S.T.A.L.K.E.R. — Clear Sky
A da vi prestanete da spamujete? :)
STALKER Clear Sky Funny Glitch...:D
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/fIKCHlPEpDo&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/fIKCHlPEpDo&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
^Call Of Duty 6? :d
dobro, ovo je zabavno, ali oni prolasci kroz zidove su naporni.neprijatelj proviri kroz zid blizu vrata i puca po meni, a ja pucam po njemu i pogađam zid.jupiii!mislim,poštujem to što su mladi ukrainci i što iza njih nisu milijuni dolara i što imaju želje i volje ali izvedba im šteka skroz.šteta!jer imaju mota za atmosferu, taman se ufilmam, creepy feeling u ranu zoru, napad na neku brvnaru, opališ metak a oni svi trk u zid od zgrade i trče ko veliki, guraju zgradu.stalno remse da ovo treba pustit da okrpe pa igrati a opet igram i opet remse...
PCGH test, Chernobyl Shooter tested with 11 graphics cards
Stalker Clear Sky: DX10 Benchmark Review
http://www.pcgameshardware.com/aid,659033/Reviews/Stalker_Clear_Sky_DX10_Benchmark_Review/
Processor requirements
Stalker: Clear Sky doesn't use more than a single core. Solely the graphics driver sometimes uses an additional CPU core sometimes. Therefore gigahertz and the performance per clock are important.
Bruka.:smash:
If you want to play Stalker: Clear Sky with all details in DX 10 a t a resolution of 1,680 x 1,050, you will have to use a multi GPU solution. If you don't need high framerates you can do with Geforce GTX 280 or a Radeon HD 4870. At 1,280 x 1,024 a Geforce 8800 GTX, 9800 GTX+ or a HD 4850 do quite well, but you will have to go down to 1,024 x 768 to make them display the game really smooth.
Stalker: Clear Sky requires a lot of RAM and video memory. Currently we are testing what processor is best, but at the moment more than one core seems to be useless.
Ko у Крњачи током вожње бајса :D
^Ahahahhaaha, nije ni ovde kod nas bolje :d
Btw, makar mu nije bilo tesko da nadje rep od pseudo doga
ovo usput pokazuje i nepostojanje fizike u igri. U krizi bi njesvi letele na sve strane...ovde ko da si bacio petardu, a ne kasikaru...(ok, znam da ima gasni upaljac, a ne kasiku al, ono...)
Kazu da je sa tim repakovanim i sbudzenim verzijama nemoguce izaci iz neke mocvare?
moguće je... ali plavi ekran i izletanje na desktop su ono, učestale pojave...
a i ono s usporavanjem miša sam primjetio što je već neko navodio. ko nije probao stvarno neka pričeka jer je naporno
Ok ljudi, u piratskom zalivu se pojavio ispravan lek za englesku verziju (v1.5.04) i upravo ga igram.
Kako mi da odemo do tog piratskog zaliva? Je l' imas mapu?
Ima mapa javi se na pp
Al meni treba nesto drugo, Full en verzija
Zahvaljujem se markoris-u i Jovyland-u na pomoci, radi!
Iako sam tek na pocetku uopste mi se ne svidja, samo kretanje, napucavanje...i lose radi 20-40fps, plus s vremena na vreme slika cudno blinka.
Sve opcije vezane za sunce stavi na medium/low, jer to najvise guta frejmove.
Jel i ova engleska verzija bagovita kao i ruska? Ako je, onda mi se ne zuri za igranjem.
Evo i mojih utisaka o igri:
Atmosfera iz 1. dela je i dalje tu. Ko je igrao, znace o cemu pricam.
Grafika je donekle ostala ista, mada su dodali par detalja, kao sto su sushafts...licno, donekle lepo izgledaju, ali gutaju frejmove, pa sam ih smanjio na low. I daje nebo izgleda lepo, a tek kad pocne da se smrkava.....brrr....kao da si tamo...
Performanse na masini iz potisa su u 85% slucajeva dobre (na rezoluciji 1440x900 i na nivou detalja koji je igra odredila, skoro sve na high (ili kako god se u igri zove), cini mi se). Naime, u nepravilnim intervalima igra kao da pocne da se gusi, da secka, istina, to sve traje manje od sekunde. Ne mislim na stuttering, nego na pravo pravcato seckanje, kao da je u pitanju Crysis ili neka jaaako zahtevna igra poput nje. A S.T.A.L.K.E.R Clear Sky, nije ni priblizno lep. Istina, mapa (za sada je u pitanju mocvara, dalje nisam stigao), je ogromna!
Dakle, za sada cu samo sumirati: vec vidjeno, ali i opet drzi paznju, grafika poboljsana, ali je zahtevnost pomerena na gore, za barem 50-60% ako mogu da primetim, kad se sve podesi na malo veci nivo.
Meni je ovo skroz OK igra:). Atmosfera je odlična, napucavanje mi se čini da je sređeno jer jedan ili dva metka sačmarom rešavaju problem, par metaka pištoljem takođe. Priča je dobra.
To za sacmaru vazi samo iz blizine, neki put moras i 4 komada da roknes da bih ga upokojio ;)
hehehe, naleteh na ovo na nekom forumu, lik je iz Teksasa, i bas zeli da sazna nesto vise o tim vanzemaljskim hijeroglifima iz igre :D
Respect :D
***eeeeeeeeeeeeeee, koliko dobro.
Al pazi on je neki mladi naucnik, vidis da se trudi da desifruje.
***, dovoljno je da pogleda da je igra iz Rusije/Ukrajine i da potrazo zvanicno pismo/font :type:.
Ljudi da li se i vama desava da vam igra random-li se skljoka. Stavio sam patch 1.5.03 jel to bese poslednja verzija? E da i jedno pitanjce da li cu moci da sa ovim sejvovima nastavim na engleskoj verziji igranje ili ispocetka posto sam podosta odmakao?
I mene ovo zanima... igra se ubija ko dobar dan... moze neko na pp kako da nadjem eng verziju...
Pa to je i uradio :) Zna on odakle je igra, a koliko vidim gore na zidu, prilicno je precizno napravio i "podsetnike" za izgovor slova.Ovo je vrlo zeznuta rabota za englesko govorno podrucje:p I garant ce da otkrije koliko je bolje/lakse od njihovog spelovanja:D
Хexe ал ми је смешно што је лик баш из Tekсаса, боље није могло :D
Koji sam ja ******, pa on igra rusku verziju :d. Zbog toga onolika pisanija i objasnjenija, u Vukovom stilu :banana:.
Malo sam spor ovih dana :wall:.
Haha, kakav kralj, jos ce nauciti azbuku :D
Mada mi nije jasno, ko ga je ucio to spelovanje cirilcnih slova, mislim, posle svakog slova dodaje (nepotrebne) nastavke, tipa '-ah', '-a', '-eh'...Mada opet, to je zaostavstina alfabeta :d
Sto ne sacekate 15.09 i lepo kupite pravu verziju, a ne ove budzevine.
