Sta je sa s810
satro stedljiviji od s801 [emoji23]
http://mobile.hdblog.it/2015/11/10/Qualcomm-presenta-ufficialmente-Snapdragon-820/
CPU 'Kryo' is quad-core
The efficiency of this generation is such that Qualcomm was able to afford the 'luxury' to leave the configuration octa-core Snapdragon 810 and develop a quad-core custom : the debut of the first 64-bit CPU Kryo . The enhancements announced are obviously considerable, but the new approach and custom-cores that have made possible the leap that Qualcomm is prospecting there, with Kryo even 2 times more efficient in terms of consumption and performance compared to the core of S810 .
To achieve this it has also been working with the newproduction
process to 14nm FinFET and ability for core working at 2.2GHz, without negatively impacting on autonomy. All with a capacity of processing defined unparalleled, which is why it is thought already to a possible use of Snapdragon 820 in the automotive industry, virtual reality, computer vision and other integrated applications. The CPU works closely with the other key components of S820, as the GPU, DSP and Qualcomm Spectra ISP room, and in order to optimize all the processes between them was so developed theSymphony System Manager .
The task can be solved by one of these modules just mentioned, without weighing on the CPU (when necessary) and thus also save valuable energy.Symphony has the task of redirecting the tasks in this complex system, and also debuts with S820.
With the GPU Adreno 530 the leap forward is 40%
Graphics performance are more important than ever, especially in the mobile, why Qualcomm has been working on two fronts, providing superior processing power and low fuel consumption. In both cases of an estimated factor of 40% when compared to the 'old' Adreno 430 mounted on S810. Debuts today the Adreno 5xx series that we will see in other SoC, with the 510 variant ready to support Snapdragon 620 and 618 .
Another plus in the multimedia sector is the newQualcomm Spectra ISP room , which is the module that has the task of managing the image sensors and give them all the necessary means to shots of high-level (but it is clear that the difference will Also sensors and optimization software OEMs). Spectra is actually a dual-ISP that supports image sensors 14-bit , which means a wider range of colors available and a more realistic tone and natural skin color.
Edit:
http://www.phonearena.com/news/Half...Samsung-strives-for-Exynos-8890-yield_id75633
