Fatekeeper
SteXmaN
Poštovan
CPU & Cooler
AMD Ryzen 9 5950X / NZXT Kraken X73 360mm
Matična ploča
B550 AORUS ELITE AX V2
RAM
Kingston HyperX Fury DDR4 3600MHz 2x32GB
GPU
Gigabyte RTX 5080 WINDFORCE OC
Storage
2xKC3000 PCIe 4.0 NVMe M.2 SSD 1024GB / 6TB HDD
PSU
LC POWER 850W LC6850M V2.31 80 PLUS GOLD
Kućište
TUF GT501
Pristup internetu
  1. Optički internet
Venture through ancient battlegrounds, forgotten ruins, and mystical forests as you uncover relics, shape your path through meaningful choices, and face enemies that demand both skill and strategy. Customize your build with a deep progression system, master unique weapons and armor, and forge your fate through a world where every encounter and every choice matters.
Game Features:
  • A Handcrafted World
    While Fatekeeper follows a focused narrative path, the world invites exploration. From ancient battlegrounds, vast underground caverns and serene forests to crumbling sanctuaries forgotten by time, each area rewards curiosity with hidden lore, forgotten relics, and unexpected encounters.
  • Melee & Magic
    Battle a wide variety of foes, each with distinct patterns, strengths, and weaknesses. Success demands both skill and preparation. Engage in reactive melee combat, unleash spells with precision, and adapt your tactics on the fly. Your build matters—but so does how you wield it.
  • Progression
    Fatekeeper offers rich progression mechanics that go far beyond surface-level stats. Build and refine your character with meaningful choices across combat styles, attributes, and spell schools. Whether you lean into raw strength, nimble precision, or devastating sorcery, the game supports a wide range of viable and unique builds.
  • Armor & Weapons
    Discover, loot, and master a wide variety of weapons, armor, and artifacts. Customize your loadout to suit your playstyle, and experiment with powerful combinations to overcome increasingly challenging enemies. Every item matters—and the right gear can be the difference between victory and ruin.
Odlično izgleda. Nadam se da će leveli pružiti dovoljno istraživanja.
Ragdoll fizika impresivno izgleda, možda jedino kako se onaj strelac odmah pretvorio u krpenu lutku pri prvom udarcu.
Kod mini bossa se vidi da hitboxes su jako precizno odrađeni.
Sviđa mi se šta vidim.
Obećava, obećava... Naleteh baš na čoveka koji je radio koncept art za igru, a vidim i da je gejmplej demo u međuvremnu izašao a tema ovde postavljena, pa ko velim da okačim i ovih nekoliko sličica odakle se može videti ideja za level art.
Sutra u 19h izlazi igra (Early Access).
Kako ovo podseća na Dark Messiah of Might and Magic
Samo da ne bude nesto kvazi-linearno... U 2026 kakav-takav open world je standard.
kupio sam je malopre, pa cu danas posle podne probati pa javljam utiske
samo sam je startovao da vidim kako radi jer imam sad neke obaveze, ali deluje dobro i optimalizovano
4K, sve na ultra, FSR quality
    417.9 KB · Pregleda: 52
    390.5 KB · Pregleda: 47
    442.3 KB · Pregleda: 46
    626.2 KB · Pregleda: 48
    540.6 KB · Pregleda: 47
    582.8 KB · Pregleda: 59
Jel neko zna koliko od igre je dostupno u EA?
Čitao sam kratak Lore što su izbacili na svojoj steam stranici, baš mi se dopada.
Fatekeeper Lore Part I: https://thqn.net/4rIeGEA
Haven - The Hub of Fatekeeper: https://thqn.net/4qiRV8N
Weapons of Fatekeeper: https://thqn.net/44GNPzn
Creatures of Fatekeeper: https://thqn.net/4ne3Mnb
World of Fatekeeper: https://thqn.net/3LG3EzM
Trenutno ima oko 2h gameplay-a, planirano je da bude 15h story.
Combat je vrhunski... vidi se iz aviona!
Ali ovaj "ostri" splet planina, prelaza i prevoja... previse mi "ide u visine" tj. smrdi na kvazi open-world ( semi-linear ).
