[scratch build] Project AXE-R
To continue 🙂
Go to assemble 🙂
hand-made brushed aluminum 🙂
mounting radiators, reservoire and fans 🙂
Day 5, 4 days left, me and my crew today finished tube in the backstage 🙂
3 days left, a lot of job is done, system work 🙂
The project is finished and ready for photo shooting 😀
Project is finished! Enjoy 🙂
CMWS2018: https://www.cmws.global/blog/axe-r-project-by-nessa
[YOUTUBE]https://www.youtube.com/watch?v=_IfgKfxOGL0[/YOUTUBE]
Two years ago today, AXE-R was project was initially conceived as a drawing, and today, it was finalized into the state-of-the-art full-aluminium chassis, combining the latest technology and the stunning hexagonal design.
AXE-R is divided into two sections - the cooling segment and the hardware section. The cooling segment is also divided in two loops, for CPU and GPU, which greatly enhances the performance efficiency of the components. This time, with the help from my brother Nemanja, and my friend Dušan, such a vast project was so much easier to take on, whilst providing handbrushed aluminium, as well as the nickel in the fittings, waterblocks, and much more to achieve the Premium look. The AXE-R case posesses an Arduino unit that measures the humidity and temperature, during which it's programmed to open the lid and circulate air throughout the chassis, should the overheating of the components occur. Therefore, we can say that AXE-R, regardless of the latest hardware that's implemented, is a true smart case.
Hardware which I've used in this project is:
Case: Custom AXE-R case by neSSa
CPU: AMD Treadripper 1950x
RAM: ADATA XPG 8x8Gb DDR4 RGB
SSD: XPG SX8000 PCIe Gen3x4 M.2
MB: Gigabyte AORUS X399 Gaming 7
GPU: Gigabyte Vega 64 CF
PSU: Cooler Master V1200 Platinum and CM 120 AP RGB fans
Cooling: EKWB full custom dual-loop water cooling system
Thank you all for support!
BR neSSa 🙂
Jedino što mi bode oči su dve vertikalne cevi ka GPU, posebno prva. Nisu idealno paralelne u odnosu na dve od monobloka.
Vidim da si išao na serial varijantu, što se GPU blokova tiče, zbog te 4 vertikale i simetrije, samo da su prve dve rupe za pass-through par mm levo bilo bi savršeno. 🙂
Bez obzira na tu sitnicu, oduševljen sam idejom i realizacijom i naravno, želim vam pobedu! cheers
Hvala, ziv bio, nego, malo si se prevario, fotografija vara oko, i tesko da se ovde nesto ne podudara u vertikali, ti bar mozes da svratis i vidis znas vec gde 😉
Znam da si perfekcionista, nije mi ni bilo logično da sve 4 ne budu idealno paralelne, ali tako izgleda na slikama. 🙂
Bravo sta drugo reci, imao sam prilike na Gamescon da vidim par Nesinih modova i to je brutalno dobro. Neso srecno tebi i ekipi u daljem radu i na novim projektima.:smash:
Hvala, ziv bio, trebace srece a trebace i vase pomoci, pisem ovde kad bude bilo glasanje itd 😀
Finalna epizoda o izradi projekta AXE-R , uzivajte:
With this photo, I want to remind you what is needed to create AXE-R case, but these are not just these parts, that is will, work and discipline 🙂
At this year's CMWS2018 competition, the AXE-R project won 1st place in the Scratch build category, It also won the audience's award! Thank you all for support, thank the sponsors for the trust, we promise in future a lot of good projects! Sincerely yours SS PC modding / neSSa 🙂
https://www.cmws.global/winners
Cestitam Nesoo!!! Prvenstveno mi je drago sto si vrhunskim inzenjerskim poduhvatom konacno matirao strani ziri i naterao ih da odaju adekvatno priznanje tebi kao moderu kao i celom timu koji je ucestvovao u ovom projektu. Cak je i publika saglasna sa zirijem sto ne pamtim da se desilo u proslosti. Kada publika i ziri donesu istu odluku..... to se zove zacementirano prvo mesto ili dupla kruna !!
Hvala prijatelju na ovim recima, pogodio si u srz, guramo dalje! 🙂
Svaka čast momci, upornost se isplatila. Ako bude nekih para setite se i nas koji smo glasali 🙂
Bravo! Sve pohvale! [emoji869][emoji1212]
