Samsung Galaxy S7 / S7 Edge
Onda bi još malo trebalo da krenu neki leak-ovi. Baš me zanima da li ostaju pri staklu ili ne... Biće ovi opasan telefon ako se udostoje da srede multitasking...
Sta je sa s810 :) satro stedljiviji od s801 [emoji23]
http://mobile.hdblog.it/2015/11/10/Qualcomm-presenta-ufficialmente-Snapdragon-820/
CPU 'Kryo' is quad-core
The efficiency of this generation is such that Qualcomm was able to afford the 'luxury' to leave the configuration octa-core Snapdragon 810 and develop a quad-core custom : the debut of the first 64-bit CPU Kryo . The enhancements announced are obviously considerable, but the new approach and custom-cores that have made ​​possible the leap that Qualcomm is prospecting there, with Kryo even 2 times more efficient in terms of consumption and performance compared to the core of S810 .
To achieve this it has also been working with the newproduction process to 14nm FinFET and ability for core working at 2.2GHz, without negatively impacting on autonomy. All with a capacity of processing defined unparalleled, which is why it is thought already to a possible use of Snapdragon 820 in the automotive industry, virtual reality, computer vision and other integrated applications. The CPU works closely with the other key components of S820, as the GPU, DSP and Qualcomm Spectra ISP room, and in order to optimize all the processes between them was so developed theSymphony System Manager .
The task can be solved by one of these modules just mentioned, without weighing on the CPU (when necessary) and thus also save valuable energy.Symphony has the task of redirecting the tasks in this complex system, and also debuts with S820.
With the GPU Adreno 530 the leap forward is 40%
Graphics performance are more important than ever, especially in the mobile, why Qualcomm has been working on two fronts, providing superior processing power and low fuel consumption. In both cases of an estimated factor of 40% when compared to the 'old' Adreno 430 mounted on S810. Debuts today the Adreno 5xx series that we will see in other SoC, with the 510 variant ready to support Snapdragon 620 and 618 .
Another plus in the multimedia sector is the newQualcomm Spectra ISP room , which is the module that has the task of managing the image sensors and give them all the necessary means to shots of high-level (but it is clear that the difference will Also sensors and optimization software OEMs). Spectra is actually a dual-ISP that supports image sensors 14-bit , which means a wider range of colors available and a more realistic tone and natural skin color.
Edit:
http://www.phonearena.com/news/Half...Samsung-strives-for-Exynos-8890-yield_id75633
Detaljne spec s820. Dobro je sto su je quad core. Ovo def obecava.
https://www.qualcomm.com/products/snapdragon/processors/820
CPU
Up to 2.2 GHz quad-core (Quad-core custom 64-bit Qualcomm® Kryo™)
GPU
Qualcomm® Adreno™ 530 GPU
Up to OpenGL ES 3.1+
DSP
Qualcomm® Hexagon™ 680 DSP
Camera
Up to 28 MP
Qualcomm® Spectra™ Image Sensor Processor (14-bit dual-ISP)
Video
Up to 4K Ultra HD capture and playback
H.264 (AVC)
H.265 (HEVC)
Display
4K Ultra HD on-device
4K Ultra HD output
1080p and 4K external display support
Charging
Qualcomm® Quick Charge™ 3.0
LTE Connectivity
Snapdragon X12 LTE with Global Mode
Additional features include:
LTE/Wi-FI link aggregationLTE-ULTE BroadcastLTE Dual SIM, Dual Active (DSDA)HD Voice over 3G and VoLTEWi-Fi calling with LTE call continuity
Wi-Fi
Qualcomm® VIVE™ 802.11ac
2x2 MU-MIMO
Tri-band Wi-Fi
RF
Qualcomm® RF360™ front end solution
Location
Qualcomm® IZat™ Gen8C
Security
Qualcomm® Haven™ Security Suite:
Qualcomm® SecureMSM™ hardware and softwareSnapdragon StudioAccess™ Content ProtectionQualcomm® SafeSwitch™ theft prevention solutionQualcomm® Snapdragon Sense™ ID 3D fingerprint technologyQualcomm® Snapdragon™ Smart Protect
Storage
UFS 2.0
eMMC 5.1
SD 3.0 (UHS-I)
Memory
LPDDR4 1866MHz dual-channel
Process Technology
14 nm
USB
USB 3.0/2.0
Bluetooth
Bluetooth 4.1
Ako je tacno ovo vezano za potrosnju S820.. za odlicnu autonomiju bice dovoljne i 2800-3000 mAh baterije u telefonima sa 5.2'' dijagonalama ekrana, jeste da se preslo na 2k rezoluciju ali kapiram da ce svi novi paneli biti stedljiviji.
