Kapiraš da je razlika ~100 mega između teorije i ovde prikazane prakse? Kako je to onda "dobar rezultat, u praksi"?Taj disk ima teoretski transfer do 140 MB/s, tako da je rezultat, u praksi, dobar.
Damn, bio sam uveren da je to. Obicno i bude nesto tako banalno, da ne kazem kako je znalo bas ovo da mi se dogodi i onda glavolomke satima.Drajvere možemo odmah da eliminišemo, jer evo rezultata USB fleške Transcend JetFlash 790
www.howtogeek.com
Nema veze, a na 99% je zato što se koristi, sve je normalno.Pozdrav, da li ima veze koliko se ssd i m.2 i hdd puta pale i gase, za 9 meseci mi nvme 980 pro pao na 99%, pa zato pitam da li im skodi, jer sam u poslednje vreme poceo da ga gasim svaku noc. Inace taj nvme koristim samo za sistem i jedna igrica koju retko igram ima samo 20tb upisanih
Pitao je za više stvari odjednom. Za SSD nema veze, ali naravno da ima za HDD, jedna od najštetnijih stvari po zdravlje diska.Ali pitanje je za NVME.
none of these solutions work
- Check the drive letter: If the HDD is not showing up in File Explorer, it may be because the drive letter is not assigned. To fix this, right-click on the Start button, select Disk Management, and locate the HDD in the list. Right-click on the HDD and select "Change Drive Letter and Paths." Assign a drive letter to the HDD and see if it appears in File Explorer.
Dakle, preko usb docka kačim hddove na laptop. LC-DOCK-U3-HUB - HDD docking station
- Update the firmware on the HDD: Check the manufacturer's website for firmware updates for the specific HDD that is not being recognized. Install any available updates and see if the issue is resolved.
- Check the format of the HDD: Ensure that the HDD is formatted in a way that is compatible with your operating system. For example, if the HDD is formatted for Mac, it may not be recognized by a Windows computer. You can format the HDD by connecting it directly to your computer and using the Disk Management tool on Windows or Disk Utility on Mac.
