Kupovina laptopa u 2023 - opšta tema [za konkretne preporuke je podforum "Šta da kupim"]
^ postoji samo zavisi koliko hoćeš hardverski jak laptop i za čega ćeš ga koristiti. Iskreno nov ili polovan za 700-800€ sa 13650hx nećeš naći.
Za dat novac koliko može hardverski jak toliko 😁
Koristiću za surf, filmove, malo photoshop i to je to, kućna upotreba. Ne planiram da igram igre. Bitno mi je da je ekran 15 16 inca.
^ Onda nađeš koji ti cenovno najviše odgovara
0:18 1. Warranty - Do Upgrades Void Warranty?
0:56 2. How To Open Your Gaming Laptop
1:15 2.1 Watch Out For This Annoying Stuff
1:35 2.2 Important - Track Your Screws!
1:49 2.3 Which Screwdriver Bits You Need
2:17 2.4 Using Pry Tools to Open Laptop
2:38 2.5 More Silly Stuff to be Aware of…
3:03 2.6 Putting Laptop Back Together
3:07 2.7 Laptop Not Powering on After Opening?
3:15 3. Identifying Internal Components
3:22 4. Battery - You MUST Do This Before Other Upgrades
3:45 4.1 How to Unplug Battery
4:05 4.2 Can You Upgrade Your Battery?
4:57 4.3 How to Upgrade Battery
5:07 4.4 Battery Upgrade Results
5:19 4.5 Swap Degraded Battery for New Battery
5:33 4.6 How to Identify Battery Model & Buy New
5:43 4.7 Removable Batteries
6:05 5. Storage Upgrades
6:15 5.1 M.2 Slots - How Many do you Have?
6:51 5.2 M.2 Drive Sizes
7:12 5.3 Make Sure Bigger Drives Fit Your Laptop!
8:20 5.4 SSD Coolers
8:36 5.5 PCIe or SATA for M.2 SSD?
9:06 5.6 M.2 Socket Key Differences
9:55 5.7 SATA/PCIe Gen 3, 4 & 5 Speed Differences
10:27 5.8 Can You Upgrade the PCIe Version?
10:46 5.9 Gen 4 Doesn’t Always = Faster Than Gen 3
11:09 5.10 Backwards Compatibility
11:27 5.11 Everything to Consider When Picking a New SSD
11:59 5.12 How Much Disk Space to Choose?
12:30 5.13 How to Install M.2 SSD
13:10 5.14 Clone Existing OS, or Reinstall Fresh?
13:32 5.15 Important - Beware of Automatic Bitlocker Encryption!
15:00 5.16 2.5” Drives, SSD or HDD?
15:32 5.17 How to Install 2.5” Drive
15:45 6. Memory (RAM) Upgrades
15:47 6.1 How Many RAM Sticks Does Your Laptop Support?
16:18 6.2 How Much RAM Capacity is Enough?
18:04 6.3 DDR4 or DDR5 Memory?
19:17 6.4 Memory Speed Depends on Your Processor
20:30 6.5 Important - Why to Use 2 memory Sticks
21:11 6.6 Memory Banks, Ranks & Timings
21:57 6.7 Why Choosing RAM is Hard
22:20 6.8 Everything to Consider When Picking New RAM
22:38 6.9 Ideally Use Same Memory Stick Capacity
23:07 6.10 How to Change RAM Sticks
23:33 7. Wi-Fi & Ethernet Upgrades
23:49 7.1 Fast Wi-Fi is Relatively Cheap
23:58 7.2 How to Check Current Wi-Fi Version
24:09 7.3 Which Wi-Fi Version to Upgrade to?
24:47 7.4 Wi-Fi Card in its Natural Habitat
24:56 7.5 Which Wi-Fi Card Types Fit in Your Laptop? Understanding M.2 Keys
25:47 7.6 Watch Out For Intel’s Proprietary CNVio!
