lepi kokan
- r5 5600 / LC cc-120 p/p
- AsRock b450m pro4
- g.skill 2 x 16gb 3200 ddr4
- rx 6700
- wd sn570 1tb nvme / wd purple 4tb
- Zvuk
- Altec Lansing 621
- fsp 750w
- Monitor
- VA
- Ostale periferije
- win10 ltsc
- Optički internet
mora ručno da se edituje .inf fajl. kigen je vezan za mac adresu (normalno), tako da pri instalaciju na drugu mašinu treba da klonirate mac
00. Your Realtek Soundcard Device ID
- win7 - Control panel
- Device manager
- Soundcard device
- Realtek High Definition Audio
- Detail tab
- HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1043841B
[Snap1.jpg]
01. Remove all realtek soundcard driver
Recommand reboot your system
02. Wait your system detect your sound card then installed
Microsoft default sound card driver. [very important]
03. Add your Device ID to driver...
open \realtek_hda_6.0.1.7233\Vista64\HDXRT.inf
[AzaliaManufacturerID.NTamd64.6.0]
"Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0255&SUBSYS_10280683
"Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1043841B
"Realtek High Definition Audio" = IntcAzAudModel, "Paste your device id for here"
save
[Snap2.jpg]
Then goto execute setup.exe
Choose anyway installation driver <- very important
04. Reboot your system again
05. installation Sound Blaster Cinema 2-1.00.10
\Sound Blaster Cinema 2-1.00.10\setup.exe
06. copy run.bat & genkga3.exe to c:\
[disable your anti-virus app, because genkga3.exe was ZProtect's enpack]
07. administrator execute run.bat
then make sure your
C:\ProgramData\Creative\SoftwareLock [had 35 *.kga files]
then
del run.bat & genkga3.exe
08. logout then login
make sure your Sound Blaster Cinema 2 working...
[Snap3.jpg]
09. setting file will be
C:\Users\xxxx\AppData\Local\Creative [xxxx is your name]
It's OK now. But you want to try both application
10. Sound Blaster X-Fi MB 3-1.00.04 is a plugin soundcard
\Sound Blaster X-Fi MB 3-1.00.04\setup.exe
11. logout then login
maybe will show can't detect device with Sound Blaster Cinema2 interface
12. So. When you have both app. you must switch your soundcard default device.
[Snap4.jpg]
[Snap5.jpg]
[Snap6.jpg]
13. You can setting
Sound Blaster X-Fi MB 3 interface or
Sound Blaster Cinema 2 interface
not startup by yourself
14. Enjoy
- Device manager
- Soundcard device
- Detail tab
[Snap1.jpg]
save
[Snap2.jpg]
then make sure your
then
[Snap3.jpg]
[Snap4.jpg]
[Snap5.jpg]
[Snap6.jpg]
13. You can setting
14. Enjoy
