GeCube X1950XTX - najjaca AGP karta
Kolika je cena ako nije tajna i kako radi?
Stim sto se za te pare prelazi komotno na 64bit masinu!
GECUBE X1950XTX AGP
1.Powered by ATI RADEON® RV580+ (90nm) GPU
2.A 90-nanometer process GPU, the debut of the unique processing architecture
3.256MB of 256-bit (512-bit Internal Ring Bus) GDDR3 memory
4.48 parallel pixel pipelines
5.Dual DVI (Double Dual Link) + HDTV + HDCP + D-sub support.
6.Exclusive X-Turbo Fan (TEC inside)
7.*TEC (Thermal electric Cooler) inside : TEC cools the X1950XT ASIC by electric controlling to its best operating condition besides the big fan coolers.
8.*With X-Turbo fan cooler: Easily to have 648MHz default core clock for 1950XT AGP board and Overdrive to 675MHz ASIC core maximum overclock margin.
9.*Satisfied thermal control device : 1950XTX level in core clock (648MHz X1950XTX original core clock) at only about 70°C or more while operating 3D in room temperature environment for reliability.
10.*OverDrive by ATI control panel
11.*Fan Control ( 2D 20Db-, 3D 28dB-) for silent cooling.
12.*Temperature monitoring : Utility to monitor ASIC temperature.
13.ATI’s Avivo™ technology connects to home entertainment devices and creates true-to-life image reproduction, and the smoothest video playback ever offered by ATI. Get high image fidelity with CRT and LCD displays, TVs, rear projection and plasma TVs, and projectors.
14.New ultra-threaded core 3D architecture with ATI’s revolutionary Avivo video and display technology to drive performance to new heights with incredible 15.speed and intense 3D graphics.
16.Shader Model 3.0 features new High Dynamic Range visual effects, and enhances realism with adaptive anti-aliasing and lightening fast performance.
17.CATALYST™: Full Windows Vista LDDM support including Aero Glass visuals
GECUBE
Mislim da je ovaj GeCube vrh za AGP! Dalje od ovoga ne mere, ai nemasmisla.
prve DX10 mainstream kartice nece biti jake koliko i X1950XTX,cak i da sepojave u AGP obliku, sto cisto sumnjam. A s druge strane DX10 high end je toliko naponski zahtevan, da mu treba sve sto PCI Express moze da isporuci, pa jos dosta preko toga. Tako da je AGP u DX10 eri totalno deplasiran.
Procesor ne moze da isprati ovu AGP karticu!
Retko ko ima takvu kombinaciju da ne kazem niko a kupovati sada tako nesto se granici sa ludilom.
Ovo nije pun 1950XTX. Ovo sr*nje ima 256Mb GDDR3...
Jos jednom... Ne isplati se!
pa jos nisu rekli cijenu ;)
LOL! Sra*e!!
Po kom kriterijumu? Ovo je najbolje sto neko sa AGP platformom moze sebi da priusti! Bilo koji Socket 939 Athlon 64 moze da isprati ovu karticu! 256Mb GDDR3 na 1.5 Ghz, malo li je!
Moja ima isto 256Mb GDDR3 memorije koja radi na 1.6GHz... :D :D
Koliko ljudi u Srbiji ima s939 ploce sa AGP slotom... Za te iste pare oni mogu da predju na PCIe i 7900GS minimum! (ako kartica kosta oko 250-280e).
evo neka bude 300€
nadji mi procesor + ploca + ddr2 + 7900GS za te pare odmah sutra kupujem.
Upravo... 7900GS ima da se nadje za 170e. ostaje 330 za proc, mem, plocu!
M2N-E
1 Gb Kingmax DDR2 800MHz
Athlon koji hoces, mozes da biras X2 ili obicni!
M2N-E
LOL meni preporucujes AMD :D
Asus M2N-E 7.950 (krsh ploca, ali ajde)
Kingston KVR 1GB DDR2 800MHz 10.045 (nisam nasao kingmax pa stavio ovaj krsh)
AMD Athlon 64 X2 (dual core) 4200+ 15.050 (mada i ovo je slabo mozda 4600+)
Club-3D GeForce 7900GS 256MB DDR3 15.300 (ima i gainward sa 512MB rama u pinu ~20.000)
48.345 ~610€
M2N-E krs ploca... Prike, si je korisitio mozda pa da osudjujes...
Za 1Gb memorije 120e si normalan... Proveri HH sobu!
Moze i slabiji X2
Kao sto rekoh, 7900GS moze da se nadje za 170e!
I to se sve uklapa u cenu...
To sto se ti tripujes i gledas najvece cene to je druga stvar!
da krsh je naspram badaxe ili asus p5b deluxe
rekao si bilo koji X2 ;)
cene su iz imtela, osim za memoriju koja je u pakomu, u imtelu nema nijedna na 800MHz
nista se ja ne tripujem, nego gledam cene nasih prodavnica hardware-a
Ja gledam i HH sobu..
NHF p0z!
Izvinjavam se sto nisam citao thread od pocetka...Da li ima kod nas da se kupi nesto jace od 7800gs (npr neki 1950 pro ili sl) za AGP?? Znaci savrseno sam upoznat sa tim sta se isplati a sta ne,tako da ako neko zna gde ima neka javi...
meni je ponudio nikola evo ti tel. pa ga kontaktiraj cena 213 evrica 063.881.66.56 Nikola
OK thx,verovatno cu uzeti za jedno nedelju-dve
OT/Illidan,M2N-E nije krsh ploca kako ti kazes..Jedina mana joj je Vmem.Ostalo na njoj je OK.
BTW imas DFI Infinity Ultra M2 za istu (ili manju) kintu,koja ima opcije koje bi zadovoljile bilo kog OC zaludjenika.
Sto se memorije tice,Kingston koga is naveo isto nije krsh,al ajde,posto sve nazivas krshem,mozda si se salio :).Skoro svi kingstoni 533 idu na 800 bez problema uz nesto vecu voltazu,sto uz odgovarajuci divider osigurava da ce mem da isprati visok OC procesora.
Na kraju CPU,imaces za nedelju dve Brisbane 3600+ 65nm(1.9Ghz,9.5 multi,2x512KB L2) za oko 100e(sto je oko 70e nize od e4300 koji je nesumnjivo brzi cpu) u maloprodaji,koji se pokazao kao izuzetan OCer,i on sigurno nece biti bottleneck osim ako ne ubodes dve 8800GTX karte u SLI modu u neku SLI plocu..U sta sumnjam :).Koga X2 na 2.8+ GHz ne moze da zadovolji u svakodnevnom radu,taj covek neka se ispruzi jos 70e za CPU i 30tak e za plocu i uzme C2D :). OT/
