Poolmaker
Nenadmašan
Nakon instalacije windowsa umesto pojedinačne instalacije uslužnih programa mnogo je praktičnije instalirati ih odjednom. Jedno od rešenja za to je besplatni Ninite, a ima naravno i drugih (Chocolatey na primer).
ninite.com
www.howtogeek.com
Ninite - Install or Update Multiple Apps at Once
The easiest, fastest way to update or install software. Ninite downloads and installs programs automatically in the background.
Ninite Installs All Your Favorite Windows Programs at Once
If you are upgrading to Windows 7 from XP you will need to do a clean install, and installing your favorite apps again is time consuming and annoying.
