BBS - Better Battery Stats **OBAVEZNO pročitati prvi post**
Izašla koliko vidim v2.0 stable - moglo bi da se proba, ima mnogo promena od 1.16.0.0
Download - http://forum.xda-developers.com/showthread.php?t=1179809
Kod:
2.0.0.0
No functional changes from RC6
Merged I18Nalized changelogs
2.0.0.0RC6
This is the golden release: release notes have been updated for the upcoming 2.0
#650: semi transparent grey touch feedback for pre-lolipop devices
- Sorry, no fix for the unthemed dialogs: there is a bug in appcompat to that and I could not find a way around that except rewriting all dialogs and that is too much change at this point in time.
2.0.0.0RC5
#632, #633, #634, #635: Fixed package info dialog (colors, label width)
#639: added arabic (testwise)
#626: fix (again) for FC on long press using german language
2.0.0.0RC4
#626: fixes crash when long-pressing a list item
#630: added credits for I18N
#631: hotfix for issue with RC3 on pre-lolipop devices
2.0.0.0RC3
#616: no battery graph when all values are 100%
#617: no changelog showing in RC2
#618: add info to dumpfile is alarms/kernel wakelocks are from API
#621, #624: I18N
#622: material design touch feedback
#625: FC opening dashclock settings
2.0.0.0RC2
#552: fixed wrong style for overflow menu in dark theme
#609: fixed oblique lines in graphs
2.0.0.0RC1
#546: option to force EN-en locale
#569, #582, #588, #595: more translations
#583: move *api* out of the title
#585: optimized load time of graphs
#586: use white icon for watchdog notifications
#597: battery graph always shows same data
#599: FC opening credits screen
#600: clean up debug info from normal logcat
#602: fixed watchdog reporting of awake
2.0.0.0B7
#491: added frature to import/export preferences
#540: System App Dialog now includes link to the recovery ZIP as a workaround is in-app install does not work (links to XDA or gplay, depending on version)
#551: fixed "pinned" battery graph
#553: lighter cicle gauge and font
#554: settings screen and white text on the light background that appears after clean start
#558: make from-to ref spinners suppressable
#563: more I18N (thanks to gaich and mag01 fpr their hard work keeping up with me changing the strings)
#564: alarm details dialog title is too dark for dark theme
#566: add notification bar color for lolipop
#572: pass the su --context for accessing dumpsys alarm (may cause slowdown, please report on that with supersu version you are using)
#574: better performance in graphics
2.0.0.0B6
#521: make icon size and font size adjustable
#522: kernel wakelock using API fail on lolipop
#550: missing strings
#556: fixed native kernal wakelocks on lolipop
#557: no translation of array, mote stuff to strings
2.0.0.0B5
#360, #529, #534, #539: more externalized strings for I18N
#387: use of wakelocks with timeouts, because I can
#511: Themed dialogs
#517: redesigned graphs
#527: add SELinux policy to dumpfile
#532: fixed theme switching issues
#535: added Czeck, thanks to mag01
#536, #537, #538: added russian, thanks to gaich
#531: fixed alarms dialog showing infinite / Hr.
#545: merged new constants that were causing the wrong stats to be processed
2.0.0.0B4
First shot at I18N: implemented german
#495: cleanup ununsed libs
#502: cleanup assets
#518: fixed infinite wakeups per hour in alarms
#519: re-add battery from/to % to screen (optional)
#520: alignment of labele/icons
#523: theme switch only complete after restart
#524: switched back from cards layout as it takes too much real estate
#525: notification area invisible by default
#526: FC after theme switch
#528: Partial wakelocks show wrong values (thank google for changing the constants again)!
2.0.0.0B3
#484, #508: surface information about errors / failures to the UI
#493: avoid retrieving the battery level from battery info API to reduce load (and avoid service unavailable)
#497: added dark theme
#509: added % from/to back to dumpfile
#512: theme preference slider controls
#513: fixed empty release notes
#515: automatically detect SELinux preventing access to dumpsys alarm and fall back to API mode
#516: fixed alarms showing infinity in gauges
2.0.0.0B2
#496: fixed gauges in RAW stats always being 100%
#499: "since" and white header missing in raw stats
#504: failed remot to ro after system app install does not report an error anymore since the app was installed correctly
#505: advanced pref to enable alternate (API) mode for retrieving alarms (and avoid the need for permissive kernel)
#506: alarm details missing in dumpfile
Bigger changes under the hood: externalized all preferences to prepare for I18N
2.0.0.0B1
It's all new and shiny
#487: ability to save JSON format from tasker plugin
New calculation approach to avoid rounding differences
Simplified / removed unused options from settings
Removed google analytics
1.16.1.0B2
#486: watchdog does not warn
1.16.1.0B1
#446, #483: watchdog warns about 100% awake even if reading shows it's not the case
#481, #482: FC conditions from crash reports
#485: addedf more comprehensive info about BATTERY_STATS perm and Xposed setting to dumpfile
Ja iskreno nikakve razlike ne vidim sem promene izgleda. Isprobavam ga vec par dana. Za sada je sve u redu. Ko hoce moze da predje, a i ne mora ;)
Evo materijala za gatanje :)
Za ta 4 sata koliko je bio na "na čekanju" stiglo je par mejlova i sms-ova, ali nije diran 4 sata...
https://db.tt/X0mMqzbU
Pa skinulo ti 2% baterije za 4h. Šta tu ima da se gleda?
