NightCrawler
Ja sam skoro počeo da je gledam od prve epizode.
Spremio sam full paket i one web epizode i filmove
Redosled:
Mini-Series (2 parts)
Season 1 (13 eps)
Season 2 (20 eps)
2.17 the Captain's Hand
Razor (movie)
Most fans agree it's better to watch Razor here. In doing so, you'll appreciate the story more and it will have greater emotionally resonance. In short: I highly recommend that you follow my advice and watch it here.
There is one small caveat, however: In order to deal with the above dialogue issue, and so not to unintentionally alter the tone of Season 3, I have two, very specific instructions that I recommend that you follow for your absolute optimum enjoyment.
I will try not to spoil anything with these instructions, so pay attention. You need to press MUTE on your TV (and/or turn off any subtitles) in the following two moments. Both of these moments occur in the last 10 minutes of the story, so you can relax and enjoy the first 90 mins before you need to worry.
Press MUTE when:
1. The hybrid touches Shaw. (You can unmute as soon as the hybrid lets go.)
and shortly afterwards:
2. When Red One contacts Pegasus. (You will literally hear the dialogue, "This is Red One come in" and see Pegasus respond -- mute before Red One can give their message to Pegasus.) You can unmute when you see Red One on your screen -- actually before that, but there's no other visual clue I can give you.
That's it! That's all you have to worry about. Two very small moments, and even if you don't unmute it, it's not a huge spoiler, it just unintentionally alters the tone of Season 3 if you don't, so do try your best to follow my instructions.
Razor Flashbacks (7 part web series)
2.18 Downloaded
The Resistance (10 part web series)
Season 3 (20 eps)
Season 4 (19 eps)
4.11 Sometimes a Great Nation
The Face of the Enemy (10 part web series)
4.12 A Disquiet Follows My Soul
4.15 No Exit
The Plan (movie) *
4.16 DeadLock
4.19 Daybreak (end of series)
Slazem se da je Battlestar Galactica jedna od najboljih serija. Preporucivao sam je mnogima u mom okruzenju. Ali vecina je odmahivala glavom da ne vole SF. 🤔 Eh da je to samo SF.Pogledao Galaktiku u poslednjih nedelju dana posle barem 10 godina.
Redosled gledanja kako je grupa "eksperta" (shmokljana) napisala.
Ima nelogicnih nebuloza npr. odakle im gravitacija na brodovima i tako neke sitnice, ali i pored toga, bez blama mogu da kazem da mi je najbolja serija ikada.
Cak i u cetvrtoj sezoni kada odu malo u dubiozu i dalje sve ima smisla.
Na kraju sve rupe zapushene, maltene sva pitanja odgovorena, prica zaokruzena i lepo ispricana od pocetka do kraja.
Poslednja scena carska.
Postavljaju se ozbiljna filozofska pitanja.
Ne bih da ih nabrajam sada da ne duzim i da ne kvarim nekome ko se zaje$&o i nije gledao.
Objektivna ocena 8.5-9/10.
Subjektivna ocena u odnosu na vecinu gluposti kojima smo trenutno okruzeni 12/10.
Jedino sto je malo smor u vezi serije je sto se bas vidi uticaj duvanskog lobija i mozda lobija alkoholnih pica.
Deluje da su oni to finansirali.
Osim toga, bombona.
160GB X265, znaci da su mali fajlovi, tj. da je npr. X264 ne bi bila 160GB, nego npr. 250-300 odokativno.sta ti to znaci, 160GB, sve u fulu?
Da nisi Sajlonac?Jos uvek mi je u glavi ona melodija
6 ok ali što i 8?Ako jesi, daj da se organizujemo da mi odshtancash par sestica i osmica![]()
8-ca je emotivna dusa. 😉6 ok ali što i 8?
Ima nelogicnih nebuloza npr. odakle im gravitacija na brodovima i tako neke sitnice, ...
Ja sam je gledao hronoloski kako je sve izlazilo. Tada nije bilo internet eksperata. 🤣Davno bese. Planiram da je repriziram. Jos uvek mi je u glavi ona melodija:
Tesko da ce neka sf/space serija nadmasiti Battlestar Galacticu i Babylon 5 (koju takodje preporucujem).
