TX9S имаш на КП за 3500.@amdpower posalji link gde si kupio, trenutno trazim neki model da pazarim.
Ne može Netfix. Za Netflix je sertifikovan Mecool KM2 ali je mnogo slabiji u svemu od KM6.Može li netflix 4K
SoC | S905X3 | S905X4 |
Technology | 12nm | 12nm |
CPU | Quad-Core Cortex-A55 | Quad-Core Cortex-A55 |
Up to 19700+ DMIPS | Up to 21800+ DMIPS | |
GPU | ARM Mali-G31 MP2 | ARM Mali-G31 MP2 |
OpenGL ES 3.2 | OpenGL ES 3.2 | |
Vulkan 1.0, OpenCL | Vulkan 1.1, OpenCL | |
2 | 2 | |
CAS | VMX, Widevine CAS,Irdeto MSR 3.2 | VMX, Widevine CAS,Nagra NOCS3.2,Irdeto MSR3.2 |
DRM | Widevine, Playready, VMX | Widevine, Playready, VMX |
Crypto Engine | AES/TDES/SHA-1/SHA-2/HMAC/SM4 | AES/TDES/SHA-1/SHA-2/HMAC/SM4/RSA |
Neural Network | 1.2 TOPS CNN and 8X RNN | |
inference accelerator (optional) | – | |
Memory | 32-bit DDR3/3L/4, LPDDR3/4, Up to 4GB, DDR3200 | 32-bit DDR3/3L/4, LPDDR3/4, Up to 4GB, DDR3200 |
Storage | eMMC 5.0, NAND Flash, SPI NOR/NAND, SD | eMMC 5.0, NAND Flash, SPI NOR/NAND, SD |
Video Decoder | 4Kp75 10bit: H.265/VP9 P-2/AVS2 | 4Kp120 10bit: AV1 |
4Kp30: H.264 | 4Kp75 10bit: H.265/VP9 P-2/AVS2 | |
4Kp30: H.264 | ||
HDR/WCG | HDR10/10+, HLG, Dolby Vision, TCH PRIME | HDR10/10+, HLG, Dolby Vision, TCH PRIME |
BT.709/2020/2100 | BT.709/2020/2100 | |
Video Encoder | 1080p60 H.265/H.264 | 1080p60 H.265/H.264 |
Ethernet | 10/100/1000 MAC + 10/100 PHY | 10/100/1000 MAC + 10/100 PHY |
USB/PCI-e | 1x USB 2.0 + USB 3.0 / (PCIe Gen-2+USB2.0) | 1x USB 2.0 + USB 3.0 / (PCIe Gen-2+USB2.0) |
Voice & Audio Processing | VAD, ASRC/EQ/DRC | VAD, ASRC/EQ/DRC, |
2xHiFi4 Acoustic/Audio DSP | ||
Audio In/Out | Stereo DACs, SPDIF-in & out, | Stereo DACs, SPDIF-in & out, |
8Ch PDM, 12+Ch I2S in, 12+ch I2S out | 8Ch PDM, 12+Ch I2S in, 12+Ch I2S out | |
Video Output | 4Kp60 HDMI 2.1, HDCP2.2, CVBS | Kp60 HDMI 2.1, HDCP2.3, CVBS |
DVB | 2x TS in, ISO7816 | 2x TS in, ISO7816 |
Ja sam okrenuo naopako kuler za laptop da izvlači toplotu iz boxa 😉Koristi li neko kulere za android boxove?
Ovaj moj h96 max x3 ima proreze sa donje strane koji nicemu ne sluze jer se topao vazduh podize.
Razmisljao sam da narucim ovako nesto sa alija mada bih radije kupio ovde nesto ali ne nalazim nista zanimljivo:
1 - има и класичан андроид, а не само АТВ верзија слимбокса.1. Slimbox je ako sam ja dobro razumeo alternativni firmver koji Android box onaj koji fabricki nije na Android TV sistemu prebaci da to bude, neka me isprave ako gresim, nisam neki fan Android boksova pa ne pratim to toliko bas ...
2. Ne, jer verovatno ubacuju klasican bulid za Kodi tipa Balkan Green ili neki slican, nauci da konfigurises Kodi, sam ces ga sebi najbolje napraviti kad shvatis sta ti treba a sta ne.
edit: pre neki dan sam video na KP-u da neko naplacuje izbacivanje reklama sa Youtuba, eh sta sve nece smisliti samo da naplate nesto ...
