Bolje da si nam objasnio o cemu se radi nego sto me to pitash...sala naravno...Gde si pronaso ovu vest?
Do malopre je radilo , skidao sam danas film .
Sta je sad , ajde ljudi javite se.
Here's a network point of view on rapidshare.com's inaccessibility:
rapidshare.com (web and DNS) is hosted on a net block of 195.122.131.0 - 195.121.131.255 (also referred to as 195.122.131/24 CIDR in network terms) which is part of a larger block 195.122.128.0 - 195.122.191.255 owned by Level3 UK service provider. It appears Level3 has blocked inbound traffic destined for 195.122.131.0/24 at the edge of their network dropping all rapidshare.com traffic such as DNS, web, etc. This is not something that's normally done for routine maintenance or upgrades so there has to be a valid serious for taking such drastic measure and the only two that make sense are denial-of-service or legal. If the inaccessibility issue has been intermittent then that hints at denial-of-service but if it's abrupt then possibly legal. My guess is it's due to denial-of-service since since rapidshare.de (web hosted by Cogent ISP in US, DNS in DE and NL) is up and serving files. I'm really surprised rapidshare.com didn't invest some of the money they're raking in on making their services more immune to denial-of-service and more fault tolerant somewhat like rapidshare.de has done. Maybe they've finally realized and are doing a major redesign hence the downtime.
Ajd nek neko ovo malo pojasni nisam bash toliko vest sa Engleskim jezikom 🙂 ako ista korisno moze da se izvuce...
E a zamalo da uplatim rapid,kanim se vec mesec dana! Sta ce ovi sto dadose za 6 meseci ili godinu,ako ga ukinu skroz???
Šta je proradilo?Ajde neka ovi malo iskusniji igraci provere ovo pa nek jave o cemu se radi dal je FAKE ili sta vec?Ovde se kaze da je proradio...
http://projectw.org/viewtopic.php?f=21&t=562305
Javite o cemu se radi pozz
Da, samo taj url, probaj da otvoriš npr. premium user login.
Pa i mi ostali čekamo da vidimo šta je ustvari PRAVA istina.I sta je na kraju ISTINA
Ajde nek neko (ako ima herca) baci ovo u sistemski folder i proveri o ćemu ovaj Rus priča.Evo sta kaze covek...
I am re-opening this topic because I made a little mistake in my previous one which made it not-working. But actually it does.
There is a problem at the nameservers of rapidshare.com, but the fileservers are up and running.
If you download this file:
Code: Select all
http://www.xup.in/dl,15733470/hosts.zip
And put it in your 'C:\WINDOWS\system32\drivers\etc' directory, EVERYTHING from rapidshare will work 100%.
Not through some hacked site or something, check the code if you like.
Tested by me and a lot of others.
Thanks to antonow
PS: admin or mod; if you delete this post it would be plain dumb. This is not against the rules and works.
Vec treci put pokusava da ubedi ljude da na ovaj nacin radi ja nisam probao nek neko proba ako hoce...pozz
Code: Select all
Thanks to antonow
Nema na cemu bitno je da smo problem resili i da svima radi...:banana:😉@Skystar Majstore svaka ti cast sto si ovo iskopao.
Veliki pozdrav😀
