I ja sam na muci, ne mogu više da vučem lopate od 5" - 6,5". Sada imam Xiaomi Redmi 10 od 6,5" (službeni, poklonu se u zube ne gleda, sebi nisam kupio telefon poslednjih 6 godina), ali ne mogu više da ga svarim, gde god ga stavim smeta.
 Da se razumemo, nezahtevan sam korisnik, a i želim da prekinem da svaki čas drndam mobilni.
Ja sam za sebe rešio, iako je telefon realno loš, ali je 4"
https://www.cubot.net/Smartphones/KingKong-mini-2
Ima da se kupi kod nas na KP za 115-120€
Pored njega sam razmatrao i ove, ali nema da se kupe kod nas, niti ima free shipping ako sam dobro shvatio:
				Unihertz Atom L is the small rugged compact smartphone designed for outdoor adventures! With its durable design and advanced features, Unihertz Atom L is built to withstand even the toughest environments. Whether you're hiking, camping, or just exploring the outdoors, the IP68 rated protection...
					www.unihertz.com
				Unihertz Jelly 2 is the 3-inch palm sized mini compact smartphone that can fit in your coin pocket. Powered by Android 11 OS, Jelly 2 is tiny but fully functional to work well as common android smartphones to meet your daily needs. Order now!
					www.unihertz.com
				<b>Features</b><br>1. Small, only bank card size, but full function. <br>2. All under control by single hand, very suitable for our palm, makes you feel comfortable from all sides due to our high tech artwork and precise design. <br>3. Dual SIM with dual standby 2 card slots, even smaller phone...
					www.sunsky-online.com
Za svaki od gore navadenih imaš dosta testova i recenzija na netu, naročito na youtube,
