Pa gde je onda tu dilema?Koja je razliku u kvalitetu izmedju ova dva video fajla? Skupljam 4K
multicorewareinc.com
If you create an OpenSubtitles account and configure it in MPC-HC settings then you may be able to bypass the quota.
Options > Subtitles > Misc > Right-click on OpenSubtitles.com > Setup > Fill in username/password
This requires using either MPC Video Renderer (MPCVR) or madVR.
These renderers can be selected here:
Options > Playback > Output
With other video renderers, the colors will be wrong!
MPCVR is now included and is the recommended renderer for modern systems. MadVR needs to be installed separately. MPCVR also supports Dolby Vision. MadVR does not.
For optimal performance you should change the hardware decoder to D3D11 in LAV Video Decoder settings when using MPCVR on Windows 10/11, because this renderer uses DirectX11.
Jel si ti pobrkao nešto? Od kad LG ne podržava HDR10? Jedino ako imaš neki baš matori TV, mada i to je pitanje. Bukvalno nema TV-a danas koji ne podržava HDR10.Ne podrzava LG HDR10, samo DV i HDR.
Media Player Classic - Home Cinema (MPC-HC) is a free and open-source video and audio player for Windows. It is famous and loved for its simple and effective user interface, providing an excellent user experience.
GitHub - clsid2/mpc-hc: Media Player Classic
Media Player Classic. Contribute to clsid2/mpc-hc development by creating an account on GitHub.github.com
Nova verzija izašla:
Release 2.6.2.1 · clsid2/mpc-hc
Changes from 2.6.1 to 2.6.2: Updates: Updated LAV Filters to version 0.81-5-g5aa4b Updated MediaInfo DLL to version 26.01 Fixes: Several small fixes and improvements.github.com
Dodatna podešavanja:
Titlovi:
HDR:
Koja setovanja si stavio za MPCVR, jer kada pokušavam preko njega ne mogu da dobijem HDR na TV-u...Nije mi povezan TV niti gledam tako video sadržaj - nije zgodno jer ima boljih alternativa 🙂
A i ne može nikako da bude perfektno jer ne podržava Dolby Vision, za HDR10+ nisam siguran...
MPC Video Renderer (MPCVR) ne mora da se skida dodatno i podržava DV, za PC i više nego dovoljno.
U mom slučaju nije stvar u MPC-HC već je u madVR renderu gde kažem da je slika fantastična za 4K HDR materijal i filmove koje gledam, a PC je povezan na TV sa HDMI 2.1 optičkim kablom.Zar nije lakše koristiti Plex recimo? Šta su prednosti MPC-HC?
Ona koja gore pišu, ništa više od toga 🙂Koja setovanja si stavio za MPCVR, jer kada pokušavam preko njega ne mogu da dobijem HDR na TV-u...
