Kojntelekt
250 kh/s je dovoljno za full zaradu.
Za mene je najbolja menjačnica u ovom trenutku Poloniex, Criptsy udara po ušima sa provizijom.
Vodi računa da obavezno izbaciš crtice iz license key.
Podešavanja za R9 270 - sorry, nadam se da će neko da ti okači, da ne kopaš info na preko 400 strana.
Može pojašnjenje za boldovano...gledam na Cryptsy fee 0.25% a na poloneix 0.2% što po mom mišljenju i nije neka razlika.
Ovde ima mnogo fakultetski obrazovanih mikroekonomista,moj savet ti je nemoj mnogo da gledas na tih 0.05%,verujem da neces biti na velikom gubitku.
PS: Nadam se da si shvatio sta sam hteo reci ;)
Na Cryptsy je fee kada se povlači btc 0.001 btc, a na Poloniexu 0,0001. Znači, 5 povlačenja - 1 dolar, a na Poloniexu 10 centi. Možda je to nekome nebitno, poštujem.
We apologize for the continued difficulty in receiving your payout. We had hoped That cryptocurrency values ​​would have risen by now, but as you are aware prices are still not improving.
We understand That some users might want to simply recoup Their initial investment instead of waiting for the situation to be resolved.
Therefore, we now wish to offer the Following options:
1) A one-time refund for users Whose total withdrawn earnings have not yet Reached Their total contract purchases. The payout will be computed as longer available:
Total Contract Purchases - Total Withdrawals Already Received = Refund Amount
For example, if you Purchased in Starter contract worth € 99.95 and your total withdrawals received so far is only € 70, you can be eligible for a payout of € 29.95 to cover your initial investment.
The refund will nullify and cancel your active contracts. If you agree to this refund, please send us your username and a screenshot of your Statement page so we can review your account. If you qualify, the refund will be processed through the First Swiss Card Which will be sent to you free of charge. You will just need to send your full name and postal address.
Otherwise anche and if applicable, we will refund your credit card payment.
2) If you Purchased contracts by credit card, you may anche inquire with your bank for a reversal of the transaction.
3) If you do not fall into These two categories or do not wish to take the above options, your earnings and withdrawals will be processed pending a when the cryptocurrency industry recovers from it's steep decline. We can not give you a specific time frame of a when pending earnings can be processed as this depends on Entirely crypto prices.
Ne obecava ovaj poslednji pasus. Jel prolaze nekom bilo kakve isplate?
Znaci kraj isplatama nemamo se sta nadati da ce biti ista isplaceno!
Znaci prestajemo kopat!
Steta!
@tip odakle si ovo preuzeo gdje si nasao ovo obavjestenje?
@mige
Za ovo vreme dok si na kojntelektu, naplatio si zadnjih godinu dana mrcvarenja grafika u "prazno"..
Ja konkretno sam dopunio btc wallet, i hvala im na tome ;)
Iz aviona se vidi da su klasicni prevaranti, tj dobri poznavaoci "ponzi" kombinacija.. moj savet je da cedis dok traje.. dinara nece videti od mene, jer jedan jedini nakog koji sam uplatio (demo sa kog sam generisao referale) su blokirali, i naravno nema odgovora na mail koji sam im pisao u vezi tog naloga..
Sad preostaje testiranje ostalih cloud sistema, poput ovog ponzija na kome i ti i ja, a i ostale kolege radimo ;) nema nista od nerviranja i cimanja jer ovo je bilo za ocekivati, samo je bilo pitanje vremena kada i u kom obimu :D
Videh ovo obavestenje pre dan-dva na ruskom forumu al` ne videh i neki link ka konjtelektu, pa ga nisam uzeo zdravo za gotovo.
Ako je zvanicno, onda je to the end..