Posle prve sezone sam mislio da ce ih nadmasiti. Ali kasnijim sezonama ne. Dobar je The Expanse to necemo dovoditi u pitanje. Ali Battlestar Galacticu iako sam je gledao pre skoro 20 god. jos uvek imam onaj "osecaj".Expanse ih nadmasio
Bravo za ovu konstataciju, pitam se tokom svih ovih epizoda da li ja tripujem ili ona ima previse flegma nastup za ovakvu ulogu.Ahsoka delovala zanimljivo na pocetku posle su ga preterali.Još dve epizode cu pregurati,gotivim Dawsonovu ali njene blago opuštajuće izraze lica bez reakcije kao da leži u nekom spa centru konstantno kroz seriju su počele da me baš iritiraju .Borbe smrti ,akcije,bežanje od svega i svačega a ona kao na nekim drogama laganica blagi osmeh 😂
Ja sam posle užasno loše treće sezone odlucio da je više neću gledati. Bas je krenulo sa ozbiljnim preterivanjem, maltene nema ko skim nije, samo cekam kad ce vanzemaljci da se pojave i umesaju se svima u odnose.Au ljudi sta su napravili od poslednje sezone Sex Education, pa ovo je tragedija... Kvalitet je padao kako su isle sezone, ali da od simpaticne serije sa dobrim humoristickim scenama dodju do ovoga, bukvalno je gore od Euforije... Pri tome imas maestralnu Gilian koja je potpuno neiskoriscena i mogla je i da se ne pojavi...
Nije da sam imao neka velika ocekivanja, ali mislio sam ok bice bar zabava za jednu/dve veceri ali sem 2 scene gde sam umro od smeha sve ostalo je bas tuzno...
Jel kanal ili za nijansu losija? Komotno je necu gledati ako je baš krš dok ne izadje 7.Trend će da se promeni6. sezone je najslabija.
Slobodno odgledaj.Jel kanal ili za nijansu losija? Komotno je necu gledati ako je baš krš dok ne izadje 7.
Prva sezona odgledana pa napravljena pauza od dve godine mislim. Sinoć počnem drugu i malo je falilo da je ugasim još na prvoj epizodi. Mnogo naivnosti, apsurdnosti tako da uopšte nisam zadovoljan kako se sezona gradi. Ima taj Homicide - Život van posla koji se provlači što joj daje poseban šmek, ali i tako nekih ortodoksnih gluposti da sam baš na klackalici...Ja moram ponovo da podelim odusevljenje sa Line of Duty, posle 4 sezone i dalje se nastavlja trend da je svaka sezona bolja od prethodne. Serija izuva, subjektivne ocene do sada:
S1-7
S2-9
S3-9
S4-9.5
Sad 5 i 6 na redu
Da li se The Morning Show moze po kvalitetu uporediti sa The Newsroom?Prva sezona odgledana pa napravljena pauza od dve godine mislim. Sinoć počnem drugu i malo je falilo da je ugasim još na prvoj epizodi. Mnogo naivnosti, apsurdnosti tako da uopšte nisam zadovoljan kako se sezona gradi. Ima taj Homicide - Život van posla koji se provlači što joj daje poseban šmek, ali i tako nekih ortodoksnih gluposti da sam baš na klackalici...
Dear Child (2023)
Sinoć je završio, u pitanju je nemačka mini serija na ntflx i šta znam. Prve tri epizode su mi bile dosta razvučene bez ikakvih naznaka šta se tu zapravo događa, mislim da serija može biti jako zanimljiva i sa vrlo jasno postavljenim motivima na početku, a ovako mi delovala kao i svaka serija sa severa. Imalo je naravno brdo nelogičnosti, stvarno neverovatno da ne mogu neke alternative da se primene, mada bilo je tu i dobrih psiholoških momenata, nakon treće epizode kreće neka vožnjica do kraja. Konačni utisak je donja granica 7/10
@Shomi22
Uh, kakva serija, odnosno kakva prva sezona čistih 10/10, ali su jako podbacili sa drugom. Treću ću pogledati mada ne očekujem previše.
