Sto bre linuksashi toliko pljuju Windows i Bill Gates-a
Kome treba iPod pored mobilnih telefona koji pustaju mp3 :)
Aj nemoj sada i ti voodoo da preterujes.
Ja na svoja kucna 2 kompa imam Linux, FreeBSD i Win i iskreno da vam kazem FreeBSD radi nastabilnije/najbrze... E sada to sto je na Linux-u najveci hipe to je druga stvar...
DOS Airline: Everybody pushes the airplane until it glides,
then jump on and let the plane coast until it hits the ground
again, then push again, jump on again and so on.
Mac Airline: All the stewards, stewardesses, captains, baggage
handlers, and ticket agents look the same, act the same, and
talk the same. Every time you ask questions about details, you
are told you don't need to know, don't want to know, and
everything will be done for you without you having to know, so
just shut up.
Windows Airline: The airport terminal is nice and colorful,
with friendly stewards and stewardesses, easy access to the
plane, an uneventful takeoff...then the plane blows up without
any warning whatsoever.
NT Airline (old): Everyone marches out on the runway, says the
password in unison, and forms the outline of an airplane. Then
they all sit down and make a whooshing sound like they're
flying.
NT Airline (new): Just like Windows Air, but costs more, uses
much bigger planes, and takes out all the other aircraft within
a 40-mile radius when it explodes.
Unix Airline: Everyone brings one piece of the plane with them
when they come to the airport. They all go out on the runway
and put the plane together piece by piece, arguing constantly
about what kind of plane they're building.
Linux Air: Disgruntled employees of all the other OS airlines
decide to start their own airline. They build the planes, ticket
counters, and pave the runways themselves. They charge a small
fee to cover the cost of printing the ticket, but you can also
download and print the ticket yourself. When you board the plane,
you are given a seat, four bolts, a wrench and a copy of the
seat-HOWTO.html. Once settled, the fully adjustable seat is very
comfortable, the plan leaves and arrives on time without a single
problem, the in-flight meal is wonderful. You try to tell customers
of the other airlines about the great trip, but all they can say is,
"You had to do what with the seat?"
OS/2 Airline: To board the plane, you have your ticket stamped
ten different times by standing in ten different lines. Then
you fill out a form showing where you want to sit and whether
it should look and feel like an ocean liner, a passenger
train, or a bus. If you succeed in getting on board the plane
and the plane succeeds in getting off the ground, you have a
wonderful trip...except for the times when the rudder and
flaps get frozen in position, in which case you have time to
say your prayers and get yourself prepared before the crash.
A sta ti drugo treba?
Mozda je Windows ipak zanimljiviji sa tolikom kolicinom plavih ekrana i reinstalacijama :)
E pa i ti ga pretera sada :) mnogi odavde nisu videli BSOD mesecima a i godinama :)
@Voodoo: to je matoro... a i prelazite u offtopic. Fazon je u tome sto ako neko ne moze a zeli da predje sa Windowsa na Linux zbog nedostatka raznoraznog softvera (glup primer: Photoshop), moze da migrira na MAC OS. MAC OS X jeste nasminkan ali on radi posao za koji je namenjen. Ok, radi i Windows, ali ovo je OutOfBox prica, nema potrebe za dodatnim shtelovanjem i zezanjem kao kod Windowsa.
Po meni to je najveci problem Maca - ono sto dobijes outofbox ima los odnos cena/kvalitet. Drugi problem je hardverska zatvorenost sistema; dok se to ne resi Mac nikada nece biti sire zastupljen iako to po svojim karakteristikama zasluzuje.
mac os nije nista epohalno... prosto je sistem koji radi!
i po cemu se onda razlikuje od Windowsa ili Linuxa? :D I oni su sistemi koji rade (kod vecine ljudi koje ja znam: rade veoma, veoma dobro...)
a price o stalnim plavim ekranima i reinstalacijam su totalno smesne i out - jednostavno, to nije tacno!
stvarno BSOD ne pamtim kad sam video (poslednji put kad sam OC graficku kartu :D) ali stvarno retko da se windows srusi... recimo PhotoShop mi je pukao 4 puta za 4 godine... retko.
ALI poslednjih mesec dana mi se desava da internat.exe (to je ona mala ikonica u systemtray-ju za izbor testature) nece da se startuje sa windowsom (moram svaki put rucno da ga palim)!
1. selektujem opciju u kontrol panelu (kayboard -> pa chekiram opciju "Show...")
2. resetujem system i internat.exe je tu u systemtray-ju
3. resetujem drugi put system i nema ga!
proveravao sam u regeditu i stvarno se izmedju drugog i treceg restarta sam izbrishe iz registryja!!
Ovo sve mi se desava pod win2k koji koristim 4 godine i nikad mi nije pravio slicno sranj*!
a pazite, ja sam neko ko koristi racunare 20 godine a ne mogu da izadjem na kraj sa ovim problem - sta da radi "obican" korisnik racunara kad mu se ovo desi?! fuck 2 windows! previshe je komplikovan da bih mogao da znam sta se tachno desava. a sranj* je zato sto se uopste desavaju ovakvi problemi.
btw eventualno resenje je da gurnem internat.exe u "startup" folder...
delimir je napisao(la):
Mozda je Windows ipak zanimljiviji sa tolikom kolicinom plavih ekrana...
ti mora da koristiš "benchmark blue" temu na benču i pri tom otvaraš dosta tabova :D
možda nije loše ni desktop postaviti da bude neke druge boje osim plave :d