26:52 7.7 Why AMD Laptops Don’t Use Intel Wi-Fi, But you can Upgrade to it
27:25 7.8 Wi-Fi Speed Differences - Why Intel is Recommended
27:52 7.9 Best Wi-Fi Card for Most People?
28:11 7.10 Windows 10 Users Need More Work for Wi-Fi 6E
28:21 7.11 Limited Wi-Fi 7 Options (For Now)
28:39 7.12 How to Change Wi-Fi Card
29:00 7.13 Install New Drivers - Download a Copy Before Upgrade
29:53 7.14 Soldered Wi-Fi? Try This
30:28 7.15 Ethernet Upgrade?
30:41 8. Cooling Upgrades - Why Heat = Bad
31:03 8.1 Why Most Laptop Thermal Paste is Bad
31:42 8.2 How Often to Change Paste?
32:31 8.3 Important - Liquid Metal - Watch Out!
33:45 8.4 Which Thermal Paste to Use?
34:08 8.5 How to Remove Cooler
34:36 8.6 Cleaning Off Old Paste Residue
35:07 8.7 Applying New Thermal Paste
35:31 8.8 Jarrod Rants at Years of Thermal Paste Comments
36:02 8.9 Honeywell PTM 7950 Application
36:08 8.10 Thicker VRM Paste, I Replace With Thermal Pads
36:21 8.11 Putting Cooler Back 36:40 8.12 Temperature Differences
37:01 8.13 Cooling Pads & Stands - An Easier Alternative
37:40 8.14 Liquid Cooling Upgrades 💦
38:06 9. Screen Upgrades
39:30 9.1 A Better Alternative
39:55 10. CPU & GPU Upgrades
40:05 10.1 Why Most Laptops Don’t Support This Upgrade
40:44 10.2 Laptops With Upgradeable CPU or GPU, & Why They Aren’t Great
41:18 10.3 Is This The Future of Upgradeable Laptop CPUs & GPUs?
41:36 10.4 Secret Stuff Coming Soon…
41:53 10.5 Thunderbolt External Graphics (eGPU) “Upgrade”?
42:42 10.6 Thunderbolt 5 Might Change Things Soon
Pravi ubedljivo najbolji sadržaj na YT u vezi laptopova!
Ovog gospodina molim te nemoj šerovati na bilo kojem forumu. 🙏 Simpatičan čikica, jedino je problem što čovek pojma nema šta je TSMC. Ne sprdam se, gledao sam bio neki live stream gde se obrukao nizom komentara. Bukvalno kopira sve što drugi rade a vrlo malo o svemu tome zna. Žao mi je hiljada i hiljada ljudi koji su poslušali njegove savete šta da kupe. U-žas.
Reci mi da si korisnik Apple proizvoda bez da mi kažeš da si korisnik Apple proizvoda. :)
Svi su oni manje više površni, čak on kupuje većinu hardvera za koju radi recenzije.
Samo da javim, kupio sam ovaj vivobook 15 oled. Laptop je perfektan, oled ekran stvarno izgleda fantasticno uzivo.
Jedina zamerka je to sto ima probleme sa wifi, slabo hvata signal. U sebi ima wifi cip mediatek mt7921 koji je katastrofa, citajuci po reditu video sam da ga svi menjaju. Problem resen zamenom pomenutog cipa sa Intelovim ax210 wifi 6e .
Da li mislite da vredi platiti ovaj laptop 1000 eura?
Lenovo X13 GEN3
Cpu I7 1260P,
Ram 32GB,
Ssd 1TB,
Grafika IRIS Xe
Laptop ima samo 60 radnih dana, besprekoran je u svakom smislu...
Mislim da je ok cena. 13" thinkpad modeli od 10gen intel procesora imaju uglavnom zalemljen RAM. Sa 32gb ces biti miran naredne 3-4 godine.
