Mozilla Firefox [FAQ u II postu]
Jel moguce nekako zoom korake promeniti da ne idu za 10 jedinica neko po jedna? Od danasnje promene foruma na 100% zoom mi je nekako sitno a kad stavim sledeci korak 110% previse mi krupno, mozda bi bilo idealno 105% ali nemam opciju.
Posetiš about:config i tamo pronađeš toolkit.zoomManager.zoomValues kome posle "1" dodaš "1.05".
Ili ako ti je lakše zameniš ceo string mojim: 0.3,0.5,0.67,0.8,0.9,1,1.05,1.1,1.15,1.2,1.25,1.33,1.5,1.7,2,2.4,3
Sa njim ćeš imati tj. dobiti 105%, 115% i 120% 🙂
Savrseno, hvala
Да ли има неки АД Блокер за 115.30.0 ЕСР ?
На лаптоп-у је виндос 7.
Bolje da ukinu za Windows 8/8.1 ionako taj Windows niko ne koristi.
Ja koristim Instapaper u besplatnom modu, meni dovoljno za sada.
Evo posle vise od godinu dana meni Instapaper poceo da trazi premijum rolu da bih pretrazivao text, što je do sada moglo i free. Da li je neko našao neku pristojnu free zamenu dostojnu nekadašnjieg Pocket-a?
More reasons to love Firefox: What’s new now, and what’s coming soon
A free built-in VPN is coming to Firefox. Free VPNs can sometimes mean sketchy arrangements that end up compromising your privacy, but ours is built from our data principles and commitment to be the world’s most trusted browser. It routes your browser traffic through a proxy to hide your IP address and location while you browse, giving you stronger privacy and protection online with no extra downloads. Users will have 50 gigabytes of data monthly in the U.S., France, Germany and U.K. to start. Available in Firefox 149 starting March 24.
Видели од опере и вивалдија.
Zanimljiv novi feature na 149, tab split view.
Plus free VPN sa 50gb/month.
    132.9 KB · Pregleda: 46
Ko nema VPN opciju
https://support.mozilla.org/en-US/questions/1577928#answer-1813239
in about:config a search bar comes up, type in browser.ipprotection.enabled if it says false then you should be able to push the button all the way on the right to set it to true.
Nema izbora servera, to je što je (Fastly, Minhen). Ali 50GB je solidna količina za browser kome treba samo da ne bude kod kuće. Dobro je što može da se uključi/isključi po sajtu
Firefox zadnjih sedmica crashuje praktično pri otvaranju. Pošto je mašina poprilično stara (1x 8GB DDR3) da li ima neko podešavanje u Settings ili about: config da se smanji potrošnja resursa kompa? Naravno, u slučaju da je do RAM-a.
Ili preuzeti ESR verziju?
W10 solidno debloatovan.
Nije pravio probleme do unazad par updateova pa mi pada na pamet da nije nešto pojačano što optereti RAM.
Edge i Brave za sada nemaju tih problema, mada sam testirao samo sa 2-3 otvorena taba. Kod Firefoxa se desi crash, monitor najšešće blinkne i izgubi se night light.
Ponekad je znao da se resetuje scale & layout displeja.
Ako bude isto i sa novim profilom, ažuriraj ili odradi clean install drajvera grafičke (DDU).
To što si opisao deluje na reset istog, tj. postoji bug ili u njemu ili interakciji FF-a sa njim, što izaziva crash i reset drajvera.
Hvala ljudi na predlozima.
Profil je sigurno default jer nisam nikad kreirao nijedan poseban.
Postoji brdo bukmarkova i bookmarks toolbar je pozamašan.
Ali sve to je odlično funkcionisalo do nekih 4-5 sedmica unazad, imajući u vidu specifikacije računara. Grafička je GTX 750 Ti 2GB a procesor I5 3470.
Ovako laički bih rekao da se počelo dešavati nakon nekog od zadnjih ažuriranja.
Mogu da importujem sve bukmarkove i ekstenzije u novi profil? Da li može biti do njih mada ih imam svega nekoliko i nove nisu dodavane odavno: ublock origin, umatrix, dark reader, keepa i user agent switcher.
Naravno.
Ako koristiš FF Sync, uloguj se sa novog profila i sam će odraditi/povući sve. U suprotnom - ručno (no otom potom, ako uopšte bude potrebe).
Ne bi trebalo. Jedino za Dark Reader postoje šanse u promilima, mada ne verujem. Svakako ne košta ništa da probaš da ga isključiš/disable-uješ pa vidiš.
A možeš i sveobuhvatno probati iz about:profiles -> Restart with Add-ons disabled.
Ako ne pomogne, svrati opet u about:profiles, otvori "Root" direktorijum, idi "up" nivo, zatvori FF, sačekaj par sekundi pa bekapuj dir profila (xyzyxz.default). Kod mene na Linuksu je putanja:
/home/filip/.mozilla/firefox/4k665v0h.default --> copy-pasta 4k665v0h.default folder i installs/profiles.ini fajlove.
Onda napravi nov profil sa about:profiles stranice, ili pokreni FF profile manager iz Start -> Run sa firefox.exe -P pa utvrdi da li je problem nestao.
Ako nije, ažuriraj ili odradi clean install grafičkog drajvera. Ako reši stvar, vrati se na stari profil i to ti je to. Ako u njemu opet krene da zeza, onda ili sync-uj podatke u nov, ili piši za objašnjenje kako ručno da ih preseliš....
Na Firefox 150.0.1 na i5 13 generacija i5 1335U 16GB rama i najnoviji driveri za graficku tik tok neki video klipovi koce na Firefox a na Chrome ne jel se to jos nekom desava?
