avg 8 update problem
pilauda
CPU & Cooler
7800x3D & Dark Rock 4
Matična ploča
GigaByte B650M Aorus Elite AX
RAM
2 x 16GB DDR5 Kingston 6000 CL30
GPU
MSI RTX 4080 SUPER 16G GAMING X SLIM
Storage
Samsung 990 pro 2TB , Silicon Power 2TB
Zvuk
Edifier R1700BT
PSU
FSP Hydro G PRO 1000W ATX3.0
Kućište
CoolerMaster MasterBox TD500 MESH
Monitor
Gigabyte 27'' AORUS FO27Q2 OLED
Miš & tastatura
Scyrox V8, Razer Ornata V3
Ostale periferije
Xbox Series X
Laptop
HP 15s-eq2083nm
Mobilni telefon
iPhone 13 mini
Pristup internetu
  1. Optički internet
Od veceras nece vise update, kaze sledece (na slici) sta raditi?
Jesi li probao manuelno da skineš bin fajl pa da ga apdejtuješ sa kompa a ne sa neta?
Ovo je sa zvaničnog support sajta:
If you receive the "Invalid update control CTF file" message during AVG update, most probably the update control files are corrupted. In this case it is necessary to delete these files. During a next attempt to update AVG, new control files should be downloaded and update process should be completed without any difficulties. Please kindly follow these steps to delete mentioned control files:
* Download the utility from the link below to your hard drive
deleteupdatefiles.exe
* Run the downloaded utility (command line window will appear for a short time)
* Try to update the AVG program
If the issue persists, then please follow steps below:
* Double-click the My computer icon on your desktop (or open Start -> My Computer)
* Navigate to the following folder:
o Windows XP / 2000:
C:\Documents and Settings\All Users\Application Data\avg8\update\download *
o Windows Vista:
C:\ProgramData\avg8\update\download *
* Find the avginfoavi.ctf and avginfowin.ctf files and delete them
* Restart your computer
* Please note that some folders/files could be hidden. For more information how to view these hidden folders/files please visit this FAQ: How to view hidden files and folders
If the issue persists even after performing the steps above, please contact us using the Get Help Online option in AVG Help menu.
to je to hvala
Nije im prvi put.
Sa starijim verzijama postoji trik da udjes u podesavanja i ispraznis "update" kes. Posle toga radi normalno.
To je jedan od razloga zasto sam sa AVG 8-ce presao na Aviru.Jednostavno su te sitne opcije skinuli sa 7.5 koja je bila stvarno dobra.Kao da su uradili downgrade, a ne upgrade.
Inace, ja sam rucno stalno brisao ove fajlove(recimo logovi su posle kratkog vremena umeli zestoko da narastu) pa tako da jedno kratko vreme koliko sam koristio avg 8 nisam imao nikakvih problema sa updateovima.A koliko sam video ccleaner ima i podrsku za avg 8 pa msilim da bi i on mogao da sluzi kao brisanje ovih update fajlova.