Dobar savet - skinuo sam to Samsung đubre sa telefona .
Evo nove statistike sada bez te aplikacije i nekih drugih - https://db.tt/zLqy8lU9
Kada sam video ovo i ocenu , nisam mogao da poverujem - https://play.google.com/store/apps/details?id=com.blurb.checkout&hl=en
0.2%/h presavrseno :)
***, bio si na LG-u, moras sad kupiti malo i Samsung fore :d
Fore su im nebeske - ko nije rutovao telefon može samo da plače :D
Zanimljiva stvar je da noob ljude cuva neki Bog. Gledao sam drugarov Note 4. Baterija savrseno traje, sve po PS-u, a sve mu popaljeno kao i nama koji se razumemo. Sad ne znam jel to karma neka nas uhvati, pa moramo da brisemo ili sta vec, ali skenjao sam se :d
Pre će biti da ti što ne pipaju ništa imaju malo aplikacija .
Ja npr imam trenutno 142 instalirane + sistemskih 278, ali koristim greenify pa sve savršeno radi (RAM status 1.7 GB zauzeto od 2.77GB)
Moram da vidim šta još ima da se briše od samsung đubreta ...
Ti si tek lud 142? Koristis ih svakodnevno? :)
Nije da imaju malo, ovaj ima oko 50 instaliranih, ja npr imam 40 :)
Naravno da ne svakodnevno, ali tu su i ne prave problem (nakupilo se godinama) ...
Ma znam tako sam i ja skupljao, ali sam resio da skresem sve na telefonu. Vrtim se tako oko 40-45 i ne mrdam. Ako ne koristim app svaki bar drugi - treci dan, leti. :)
Nema potrebe - sve odlično radi, mesta ima na telefonu dosta, ne rade u pozadini i ne smetaju :)
Tih 40 samo na jednoj stranici :D
Kazem ja, lud covek :d
Nova.
@Djilkosh_Ns
Jel mogu da insaliram ovu novu verziju BBS-a? I da li mogu da ga nocas (nekih 7 sati) ostavim umesto 4 sata pa da okacim log?
I jel moze pomoc oko podesavanja? Jer u ovoj novoj verziji nikako ne mogu da nadjem ono sto pise u prvom postu. Koristim Neat 6.4 na S2
Evo da javim u vezi gms-a u bbs-u.
Posle 14h, wakeups 156 (11/h)
Medju njima najbrojniji su proces send_idle i eventlogservicereceiver
@Djilkosh_Ns
    306.3 KB · Pregleda: 143
@Djilkosh_Ns
Mozes da instaliras. Mozes 7 sati. Minimum je 4 sata, a sto vise to bolje, precizniji rezultati. Pa ima sve isto je, sta ti nije jasno pitaj slobodno.
Hvala vam obojici.
Nikola koliki ti je uptime, posto vidim da pise tamo from boot?
Pa izračunaj, ako je 192 ukupno i 16 po satu ne treba ti neka nauka valjda [emoji13]
3 sata je Vojkane. Kasno je da razmisljam :D
12h je bio uptime :) tj. from boot
@Djilkosh_Ns
Podesavanje aplikacije:
settings > dumpfile > oznacite sve > Process stats, Service Stats (treba root), Alarm Stats(treba root), Network Stats(treba root), CPU States.
> advanced > Iskljucite Google Analytics
> Ukljucite Root Features
Obavezno za korisnike 4.4.x verzije androida
Posto je Google promenio kako se cita baterija pocev od 4.4.x treba otici u settings > advanced > kliknuti na System app (experimental) > restartovati telefon
Kako odraditi dumpfile:
1.) Otvorite aplikaciju
2.) U gornjem desnom uglu videcete dugme SHARE
3.) Kliknite na njega
4.) Otvorice vam se prozor, otkacite samo > Text Dumpfile
5.) Idite na Save ( dumpfile se sacuvava pretezno na vasoj internoj memoriji nekad i na eksternoj u putanji > /sdcard )
Nije mi jasno kako u novoj verziji aplikacije da podesim onaj prvi deo "Podesavanja aplikacije".
Drugi deo je za 4.4.x, a ja sam na NEAT 6.4 za S2, tako da ovo za mene ne bi trebalo da vazi. Treci deo za dump file je identican i na novoj aplikaciji.
Evo slika sta ima od podesavanja, u kojima ne mogu da nadjem ono sto si rekao da trebamo da podesimo:
Chamonix je izbacio to fino podesavanje, tako da ne moras da podesavas, vec je podeseno, da ne bi bilo polovicnih logova. Da ovo 4.4.x ne vazi za tebe :)
