omašio si temu![]()
Owner Highlights Singed Connector on MSI's Yellow-tipped "Safety-oriented" 12V-2x6 Connector
Earlier in the year, MSI started to showcase a simple yet innovative safety measure—involving the heavily debated 12V-2x6 connection standard. In a completely serious April 1 social media post, the brand's gaming division refreshed its audience's collective mind: "did you know? MSI graphics cards...www.techpowerup.com
Mozda, mada ipak misli da svaki info treba ovde da se podeli.
Ne znam po kojoj racunici je 5060 Ti 16GB bolji perf/$ od 4060 Ti 16GB kad je ova druga imala osetno manji msrp. To sto su u ovoj tabeli lupili cenu od 450e za prvu, odnosno 500e samo cini da tabela jos manje ima smisla.
Da je 5060Ti 8GB 250$ a 5060Ti 16GB 300$ onda da, nema razloga da se ne doplati, ovako jok50eur doplata je razumno i tu ko kupuje nema sta da se misli i da skrtari
Of course, the argument will again be that you can turn down the texture quality. Yes, of course that's possible, but there are limits here too. In Indiana Jones and the Great Circle, for example, the RTX 5060 Ti with 8 GB only runs properly at the lowest texture setting – and that doesn't look good anymore. And in other games, too, it's usually not enough to reduce the texture switch by one level. It usually has to be several levels, which is quickly apparent on the screen. But for 400 euros, that's simply a no-go.50eur doplata je razumno i tu ko kupuje nema sta da se misli i da skrtari, a sto se tice testa napomenuto je da su podesavanja za 16GB karte primenjene na 8GB karti... doticne igre sve bi radile odlicno i 8GB ali bi se prilagodile, smanjile bi texture i podesavanja na default profilu za istu..... naravno test je uradjen da bi pokazao kako se 8GB karta moze preopteretiti i da neke igre traze 16GB rama na odredjenim podesavanjima i da pokazu razliku od odnosu 8 na 16G kad se taj scenario desi
Koliko ti mlatis po ovom forumu, to je smesno.Graficke karte zavise od cene novog rama, proizvodnog procesa, tsmc 4nm jeste mator proces, gddr7 je skupa koliko je gddr6 jeftinija mi to ne znamo, po svemu sudeci 16GB gddr7 NV kosta manje od 100$ to se moze izvuci i razlike u ceni a koliko manje je pitanje
Kapaciteti tsmc isto nisu poznati, zato i ne vidis jaku AMD kartu u ovom segmentu, svakako da ce svako ici na AI koji je buducnost 😉 nerealno je ocekivat da iko ko moze da ponudi karte za AI targetuje gamere sad sa niskim cenama
Realno meni bi samo zbog AI trebale sto slabije karte sa 16G+ ali samo NV jer je cuda daleko ispred svega ostalog po lakoci programiranja...
Anyway evo jos nezvaničnih info o Super verzijama... a posebno preporučujem drugu polovinu videa o generalnoj stabilnosti AMD vs NVidia...2007 - 8800GT 512MB - $350
2015 - R9 390X 8GB - $430 (in 8 years from 512MB to 8GB)
2017 - gtx1070 8GB - $380
2019 - 2060 S. 8GB - $400
2021 - 3060ti 8GB - $400
2023 - 4060ti 8GB - $400 (8 years later still 8GB for ~$400)
Jel nam otvorenam tema nama kojima je 8GB u 2025. smesno?
Bice zbog buildova koje ljudi kupuju po radnjama i marketima a ne znaju nista ili vrlo malo o racunarima.opet ce biti medju top10 kartica na steamu 🙂
Prodace ih u prebuilt masinama zajedno sa ostalim neprodatim hardverom.***a new reality, 400 im je dno 🙂
niko nas ne tera da kupujemo, neka trunu u magacinima, pa ce propasti (not)