Lenovo ima worldwide garanciju preko serijskog broja. Relativno je nov model, tako da bi trebalo da bude 3god u garanciji
mislim da je 5 godina garancija.... u svakom slucaju vredi hiljadarku :) Hvala na odgovoru
@RanGo kontam super spravica za te novce...i ja gledam nešto na taj fazon za firmu da nam uzmem par komada (bukvalno taj model gledao, samo što je kod nas 135k sa 32gb ddr5). Ne vidim što bi išao na stariji čipset koji se više greje i više troši?
Nešto čitam oko za Snapdragon... kakvi su oni za svakodnevni Office/Internet rad u odnosu na recimo Intel i5 ili Ryzen 5, 6/12core, što je neki prosek po snazi?
Lenovo gaming 3 16IAH7 wuxga ips 165hz, za ovih godinu dana se pokazao bez greske, hladjenje I panel za te novce su anblvbl
Za te stvari ce mahom biti ok, mislim da bi pucali sebi u nogu kada bi taj neki baseline bio neoperativan.
Ono sto ce biti izazov za Snapdragon (kao i ARM procesore generalno) ce biti optimizacija softvera jer ARM radi na potpuno drugom setu instrukcija nego Intelovi procesori.
Ono sto ce biti pitanje su igre, aplikativni softver (sto za razvoj sto za creative profesionalce), mrezni protokoli, lokalni protokoli etc.
Word ce da radi npr, al kako ce ti kompajlirati kod, renderovati modele, to je pitanje.
Treba mi mišljenje vezano za sledeći laptop: ASUS Vivobook 15 OLED X1505.
Intel Core i5-13500H, 16GB (8GB DDR4 on board + 8GB DDR4 SO-DIMM), 15.6-inch 2.8K (2880 x 1620) OLED 16:9 aspect ratio, OLED / 120hz / 100% DCI-P3 / 600nits HDR peak brightness
PANTONE Validated, 512GB M.2 NVMe PCIe 4.0 SSD, Intel Iris Xᵉ Graphics, Osvetljena tastatura i još raznih nekih marketinških trikova koje neću ni pominjati.
Trenutna cena 66k, i plus preko jetela kupon 5k, znači u zbiru 61k za ovu mašinu. Ja bolju ponudu ne nadjoh, ali me zanima i vaše mišljenje.
Znam da će cpu da se greje, znam da će baterija da traje kratko jer ipak je na 45w, ali s obzirom da ce sigurno 90% vremena laptop provesti u stanu (a to znaci i na utičnici) to nece biti neki deal breaker. Uvek sam pre za neki ozbiljniji procesor nego za one kosačice od po 10-15w (naravno tu ne računam apple M, oni su priča za sebe).
Eto voleo bih da čujem i tudje mišljenje pre nego naručim.
Sledeće nedelje treba da odlučim šta da uzmem u USA, pametan nisam. Ovi arm mi deluju primamljivo ali me nervira što ni jedan nema više od 16gb (tj ima ali je 2k dolara)! Nadam se da opet lenovo legion 7i bude na akciji ili čak yoga pro 9i pa da nemam muke i dalje oko izbora
I ja se vodim tom nekom logikom. Mada su mi stvarno lepi i yoga 7x i novi surface laptop. Sa druge strane imam HP spectre 360 2024 sa 2tb i 32gb za 1399$ npr...odličan ekran, zvuk, haptic touchpad itd. Žao mi što se nisam pre odlučio i kupio asus flow x16 sa 4060 dok se nije rasprodao u roku od dana za iste te novce.
Sad si me razočarao, ja sam mislio da ćeš pazariti nešto egzotično što ovde niko nema pa da iz prve ruke čujemo kako je a ti ziheraš ideš na sigurno...😂
@Martin Mystere vidi ako baš u ponedeljak bude neka super akcija za Lenovo yoga pro 9i lako se ovaj vrati i uzme pomenuti...al zarekao sam se da ću ga imati pre ili kasnije, mašina je izuzetna!!