Niti placaju, niti ometaju minere, cak i antiboot je u zimskom snu, ne banuje vishe slucajne uzorke. Mozda se probudi sa vremena na vreme kada neki user bas napravi fatalnu gresku.
to je sa italijanskog foruma, navodno je preuzeto sa fb stranice i support je odgovorio isto nekom liku
ne znam da li je zvanicno posto ja tu fb stranicu ne mogu da nadjem
edit: odgovor supporta - sa turskog foruma :)
Bas i ja trazim, ali ne mogu da nadjem, mada cim isplate ne stizu to je to 99% da je tacno, ovo u prevodu znaci dzaba nam je kopat samo trosimo struju, sta nam znaci sto su novcici pending -nista, a nije ni cudo da je pool ovako proradio sve je to igra sve je to povezano.
Znali smo da ce doci do ovoga pre ili kasnije pricali smo vise puta o tome sta reci "Bilo je lijepo dok je trajalo"
@karanovicz povlacio sam ja i jucer i sinoc i jutros sa razni naloga nista ne stize.
ja jos danas kopam kojin, ako nista ne isplate od sutra verovatno kopam nos :S:
Znaci to je to, CRKO KONJ :whip:
Meni juce stiglo nesto malo kerica sto je povuceno preksinoc u ponoc. Od tada nista ali ja jos ne odustajem, vec imali ovakva kasnjenja pa i veca i onda su isplatili. Jasno je da ih opasno keca ovaj kurs btc bez obzira sto apsolutno ne razumem kako su uspevali da odrze ovaj sistem i da zarade.
Pogledajte prilog 162207
Ima i na facebook stranici, samo nece da stave na pool da se ljudi ne bi razbjezali, kontaju jos da bilo sta zarade, mutanti su to dobro osmisljeno, sad samo lagano da se ispare.
Meni od prekuce stiglo juce svasta,osim starih naloga.A danas cemo videti...
A kazite mi jel leze sta sa svezih free naloga?
tri dana ništa, danas ću probati napraviti nove ...
Kod mene od preksinoc takodje stiglo nesto malo, sa tri naloga gde je bilo po 2k stiglo, ostalo nista.
Nek proba neko da pusti mali iznos, po 1.5 -2k recimo.
pustio sam zadnja 2 dana po 1,5e sa 4 naloga i nista ne stize, svezi free nalozi od pre 3 dana, samo su prvi dan platili. Naravno sa starih demo naloga i startera nema nista jos od 25.01.
Koji su to sistemi ako nije tajna koji rade ovako ili slicno?
To je to prvo su zaustavili stare naloge, ostavili free naloge da jos malo privuku ljude, pa su onda podesili pool da radi punom snagom da se ljudi ponadaju, i onda su obustavili isplate i sa stari i sa novi naloga, nebitno jesu li free ili verifikovani. To je sve dio smisljenog plana suvisno je vise bilo sta reci, koje sta zaradio-zaradio fajrunt!!!
Sad ce ostaviti da ovako pool radi da ljudi misle da ce im nekad isplatiti, i tako ce trajati dok i oni najuporniji ne odustanu.
Postoji mogucnost da i puste po nekome neku isplatu cisto da zadrze sto duze ljude, da im dadnu lazu nadu, ali ovde je kraj definitivno!
+1
Meni se cini da nisu uspeli da prevaru izvedu na nacin i u meri kako su to hteli, pa pokusavaju da ostave otvorena vrata. Videcemo...
Ne da nisu izveli nego ja kao nesmisleni pojedinac bi je mnogo bolje smislio.
Tebi u jeku interesovanja ne radi pool krece da zakidas isplate i
upteljavas se sa glupim razlozima i objasnjenjima zasto je to tako.
Umesto pusti sve da radi ko zmaj i kazi:nema vise free,nema demoa od danas,mozete startere pa na gore samo.
I mi normalno pavijani,gde cemo no cemo svi iznauplacivati startere.
I onda kad sve najbolje radi i svi uplatili milione naloga,magla!
Ma nisu oni prevaranti, sta vam je... :) Vidite da hoce da nadomeste ostatak para za contract-e...Ajde, molim vas... Sta vam sve pada na pamet, oni ovim potezom samo nagovaraju ljude da pumpaju BTC... :)
