Mene je igra smorila skroz, vec 3 dana nisam igrao. Mislim da cu bataliti.
When you create a brute character, cookies are stored in the computer where you created it. The cookies are stored there until it is removed.
When you access your brute in another computer, you’ll notice that the option to create a password is not available. If you want it to appear, you have the following options:
Option 1:
Use the original computer where you created the brute and create the password there.
Option 2:
Go to the original computer where you created the brute and use a software that back-ups the cookies in a computer. One example is the FEBE Firefox Extension.
Simply back up the cookies and then go to your computer and restore the cookies there. After that, the option to create a password for your brute will now be available.
Remember, this method will only work if the cookies in the original computer has not been not deleted or cleared from the time you created the brute character there. Otherwise, it is gone forever.
So the next time you create a character in an internet cafe or on a friend’s computer, always put a password immediately or at least, back-up the cookies. So that when you get home, or when you someday decide to put a password on the brute, you can easily do so.
http://funkkilluh.mybrute.com/fight/679747028
Majlo, ti nesto o dva udarca??? :d
edit:
evo, i sa ovim da ti vratim...
http://madafankinz.mybrute.com/fight/679908838
doduse, ovog si mi dobio... jedva, ali dobio... (mada, bilo mi je dovoljno za lvl)
http://neko-*******.mybrute.com/fight/679831522
evo daily report:
http://pawnor.mybrute.com/fight/699423945 - ludi100%
http://pawnor.mybrute.com/fight/699432278 - kudtihaex
http://pawnor.mybrute.com/fight/699450150 - doca999
poz decki
