Sony Xperia 1 Mark III
hsv.stoned
- Audio Guru -
CPU & Cooler
AMD RYZEN 7 2700/LC-CC-120
Matična ploča
MSI B450 Tomahawk Max
RAM
Kingston HyperX Fury 32GB (2x16GB) DDR4 3200MHz (CL16)
GPU
Sapphire RX 580 Pulse 8GB @1440/2200 MHz
Storage
Kingston A2000 M.2 NVMe 500GB, Toshiba P300 3TB, WD Black 750GB, 2 x WD Blue 10EALX 1TB
Zvuk
FiiO K5 Pro + Beyerdynamic DT 900 Pro X/Fostex TR-90/Sennheiser HD650/AKG K240 Sextett/PreSonus HD7/ATH-CKX9/SFR DT6 | 2.1 50W + FiiO E10k
PSU
Cooler Master G550M
Kućište
Cooler Master Mystique 632s Black & Silver
Monitor
GIGABYTE G27Q & AOC i2481FXH
Miš & tastatura
Asus ROG Chakram wireless & ROG Strix Scope RX, Logitech MK320 wireless
Ostale periferije
Cube Reaction Pro
Mobilni telefon
Xiaomi 14 Ultra 16/512GB Black & Sony Xperia™ XZ2 Liquid Black
Pristup internetu
  1. Kablovski internet
  2. Mobilni internet
https://www.sony.com/electronics/smartphones/xperia-1m3
Sony debuts the Xperia 1 III and Xperia 5 III - first phones with variable telephoto lenses
Time for the big news. Sony has decided to be brave and incorporated a periscope zoom system in the Xperia 1 III and Xperia 5 III. Unlike other similar camera systems with fixed focus, this one features a variable telephoto lens. This means there’s an optical element that physically moves inside the camera system, switching between two focal lengths — 70mm and 105mm.
Za sada najveci utisak mi ostavljaju varijabilna telefoto kamera i baterija koja ima duzi zivotni vek od klasicne (konacno pocinje napredak na tom polju, Xiaomi i Sony su prvi)...
https://www.gsmarena.com/sony_xperia_1_iii-10712.php
https://www.gsmarena.com/sony_xperi...ced_with_revolutionary_cameras-news-48642.php
Dobra unapređenja funkcija svih kamera (posebno Eye AF i Real-time tracking) ali su morali bar malo da povećaju veličinu senzora glavne kamere.
Sve ostalo je top, u smislu multimedije itd. (osim prednje kamere, meni je to nebitno).
Totalno je nelogično da flagship model, sa takvim hardverom, ima bateriju istog kapaciteta kao 5 MK3 i 10 MK3. Olakšavajuća okolnost je to što površina displeja ne prelazi 100cm2, npr. OP 9 Pro ima za oko 10cm2 veću površinu displeja (niže rezolucije) uz isti kapacitet baterije i solidno se pokazao u smislu trajanja baterije, ali jednostavno nisu smeli da naprave 1 MK3 bez 5000 mAh baterije.
Ostaje još da se vidi kako će raditi 4K 120fps mod displeja (s obzirom na SD 888 limite), da li je neko varijabilno rešenje i na kom principu funkcioniše, i kako su rešili sistem hlađenja SD 888.
Detaljnije o kamerama: Sony’s Xperia 1 and 5 Mark III introduce first ever variable optical zoom (but that’s not what we’re excited about)
  • World´s first smartphone with a Variable telephoto lens paired with a Dual PD sensor
  • Real-time Eye AF for humans and animals, newly equipped Real-time Tracking and fast, accurate continuous AF across all lenses
  • 20fps Burst Mode with low light noise reduction powered by BIONZ X™
  • Brand new AI (artificial intelligence) super resolution zoom technology
  • Updated Photography Pro feature – now equipped with ‘Basic Mode’
  • World’s first smartphone with a 4K HDR 120Hz Refresh rate display crafted from Gorilla® Glass Victus™
  • Evolved Full-stage stereo speakers, 40 percent louder than previous model
  • Qualcomm®Snapdragon™ 888 5G Mobile Platform
  • Improved battery life (4500mAh) and the ability to charge up to 50% of capacity in 30 minutes with the kitted 30W charger - in addition to a newly extended battery life of up to three years
Na službenoj stranici Sony Rusija pojavile su se cijene za prednarudžbe:
Xperia 1 III oko 1.095 evra + na poklon WF-1000XM3 slušalice,
Xperia 5 III oko 930 evra + na poklon WF-XB700 TWS slušalice.
Dopada mi se frosted glass fazon na zadnjoj strani, specifikacije evolucija prošlogodišnjeg 1 mark II.
Da porade na marketingu, vrate se u par regiona za početak pa da vidimo za dalje.
