My Brute, simpa flash igrica :)
hej ljudi,oce neko da kreira benchmark klan,ja bi se pridruzio..:)
ako ima vec,budite ljubazni dajte link...:)
Evo i ja sam se prijavio u klan :D kontam da sam jos slab al ko oce nek me testira :D
pri'vaceno vas troje ;)
Super fala :D
Mene je igra smorila skroz, vec 3 dana nisam igrao. Mislim da cu bataliti.
posalji mi password na PM...:d
Ko hoće da vodi bruta sa vukom i ne smeta mu bezvezno random ime, evo mu ovog.
http://liloilkkoo.mybrute.com/cellule
Pravio sam par učenika za EXP iz dosade i jedan ispade sa vukom od prvog nivoa. Frišak, još neupotrebljen, traži nekog da ga usvoji.
mnogo mocan brute...sad ne moze ni password...:(
pokida me u komade....:)
vuk je do jaja znaci..xD
Kada pomenu taj password, prva dva bruta koja sam pravio nisu imala opciju za password, dok je tek treci dobio istu. Jeli to neki bag ili sta...?
nije bag, evo procitajte sami
When you create a brute character, cookies are stored in the computer where you created it. The cookies are stored there until it is removed.
When you access your brute in another computer, you’ll notice that the option to create a password is not available. If you want it to appear, you have the following options:
Option 1:
Use the original computer where you created the brute and create the password there.
Option 2:
Go to the original computer where you created the brute and use a software that back-ups the cookies in a computer. One example is the FEBE Firefox Extension.
Simply back up the cookies and then go to your computer and restore the cookies there. After that, the option to create a password for your brute will now be available.
Remember, this method will only work if the cookies in the original computer has not been not deleted or cleared from the time you created the brute character there. Otherwise, it is gone forever.
So the next time you create a character in an internet cafe or on a friend’s computer, always put a password immediately or at least, back-up the cookies. So that when you get home, or when you someday decide to put a password on the brute, you can easily do so.
Ma napravio sam ga kod prijateljice, i nakon sto sam procitao na netu to sto si mi ti sada napisao, otisao kod nje i nije bilo opcije za sifru... Nema veze... Sibamo se dalje :D
meni je pre 10ak dana promenio sam od sebe klan, iako sam ga ja osnovao, na rur-u
pa sam upao u klan koji je bio 4. na listi
danas pogledam kad ono opet neki levi klan sa 2 clana lol
pokusam da se ulogujem, promenili mi shifru... to je to, ne igram vishe uopste a imao sam 100ak uchenika i 16 lvl
sta tu imas da zardjas majke ti - 2 minuta zezanja dnevno i to je to..:)
***, sto volim tako da ostavim nekog na 1 helta i onda da umrem... xD
to mi, izgleda, draze nego 'leba da push...... am... jedem... :d
http://funkkilluh.mybrute.com/fight/679747028
Majlo, ti nesto o dva udarca??? :d
edit:
evo, i sa ovim da ti vratim...
http://madafankinz.mybrute.com/fight/679908838
doduse, ovog si mi dobio... jedva, ali dobio... (mada, bilo mi je dovoljno za lvl :D)
http://neko-*******.mybrute.com/fight/679831522
dobar si, evo imam i ja nesto za tebe, to isto samo malo drugacije :-devil-: :
http://majlog.mybrute.com/fight/694507462 - dobar ti ovaj lik
http://majlog.mybrute.com/fight/694515723 - ovaj put me on dobi, mora da je zato sto je dobio lvl
http://majlog.mybrute.com/fight/694522082 - ovaj ti je 17lvl?! :D
A tesno je, stalno, sa ova dva slabija (zato sto imaju poprilicno los helt), ali onaj sto je 17-i... znaaaaaciiiiiii -.-
taj sto voli da se bije bez oruzja, pa to je strasno... -.-
A inace, sa njim redovno gubim barem po 2 borbe dnevno -.-
I za taj sedamnaesti lvl dobih 1 agility-ja... Jee... xD
Strasno...
izgleda kako raste lvl,pada AI...:(
