Vivo X300 Series
ProdigyFreak
CPU & Cooler
Ryzen 7 5700x3d / Thermalright AXP120-X67
Matična ploča
ROG STRIX B550-I GAMING
RAM
Kingston HyperX 3466 @ 3600
GPU
PowerColor Reaper RX 9070 XT
PSU
650W SFX-L 80Plus Gold Fully Modular
Kućište
NZXT H1 (v1)
Mobilni telefon
Realme GT 8 Pro
Pristup internetu
  1. Optički internet
Za par meseci tačnije na jesen izlazi X300 serija a roumor mill uveliko melje
Izgleda da će Ultra opet pomerati granice fotografije
Naravno uz novi SoC, baterije još većeg kapaciteta...
Rano je za ultru, sve su ovo nagadjanja, ko zna sta ce biti na kraju. Meni se najvise svidja sto je glavna 35mm, jos kad bi ostali presli na 35mm bilo bi odlicno.
Dva 1in senzora na uw i main i 1/1.28 na zoom i ja ga prvi kupujem. Broj Mpx me apsolutno ne zanima.
Pa nije nerealno, kakav gas su dodali Kinezi, za 2-3 godine će svaki chi Ultra flagship imati po 3 velika senzora pozadi, i mozda jedan manji 1/2'' za 6x ili 8x telefoto modul. A sve to u kombinaciji sa brutalnim čipsetom i 7500 mAh.
Ovo postaje sve bolje!!...još da je compact - compact, a ne cigla od 6.3 i više inča gde bi nam kraj sreći
FuntouchOS merging with OriginOS for Vivo and iQOO devices news is FAKE!
OriginOS is China exclusive UI developed by BBK for Vivo and iQOO and is thousand times better than FuntouchOS which BBK offers to Global Vivo and iQOO users.
A telegram group today spread the news that BBK has decided to merge FuntouchOS with OriginOS for global users. Many famous tipsters & channels claimed that the "news is real" as their "sources" also said the same and they knew about it already.
However, in reality, FuntouchOS will get only some of the features of OriginOS, a new UI overhaul and that's it. BBK may also rename FuntouchOS to hype up the upgrade for global users, similar to how Xiaomi fooled everyone with HyperOS being different from MIUI.
The sequel to the vivo X200 Pro will keep the same overall dimensions and design, but will bring a faster chipset and a bigger battery.
The X300 Pro is said to have a flat 6.8” display with “1.5K” resolution (possibly the same as on the X200 Pro, 1,260 x 2,800px).
Inside will be a Dimensity 9500 chipset, which has leaked extensively. It will use ARM’s new X930 (“Travis”) core clocked at 3.23GHz (the focus is on efficiency with this generation) and a new “Immortalis-Drage” GPU.
The vivo X300 Pro will have a large 7,000mAh battery, according to this leak. That’s 1,000mAh more than the X200 Pro has and 1,600mAh more than the X100 Pro had. There’s no word on charge speeds, but vivo might have to bump up the 90W wired and 30W wireless support of the current Pro to keep up with the increased capacity.
As we talked about yesterday, the 50MP main camera will use the latest Sony LYT-828 (1/1.28”) sensor. It will be joined by a 200MP periscope (1/1.4” sensor) and a 50MP ultra-wide. ZEISS has apparently cooked up a new lens coating that will improve image clarity, but the leaked renders just have the “T*” label.
The X200 series was unveiled in October and we expect the X300 series to arrive in the same time frame. By the way, check out the camera specs for the vanilla vivo X300 (or possibly the X300 Pro mini) here.
sad kad kazu da obican x300 menja mini ali sa zakrivljenim ekranom.. a ja cekam
spongebob squarepants GIF
Deluje da su smanjili ivice oko ekrana što je odlično. Nadam se da će da ubace UW selfie
E sad, na slici 7200mah, a u propratnom tekstu 6375
Za sada sve deluje zanimljivo. 🙂 samo još da vidimo šta znači R-angle ravan ekran
Sve što nije 1in senzor preskačem. 😁
Pa x200u ima "ultra" u nazivu pa sam preskočio. 😁
Translated: Recently, I talked about the vivo X300 and X300 Pro, nicknamed the “Dual 200MP, Imaging Little Kings”. Some asked why vivo invests so heavily in imaging. The point isn’t just to chase numbers, but to make sure that every focal length has at least a 50MP-level hard power. That’s what makes it real — that’s what proper imaging upgrades look like.
Besides the dual 200MP, the X300 series has some serious hardware:
1. ⁠X300
Main camera: upgraded to 200MP, but the highlight is the first standard edition with a 50MP periscope telephoto.
Uses a custom Sony LYT-602 sensor with Zeiss T* coating. Telephoto shots are clear and stable with low distortion, and it even supports tele-macro and portrait bokeh.
2. X300 Pro
Main: upgraded to the world’s first co-developed Sony LYT-828 Gimbal Main Camera.
50MP, 1/1.28" large sensor, f/1.57 aperture, advanced stabilization up to CIPA 5.5.
Features: 22nm low-power process, video recording power efficiency, Hybrid Frame-HDR with 100dB dynamic range, excellent low-light performance, Zeiss T* coating, VCS spectrum technology for natural colors.
3. Front Camera
Both models feature a 50MP AF front camera (92° FOV). Supports autofocus for selfies and video, with sharp detail and accurate focus. Perfect for vloggers — no compromise on the front camera.
In short:
X300: 50MP periscope APO tele + 200MP main
X300 Pro: 50MP LYT-828 gimbal main + 200MP tele
Across the lineup: every focal length gets a true high-end 50MP setup
This isn’t about hype — the vivo X300 series brings hardcore, all-round imaging strength to mobile photography.
mislim da sad znamo sve o kamerama, još da vidimo kakve su 🙂
AF na prednjoj na oba modela 🎉
    607.9 KB · Pregleda: 49
Doživeo sam i to da sa nestrpljenjem čekam objave vezane za neki kineski telefon 😬😶‍🌫️
Još samo da u slikaju ekran sa prednje strane pa da krene da se steka lova.
Punjene ostaje isto.
Yesterday we talked about the all-focus imaging system of the #vivoX300Series. Today, let’s dive into its “extreme narrow quad-edge” design and “visual ace” eye-care screen!
Design Highlights:
vivo’s narrowest bezels ever, using LIPO tech with significantly slimmer quad edges (exact numbers to be revealed later).
Paired with smooth round R-corners for immersive full-screen visuals and a comfortable in-hand feel.
Display Experience:
X300 entire series uses BOE’s Q10 Plus luminous material, with deep customization for higher brightness, lower power consumption, and more accurate colors.
Delivers lifelike detail reproduction in high-res photos.
With vivo & Zeiss Master Color tuning, colors remain true and natural whether you’re watching videos or using the phone outdoors.
Eye-Care Technology:
First to feature 2160Hz high-frequency PWM dimming + full-brightness DC dimming dual solution.
At full brightness, it defaults to DC dimming; both options greatly reduce eye strain and fatigue.
Combined with the upgraded OriginOS 6, vivo introduces “Smart Eye Protection” for all-weather, all-scenario, all-people comfort.
izostavio je ono najbitnije 😆
    208.6 KB · Pregleda: 55
    75.6 KB · Pregleda: 52
Da li ovo znači da se ide na ravan ekran? 🙂
Za sada ubedljivo najveća mana x200 pro, naravno uz šporet od kamere pozadi.
Pa tako bi i ja rekao sa slika...a mislim da sam i još negde pročitao vest.