Стварно импозантно, 3 телефона за сваког понешто. Овај пут видим да су додали бежично пуњење код "јединице" и једну камеру више, чиме су направили за нијансу јаснију разлику у односу на "петицу", осим упадљиво већег екрана који има од самог почетка. А баш ме занима како ће се показати ова нова варијабила телефото камера, пошто и ова на МК2 прави одличне фотке.
Што се тиче 10 МК3, такође одличан mid-range телефон - GG 6, IP65/68, стерео звучници и батерија од 4500 mah.
Можда је рано говорити али било би лепо када би се вратили на тржиште и да их видимо у скоријој будућности и код наших оператера.
Slična razlika kao i prošle godine, između 1 MK2 i 5 MK2, tu mislim i na bežično punjenje koje ima jedinica a nema petica, kao i TOF 3D senzor koji možda i nije toliko bitan ali za tu cenu serija 5 bi trebalo da ima bežično punjenje.
Na kraju će Xperia 5 i ove godine imati bar malo bolju autonomiju baterije u odnosu na Xperia 1, tako je već treću godinu zaredom.
10 MK3 nije loš telefon ali u toj cenovnoj klasi mora da ima Snapdragon 750G, kao Samsung A52 5G.
Sad gledam bench skorove, izgleda da SD 750G nije drastično brži čipset od SD 690, što po oznakama nikada ne bih pomislio. Verovatno postoje još neke prednosti 750G ali izgleda SD 690 nije spor kao što sam mislio.
https://www.androidworld.it/2021/04/14/sony-xperia-1-iii-uscita-745003/
24mm/real-time tracking
16mm UW sample
24mm wide
70mm telephoto
105mm telephoto
Htjedoh ovo okačiti zbog bitne informacije, tj da 120hz radi i na 4K ali ažurni ste svakako 😉
Aaahahaaha. HSV svaki put, ali svaki, malo iskritikuje što nisu stavili veći senzor i veću bateriju 😀 , eto da ne bude da je savršen telefon (mada i mogli su ako ćemo cjepidlačiti), ali ok, Mislim da Sony ide u pravcu koji smo dugo priželjkivali...
Са 4к, 120hz, 4500 mah батеријом и бежичним пуњењем, новом телефото камером коју још треба видети, тренутно комплетан телефон. Са моје стране више бих волео да је мало мањи пошто је 165мм мало превише, али ваљда је то један од начина да направе дистинкцију између њега и 5 Мк3.
Оно на чему би Сони требао да поради мало јесу апликације у домаћој радиности када су већ овако одлучно кренули са телефонима.
Rus iz klipa iznad navodi ovo:
  • 4k 120 Hz at the same time
  • no vibration from the speaker
  • display is a little brighter
  • front camera is much better then 1 II, Video too
  • auto focus is great on all sensor
  • Video stabilisation/ steady shot is better, and much more natural, no artifacts
  • smooth zoom in video
  • real time tracking works on all sensors
  • 105 mm give great bokeh
  • colors and auto focus much more like real camera
  • Google assistant button can be revamped to any app
Nativna rezolucija displeja je 1644 x 3840p, što SD 888 navodno ne podržava @120Hz (samo @60Hz), tako da ostaje da se vidi kako su to rešili, verovatno uz nekakav upscaling ili interpolaciju rezolucije.
Pa ne može veći senzor jer to traži mnogo veće objektive. Da se razumemo, svi objektivi na mobilnim, pogotovo ovima iz top klase, sa velikim senzorima, su u suštini na granici fizike, odnosno under-engineered. Finalni rezultat je proizvod softvera a ne optike, jer bi ona kod svih trebala da je bar 3x veca u promeru a o broju staklenih elemenata i grupa unutar objektiva da i ne govorim. Senzori su moćni ali tek kada bi imali neuporedivo veće objektive, sijali bi u punom sjaju.
Spominje se i pojačalo za slušalice, odnosno jači audio izlaz u odnosu na 1 MK2.
Ono što Sony ne želi da napravi, obično Sharp napravi i plasira na japansko tržište 🎌 😀
Sharp Aquos R6 debuts with 240Hz screen and enormous 1” sensor
E1lv2QZWQAEigH8
Čini se kao opasan telefon. Navijamo da otkine parče kolača vodećim ajfonima, samsunzima itd.
Iz ugla fotografa/videografa:
GSMA review: https://www.gsmarena.com/sony_xperia_1_iii-review-2287.php
Još jedna žrtva SD888, malo lošija autonomija od 1 MK2.
Ovo za rezoluciju displeja i osvežavanje ostaje da se vidi. Bugari tvrde da telefon sam menja rezoluciju i refresh rate, neki tech YT-eri tvrde da displej stalno radi u 1644 x 3840p sa 120Hz (ako se tako podesi), što SD888 zvanično ne podržava ali da navodno telefon ima zaseban čip za displej (X1) koji to omogućava. U svakom slučaju autonomija baterije ispod očekivanja, izgleda da se na neki način se ponavlja 2015. i SD810 čipset.