Tako da postoje 2 opcije, ili ce flagship telefoni ponovo imati odlicne autonomije i nastaviti tamo gde su stali G2, Z2/3, S5, M8 (sto je super a i bilo bi normalno) ili ce proizvodjaci stanjiti kucista na 5-6mm uz 2300-2500 mAh pa da se juri punjac 2X dnevno uz brzo punjenje :) Ne znam zasto ali ovo drugo mi deluje kao realnija opcija :d
Druga opcija ce se desiti.. :)
Jedino mislim da ce htc ostati pri logici povecanja baterije.(izbegavanje da se ide na debljinu moba od oko 6mm) Znaci na 5.2 ocekujem od njih ~2900mah bateriju.
Ovaj lik je dosta toga pogadjao u poslednje vreme.
Ma kad god, utoliko ce biti zanimljiviji MWC :smoke:
realno, zasto bi zurili, treba prodati jos koji S6 i njegove podvarijante. juce sam se malo igrao sa E+ od drugara. kakva je ono pornografija od telefona :zgran: cak ni ne deluje nesto glomazno u ruci obzirom da je 5.7". prebesan telefon.
Ovo je ocekivano posle predstavljanja s820 i najava vezanih za htc i kineze.
Velika sansa za huawei da napravi nesto sa mate 8 dok ne izadju ove azdaje.
svaka cast huawei-ju i drugarima ali...*** :)
Ma znam .. Ne moze niko prici svemogucem samsungu lol.
Dovoljno da prodaju milion uredjaja vise nego prosle god pa da se kaze da su "iskoristili trenutak"
Vrhunski uredjaj ce svakako imati,talas reklame od 6p takodje..
Nisam mislio na to, vec na ovo prvo sto si napisao. Mada ne znam o kakvim najavama vezanim za HTC i kineze se radi.
Ali planira se sve to mnogo unapred, ali bas, bas. Samsung je radio zajedno sa Qualcomm-om na S820, nije to tako jednostavno kako tebi izgleda: "januar cemo, ne ipak februar, a mozda je ipak bolje januar?"
Sta tako ? Pa ja sam prvi napisao da ce najranije izaci u martu. Imas tamo u z5 temi. To jest da je tesko da dodje na trziste pre marta.
Mislio sam na price da ce novi htc biti najranije 3 ceg meseca 2016 a isto su i kinezi najavili da se pomeraju za feb 2016.
Zato sam i rekao da je ocekivano da s7 ne izadje ranije,verujem da s820 jos nije spreman za mase,sto je i logicno
Much like Huawei’s recently announced Kirin 950 chipset, the Exynos 8890 features a Mali-T880 GPU, but as with all of ARM’s graphics processors, the secret is in the number of cores (the x in MPx, which follows the GPU model number). Samsung uses the Mali-T880MP12 with a total of a whopping twelve cores, as opposed to Huawei’s MP4.
http://www.gsmarena.com/samsung_exynos_8_octa_8890_is_official-news-14964.php
GPU sa 12 jezgara! :zgran:
Bolest [emoji15]
Ovo samo znaci da je i gpu na s820 ubica,nece smeti da naprave da se exynos mnogo razlikuje od s820
Prvo da vidimo kako će se pokazati u realnom radu
Naravno,novi exynos i s820 moraju biti priblizno isti da ne bi bilo diskriminacije kupaca s7.
Ogroman skok u performansama na papiru.
Edit:
Jos malo o mali gpu.
GPU side, we see usage of an ARM Mali T880MP12. This is the biggest Mali core implementation to date and increases the number of cores by 50% compared to the Exynos 7420's MP8 configuration. Keeping in mind that the T880 also increases ALU pipelines per core by 50%, we're looking at a 2.25x increase in computational power assuming Samsung kept the clock frequencies equal. Alternatively, they could go lower in frequency for much improved power efficiency. Samsung advertises 4K as an option for this SoC so likely we're looking at a very powerful GPU setup.
Anandtech
Vec vidim note 6 sa 4k rezolucijom :)
Ako je G5 najavljen sa 4k def ce u tom smjeru ici i Samsung. Samo me interesuje dokle ce ici, koji je to broj dje ce rec e sad ni pod mikroskopom se ne vide pikseli.
Haha, a zamislite samo koliko bi baterija bila bolja kad bi umesto glupog i nepotrebnog 4k stavili full hd. :)
Samo onda fanbojsi ne bi uzimali nove telefone od 600+ eura.
Ocekivani rez u multiju :) ubica. Mada mislim da ce ga malo skresati da ne bi pravio veliku razliku u testovima u odnosu na s7 s820 model
Prijatno sam iznenadjen sa kirinom. 2016 odlicna god u najavi. Samo da ne krenu na radikalno smanjivanje baterija
