Poco X6 / F6 / Pro
faXcooL
Procureli su renderi za K70 i K70 Pro, što bi globalno bili Poco F6 i Poco F6 Pro :
Što se specifikacija tiče, još uvek ništa zvanično i razni izvori svašta različito pišu, ali ono što se uglavnom šuška je :
Poco X6 / Pro : SD 7s Gen 2, Adreno 710, 5100mAh, 67W, Corning Gorilla Glass Victus, 200mp/8mp/2mp/16mp
Poco F6 / Pro : SD 8+ Gen 2 (negde se navodi i Gen 3), Adreno 730, 5120mAh, 120W, 50mp/12mp/5mp/16mp
RAM se pominje u opsegu od 8 pa do čak 24GB.
Ako su spefikacije i približno tačne, F6 serija će biti prilično silna.
Zvanična najava se očekuje uskoro.
Zvanično predstavljanje K70 modela najavljeno za 29. novembar.
There will be three models in the new series of devices : the Redmi K70e, K70 and K70 Pro.
K70e : The base model of the series will come with a 1.5K OLED display, Dimensity 8300-Ultra chip, and a 5500 mAh battery with 90W charging and a 64 MP camera.
K70 and K70 Pro will get 2K panels at 120Hz, 5000/5120 mAh batteries with up to 120W charging and 50 MP cameras. The Redmi K70 will be powered by a Snapdragon 8 Gen 2 processor, while the Redmi K70 Pro will be powered by a Snapdragon 8 Gen 3 chip. How much the new products will cost is not yet known.
The smartphone is equipped with a 2K display with a frame refresh rate of 120Hz. The 12-bit panel has a peak brightness of 4000 nits, as well as support for HDR10+ and Dolby Vision. The OLED screen has a diagonal of 6.67".
The Redmi K70 Pro is powered by a Qualcomm Snapdragon 8 Gen 3 mobile processor. The chip is complemented by 24GB of LPDDR5X type RAM in the top-end variant, while the UFS 4.0 storage capacity is 1TB. The battery has a capacity of 5000 mAh and 120W fast charging.
The model received a triple main camera with a resolution of 50 MP + 50 MP + 12 MP. The main module has a Light Hunter 800 sensor of 1/1.55" optical format. Also note the presence of optical image stabilisation.
Redmi K70 Pro is equipped with NFC chip, USB-C connector, Wi-Fi 6E and Bluetooth 5.3 adapters. Also note the presence of stereo speakers, inbuilt in the display fingerprint scanner and front 16MP camera. The smartphone runs on the HyperOS operating system. The casing has IP68 class water resistance.
The Redmi K70 Prois available for pre-order in China and sales will start in December 2023. You can check out the prices below :
  • 12GB/256GB - $465
  • 16GB/256GB - $510
  • 16GB/512GB - $550
  • 24GB/1024GB - $620
Ja merkam F6 ili F6 kao sledeci telefon. Trenutno sam na F3 Pro i tacno ce mu biti 3 godine u junu/julu kada F6 izadje.
Ja sam na F3 isto merkam F6 ili F6pro mada će najverovatnije biti F6 tj, biće onaj koji prvi bude dostupan u prodaji kod nas.
Kontam što se performansi biće dovoljan i SD 7+ gen 3 koji će valjda biti u običnoj verziji F6.
Koja li će mu cena biti?
Kako vam se čini X6 pro , vidim da se cene krecu na kp od 370e pa na gore za 12/512GB, po specifikacijama je kidalica, baterija deluje dobra, dolazi sa A14 xiper os-om, valjda nema neke bolesti zbog kojih ti presedne telefon, tipa 13T magljenje kamere, neke fleke na displeju, battery drain, i td. Jedino što nema ništa još od maski i temepred glass-a da se kupi kod nas
Vidim da se zale na battery drain, al kao je reseno sa novim update. Ima li neko sa foruma da ga koristi da prenese utiske?
Ja bio pošteno zagrejan za x6 pro ali sam odustao kad sam skontao da nema ništa od Xiaomi.eu roma na Mediateku. Čekam F6 ili F6 pro, a vesti polako zakuvavaju... https://www.gizmochina.com/2024/03/12/poco-f6-could-be-launched-soon/
Ima li neki info od uvoznika? Jel se zna kad ce zvanicno u Srbiji da se pojavi
Koliko je meni poznato, Poco nema uvoznika i zbog toga ih nema na našem tržištu. Bar ne zvanično.
Izlazi Turbo 3 u Kini 10. aprila, koji ce valjda biti F6
Redmi turbo 3 kod čajneza 2000 žujana=oko 275$ valjda će ga poterati globalno skoro kao poco f6.
Taj mob će biti dostupan samo na KP ili će ga biti kod operatera, u radnjama ??
Da li ima neko ovaj x6 pro, kopa me nesto da zamenim 13 pro max posle 2 godine i to bas sa ovim pocom, ako ga neko ima i koristi voleo bih da cujem iskustva, hvala unapred!
Nemam ga, ali vidim na netu da se žale na curenje baterije. ako ti se ne žuri ja bih čekao poco f6 koji bi trebao da bude bolji po tom pitanju plus na njega možeš da ubaciš xiaomi.eu. a na x6 pro ne možeš.
Moze eu na x6 pro ali su ****** otvorili patreon gde moras da platis da bi dobio rom. Ista ekipa koja radi eu rom. Verovatno su videli da se dobro prodaje pa da malo i oni zarade.
Ja tek sad kapiram da u ovoj temi niko ne priča o X6 Pro, već se svi samo oblizuju kad će F6 da dođe. X6 Pro izgleda ne interesuje nikoga, što me čudi, jer telefon deluje kao ok naslednik F5, vrlo slične specifikacije, praktično ista cena, slično trajanje baterije, a dobiješ još tri buduća Androida, dok moj F5 će da dobije još samo jedan. Korisnici su generalno zadovoljni, 4,6 zvezdica. Jedino ne znam što bi menjao još uvek aktuelan telefon ovako rano.
Telefon je odlican. Moj kolega ga je kupio na kp pre par nedelja. Procesor dobar,brz. Igra samo zahtevne igre i ono sto sam ja probao prosto leti. Bio je moja druga opcija za kupovinu ali sam se ipak odlucio za oneu. Imao sam od redmi note i redmi 1 sve modele do redmi note 10. Izgleda da sam se zasitio miui sistema. Posle note 10 mi je sve postalo dosadno i uvek se zavrsavalo sa nekim custom romom tipa pixel experience. Ali za x6 pro nemam nista lose reci. Ekran dobar, brzo radi, jedino kamere nikad ne komentarisem jer ih ne koristim skoro nikad.
Ja se oblizivao neko vreme pa batalio i kupio Xiaomi 14, 6 meseci je previše čekanja x6 pro sam merkao ali nekako ga nisam video kao dovoljan upgrade u odnosu na poco f3, pogotovo što sam vezan za originalni rom jer ne želim da plaćam za xiaomi.eu rom za MTK.
Da, to mu je jedina mana. Naprotiv, procesor je predobar ali je podrska slaba. Da je neki snapdragon bio bi ubedljivo najprodavaniji. Izlazili bi custom romovi narednih 5 god minimum.
