Ne, nema ga nije kao neke od funkcija koje traže samo aktivaciju.Da li posle ostaje u SRB, ili ga nema? Odnosno, da li se prvim odlaskom preko "aktivira", ili je aktivno samo preko?
Hvala na odgovoru btw.
Photos
- New filters to show or hide items that are not contained in an album, or synced from a Mac or PC, in the Library view in Photos
- Reorder items in the Media Types and Utilities collections in Photos
- Consistent filtering options in all collections, including the ability to sort by oldest or newest first in Photos
- Option to sort albums by Date Modified in Photos
- Ability to disable "Recently Viewed" and "Recently Shared" collections in Photos Settings
- Hidden photos are no longer included for import to Mac or a PC if Use Face ID is enabled in Photos settings
This update also includes the following enhancements and bug fixes:
- Safari recent search suggestions help you quickly get back to previous search topics when starting a new query
- Setup Assistant streamlines steps parents need to take to create a Child Account for a kid in their family, and enables child-appropriate default settings if parents prefer to complete setting up a Child Account later
- Screen Time App Limits persist even after a child uninstalls and reinstalls an app
- App Store includes summaries for user reviews so you can get helpful insights from other users at a glance
- Pause and resume of an app download or update on App Store without losing progress
- New widgets for Podcasts including a Followed Shows widget to track your favorite shows and a Library widget to get to your most used sections, such as Latest Episodes, Saved, and Downloaded
- Ambient Music offers the ability to instantly play music from Control Center, giving access to a set of hand-curated playlists that offer soundtracks for daily life
- Apple Fitness+ Collections can now be added to Library
- Matter-compatible robot vacuum cleaners can be controlled in the Home app as well as be added to scenes and automations
- Support for 10 new system languages including Bangla, Gujarati, Kannada, Malayalam, Marathi, Odia, Punjabi, Tamil, Telugu, and Urdu
Apple Vision Pro App
- The new Apple Vision Pro app, automatically installed for users with Apple Vision Pro, helps you discover new content, spatial experiences, and quickly access information about your device
Apple News+
- Recipes from some of the world's best recipe publishers are now available on Apple News+
- Recipe Catalog allows you to browse or search to find the perfect dish and save it to your Saved Recipes
- Cooking mode lets you easily follow step-by-step directions
- The Food section also includes stories about restaurants, kitchen tips, healthy eating, and more
				 www.macrumors.com
					www.macrumors.com
Nema nijednog odgovora koliko je korisnoDa li neko od vas koristi Apple Intelligence i na koji način mu olakšava život? Kad su ga najavili, očekivao sam nešto u rangu ChatGPT-a (kojeg svakodnevno koristim), a ispalo je nešto totalno beskorisno, bar za mene.
Totalno beskorisno, nema apsolutno nikakvu funkciju niti radi kako bi trebalo. Siri nikako ne vodi konverzaciju kada ga pitaš neke proste stvari pa se nadovežeš potpitanjem.Nema nijednog odgovora koliko je korisno
Ugasi ai ili always on display pa probaj tako, ja imao sličnih problemaiPhone 16
Sinoć sam ažurirao na verziju 18.4 (prešao sa 18.3.2 gde je sve radilo savršeno) i od jutros notifikacije na zaključanom ekranu više ne rade kako treba. Animacija užasno secka kad skrolujem. Da li još neko ima sličan problem?
AI ugasen a AOD nemam jer je obicna 16Ugasi ai ili always on display pa probaj tako, ja imao sličnih problema
Jesam, opet ništa. Skoro sam kupio novu 16. Baš sam se razočarao u Apple. Ne znam šta im se desilo, da iOS bude ovoliko bagovit. Nikada nije bilo ovako.Probaj force restart, možda se još indeksiraju fajlovi. Ali ova 18 je užas blagi stalno neko stucanje bagovi
Ako ga force restart, da li se indeksiranje prekida ili nastavlja?
Daću mu još dva dana da indeksira, posle toga ko živ, ko mrtav😂Nastavlja se, a za bagovitost ne znam šta da ti kažem, 14 Pro i 18.3 verzija radi kao podmazan 😃
Osim najbagovitije tastature koju nikako da isprave 😁
Napravi backup, erase all content and settings, instaliraj sistem ponovo i vidi da li baguje, praktično clean restore. Ako radi ok, vrati backup i uporedi 😃
