xbox360 daleko logičnija kupovina od PlejSmora. Ako ikad Sony bude imao neke naslove koje nema PC ili Xbox, sa zadovoljstvom ću preći na njega... mada sumnjam da će tako biti.
GranTurismo :d
LOL, pa PS3 do kraja godine ima vishe ekskluziva nego multiplatform igara, i sve redom su drugachijee od smor360PC ubij-sve-shto-vidish gluposti, ali to izgleda ne pishe na TomsHardware i Inquireru pa ne znash :)
E riknuo mi router ovih dana, pa me nece biti online jedno nedelju dok ne dobijem zamenu....mislim ono da se ne brines.....:D ;)
Mrzi me da stalno cupam LAN kabl da bi ustekao 360 na live.
Koji ti je Gamertag da te dodam na budddy list?
Eh, steta ja taman mislio da te operem u PES6 ranked match-u jednom...:)
@driver
Pazi, ja sam ogroman PlayStation fan, ali ne vidim sad neku prednost PS3 u odnosu na XBOX360 listu igara. Ja cekam da dodje jedna igra vredna igranja na PS3 kao ozeb'o sunce, i da upotrebim konzolu. Voznje ne igram, sport vec pikam na 360-ici, interesuje me RPG, akcione avanture i slicne stvari. Ocito je da cu se nacekati ko blesav.
Eh, steta ja taman mislio da te opereu u PES6 ranked match-u jednom...:)
@driver
Imao sam PES6 pre pola god, vratio sam ga u shop posle nedelju dana jer sam tada i prodao moj prvi 360, no planiram ponovo da ga uzmem, tako da mozemo malo pikati.
Sony mi se ne svidja zato sto su im kontroleri ocajni, 10 godina ne menjaju nista, dok mi je 360 kontroler do jaja.
I da ne pomisli neko da sam 360 fanboy, naprotiv uvek sam imao sony, i keca i dvojku, ovo mi je prvi put da sam uzeo xbox.
poz
E ajde idi igraj nijednu igru na PS3. Koji si ti ložač. Sve najave koje sam video (osim Haze-a) su Xbox360+PS3. Apsolutno sve. Dobro, DMC4 nije, eto. I ona sa onim glupim letećim zmajem koja je smorčina. Sve izlaze za Xbox360 i PS3, a dobar deo i za PC. Ne budi lud, pa njima je cilj da imaju što veću bazu kupaca. I dalje misliš da je PS3 nešto posebno i extra... hahaha... ne verujem.
Pa i DMC4 je odsad mutiplatform.
Ekskluziva je nesto sto samo mali broj developera moze sebi da priusti, ovo vazi za 360-ku kao i za PS3. PS3 i XBox360 only naslove mozemo ocekivati jedino od timova koji su pod amom SCE-a odnosno MGS-a a svi ostali developeri ce raditi igre na obe platforme, jednostavno receno jer im se to vise isplati.
Ja kad sam uzeo u ruke PS3 kontroler, smorio sam se kao mac u kamenu...
360-ica je napravila pravi mali svemirski brod u odnosu na PS3...to mi recimo nikad nece biti jasno, CEMU ta aljkavost pri samoj zavrsnici. Ipak, ne odustajem ja od Sony-a, uvek sam samo PS konzole igrao u svim varijantama, pa se nadam da ce se vratiti na velika vrata:)
nije to aljkavost nego su bili primorani da ustete gde god su mogli zvog visoke cene izrade same konzole. vremenom ce se pojaviti dobri joypad-i pa ces za neke nenormalne pare moci da imas sve potrebno.
Eto, još gore. PS3 nema razloga niko da kupi, bar ne zbog nekih tamo igara "koje nijedna druga konzola nema". Xbox360 je jeftiniji, igre se igraju "za dž", plus ih ima već 150, a za PS3 ih ima 10. I koštaju 100 evra:) Smešan je ovaj drajver.
PS3 ima do kraja godine vishe ekskluziva nego X360, a josh nije ni E3 doshao :) Pored toga, svaka od tih ekskluziva shamara onu iz istog zanra na X360. Shta si se ti istripovao, stvarno ne kapiram. Sve te igre koje su preshle multiplatform nikada nisu ni bile neke velike igre kao one koje su uvek bile PS ekskluzive i tako ce da ostane :) Playstation ce uvek ubacivati nove igre, sveze IP-eve, dok ce Microsoft da kupuje pravo od 3rd party developera na 5x iscedjenu igru, i napraviti stoti deo Forze i Halo, gde su i prvi delovi bili krsh, ali nije bilo shta drugo da se igra. Prave igre i najbolje igre na bilo kojoj Playstation konzoli M$ nikada nece dobiti, jer ih je sam SCE radio.
Evo ti samo igre koje su mi sad pale na pamet, i koje su klasu ispred svake slichne na X360, i obrati paznju da nema dve iz istog zanra, za razliku od X360 kome je HALO 3 glavni adut, opet.
Metal gear solid 4, Lair, Heavenly sword, Little big planet, Uncharted, Gran turismo 5, White Knight, Afrika, Ratchet and Clank, God of war 3, Wipeout, Final Fantasy XIII.
Premlad si ti u konzolama, mogao bi prvo malo da istrazish kada vec hocesh da se upushtash u neku prichu :)
PS3 je konzola budućnosti.
Svaka igra koja valja još nije izašla :d
Kako to mislis za "dz" kad se placa $80NZD ovde, a kod nas ne znam koliko je u evrima.
Sem ako nisi mislio na pirate zbog kojih sad svi bivaju banovani sa "live" servisa.
poz
Stvarno ne znam zasto se vas dvojica prepucavate....
Mada, svaka igra koja je do sada izasla za obe platforme, izgleda i uradjena je bolje za 360, zeleo ti to priznati ili ne driver, a za to, sta ce tek da izadje za sony 3, prvo treba sacekati, pa cemo videti sta ce od toga biti dobro a sta ne.
poz