Ne verujem da je open world, posebno jer će biti prilično kratka igra. Ipak trenutku košta 8 eura, cenim full verzija može da ode na 30.
U ovakvoj grafici i combat-u (10/10) : da je open world - pravili bi ga min 40 developera ( a ne njih 13 )... koliko kapiram nema ni story.
Bice to vrhunski "medievel Doom"... super zezanje ! Prijatno gaming osvezenje za 10EUR... a igra ce tek da raste.
Nije open world (i drago mi je sto nije) vec linearni hack & slash iz prvog lica sa RPG elementima (tu je masivni skill tree). Kao sto se vec zna, na igri radi svega 13 ljudi i prosto je nevereovatno sta su do sad postigli da urade sa igrom. Grafika je neverovatna, kao neki odlican UE5 tech demo, borba veoma dobra i igru bih opisao kao neki mix Dark Messiah-a i medieval Doom-a (kao sto @golub ) rece u post-u iznad. Early access nudi oko 2-3h gameplay-a, a full igra (kad bude gotova tamo negde krajem iduce godine) bi trebalo da pruzi oko 15h gameplay-a. Inace igram na konfiguraciji iz potpisa (7800X3D i RTX 4090) i igra radi veoma glatko, bez ikakvih stutter-a (4K, DLSS quality, FG off, sve na ultra).
    455.2 KB · Pregleda: 42
    615.7 KB · Pregleda: 43
    560 KB · Pregleda: 44
    536.7 KB · Pregleda: 37
    490.1 KB · Pregleda: 36
    263.9 KB · Pregleda: 33
Pazi ako im dobro prodje prvenac, mozda zaposle jos ljudi i nastavak bude open world..
Mada me interesuje kako bi odrzali ovakav kvalitet prikaza sadrzaja uz dodatni kvantitet. Verovatno bi dosta generisanja radilo u tom slucaju.
Izgleda kao onaj demo unreal 5 kad je izasao 🙂 (Znam da je unreal engine 🙂) Dosta ljudi pljuju u fazonu "AI generated UE5 asset flip slop"
Ti isti ljudi ne mogu vise da provale polovinu jutjubera dal su realni ili fejk a kamo li digitalne stvarnost dal su AI slop ili ne.
Isuviše lako vecinu konzumera buni taj isti AI kome se poveravaju kao popu.
Ovo je bas tech demo, i kao i vecina EU5 igara ima microstutter. Nema podrsku za gamepad. Izgleda jako lepo, nije previse zahtevno ali ubi microstutter.
Nidje veze sa open world ovo nema, linearna igra. Nema cak ni animacije za penjanje uz merdevine.
Nekada su ovakve "igre" stizale uz nVidia graficke, da se proba novi tech.
ja ni u jednoj, pa ni u ovoj UE igri nemam nii M od microstuttera, da kucnem o drvo
Sad bas isprobao i da, ima stutera tu i tamo ali u mom slucaju bas malo. Daleko od neigrivog, i da se u ovom tehnickom stanju igra pusti, opet bi radila bolje nego 90 posto unreal engine naslova koji su krpljeni godinama. I ovo je sa par mesecima starim nv drajverima.
Na stranu izgled koji kida i po prvi put stvarno izgleda kao onaj prvi unreal 5 demo , sto neko pomenu gore, sistem borbe je odlican a i protivnici su dobri, mada sam na samom pocetku pa cu za vikend malo vise da se posvetim.
Svidja mi se sto ima elemanta Dark Mesaje i njegovog sistema upotrebe okoline i fizike da se resite protivnika.
Penjanje na stepenice i nedostatak animacije (za sada) mi nista ne smeta, narocito ako nije mehanika od koje ce biti nekih daljih interakcija. Popnes se na osmatračnicu sa koje ionako mozes samo da gledas - pa jos je bolje ato mi igra ne teavi vreme na pentranje.. Ovo je u stilu onih point and click avantura os pocetka 2000.
Takodje mi se svidja sto ima platformisanja. U sprezi sa onim sistemom i interakcijom okoline, ovo obecava samo po sebi interesantan gameplay.
Al da ne tupim previse za pola sata igre. Videcemo jos.
