Stonecold
Isto, furao apple music i spotify poslednje 3-4 godine.
Mali off, jel stvarno vrede oba ta servisa više od Deezera i zašto?
Stizu i u mts, od sutra krece preorder, pa cemo videti i na oglasima kakva ce biti situacija.
Pogledajte prilog 291114
Nisam bas ispratio od silne kuknjave na punjac, ima razlike u kameri izmedju 12 pro i max?
The main differentiator between the Pro and Pro Max is the sensor size, which as mentioned is 47% larger on the Pro Max. That larger sensor should provide better dynamic range, better performance in low light, and overall higher image quality than any other iPhone. In fact, Apple says the low light performance of the Pro Max sees an 87% improvement over former devices.
The larger physical size of the iPhone 12 Pro Max allowed them to do more with the camera system as well, increasing the zoom on the telephoto camera to 65mm. This means that the Pro Max features a very large zoom range, from 13mm ultra-wide through 65mm zoomed. Additionally, the Pro Max uses on-sensor stabilization via sensor-shift technology, which is common on full-size mirrorless cameras. The sensor can make 5000 micro adjustments per second, and that stabilization means you can expose for up to two seconds handheld in low light. It delivers steady video as well, as expected.
Šta fali ram menadžmentu? Bolji mi je nego na note 9 a furam ih istovremeno. Nego, de nam je stari fanboy ‘sve je fantazija’ igor88?
“The short version is this: Android uses a form of tracing garbage collection to free up unused memory. This process brings everything else to a halt when it runs. This is why Android had a reputation for stuttering performance for a long time. This process is called by the system as often as needed. The less memory you have, the more often it goes into a garbage collection cycle. The best vendors can do to minimize this process is by shipping way more memory than you need.
Now, on the other hand, iOS uses a technique called automatic reference counting. The compiler actually inserts code to allocate and deallocate memory exactly when it is done with it.”
