Na papiru sve lepo izgleda, podržava WiFi 5 standard. Praksa, bunar.
EuroDOCSIS 3.0 and EuroPacketCable 2.0 compliant, the EVW32C integrates 4 products into a single device: a cable modem, a residential gateway with a built-in...
www.speedguide.net
Delivers increased bandwidth for subscriber’s multimedia and high-bandwidth applications. DOCSIS 3.0: 24 downstream and 8 upstream channels provide speeds of up to 1029Mbps downstream and 246Mbps upstream. WiFi (802.11ac) : Support up to 300Mbps (2x2) @2.4GHz and 1300 Mbps (3x3) @ 5GHz...
www.ubeeinteractive.com
Kada hoću da se konektujem preko EON Connect aplikacije i optimizujem WiFi, izbaci mi grešku "Modem status is unknown". Ispod je digme "contact support", koje ne daje nikakav odziv (klasika). Hvala svima na pomoći i savetima, ne bih više da gušim temu. Živeću sa ovih max 150Mbps ili se vratiti na žicu.
