Po prvim pisanjima na xda i po onome sto vidim na mi5 izgleda da je ipak dobro sto je exynos s7 za nase trziste.. Vec se polako javljaju price na xda da s820 guta bateriju i da exynos drzi mnogo bolje.. Zanimljivo ce biti ispratiti tu pricu
https://www.reddit.com/r/GalaxyS7/comments/492sn4/psa_only_the_snapdragon_version_has_the_android/
been following the xda battery thread over the past few days, and it's 100% confirmed that only the Snapdragon version shows very high 'Android System' usage.
Also of note is the exynos often shows a higher 'Cellular standby' usage when compared to the snapdragon (however not a significant percentage, OPs screenshot is a good example)
That being said, there isnt necessarily any link between this and actual poor battery life. As far as I can tell the snapdragon reports battery differently for some reason (maybe grouping a bunch of things under android system idk).
Buuuuuut, in addition to that, as far as I can tell from the xda forums, exynos users seem to generally have more impressive battery life. The sample size is really small though and its wayyy to early for me to infer that.
Exynos. 6h i 30min sot
[youtube]vKx1VmuOl_c[/youtube]
Kazem ja Exynos >>>>> SD.
Bice zanimljivo ako razlike sto se baterije tice budu velike. Ipak je Exynos bolje optimizovan za Samsung telefone, SD skoro svi koriste.
Ovo za low light me podseca na 1020, imao je slican "problem" na startu. Cudno da neke low light fotke uopste ne izgledaju ovako.
Mogao je kolega ako je imao jos neki telefon uz S7 da slika pa da uporedimo. Takodje zanima me da li je retail ili test model?
