PlayStation 5 - opsta tema
Vrhunski je to za M2.NVME SSD, najbrzi moguci protokol trenutno.
1 TB kosta oko 100 eura i kapiram odmah da ubacim, jer onih 660 GB nece vrsiti posao vec za par meseci
M.2 PCIe x4 SSD-ovi od 1TB su značajno skuplji od 100€. 🙂
Ali da objave spisak podržanih SSD-ova, pa ćemo da vidimo šta da se uzima.
Ne znam evo na KP 114 eura Kingston, jedino ako nije to to.
KINGSTON 1000GB M.2 NVMe SA2000M8/1000G SSD A2000 series
Ali da, svakako treba da sacekamo koji ce da radi
Samo ce PCIe 4.0 Nvme drajvovi biti u opticaju (za interni storage) i to samo oni koji imaju minimum 5.5GB/s brzinu, uz veoma bitnu stavku da ce verovatno trebati i vise zbog priority levela koje PS5 I/O chip (6 nivoa) ima:
Having said that, we are comparing apples and oranges, because that commercial M.2 drive will have its own architecture, its own flash controller and so. For example, the NVMe specification lays out a priority scheme for requests that the M.2 drives can use, and that scheme is pretty nice, but it only has two true priority levels. Our drive supports six. We can hook up a drive with only two priority levels, definitely, but our custom I/O unit has to arbitrate the extra priorities rather than the M.2 drive's flash controller, and so the M.2 drive needs a little extra speed to take care of issues arising from the different approach. That commercial drive also needs to physically fit inside of the bay we created for PlayStation 5 for M.2 drives.
That doesn't sound cheap 😀
Nije. Računamo na 220€+ za 1TB, barem prvo vreme.
Hm, pa i ako uzmes 1Tb neces se ovajditi, posto je onaj unutra vec 850?
A opet, koliko se secam, oni su najavili da ce prodavati externe kompatibilne SSD-ove koje cemo koristiti manje-vise kao nekad kertridze?
Pretpostavljam da ce za to koristiti onaj USB-C?
Ma kakav Usb C za to, nema on protok takav i nema sanse da se bilo kako Nvme poveze na njega
Što se neće ovajditi sa 1TB? Pa ne vadi se 825GB napolje, on je čip na ploči 🙂 Nisu najavili eksterne SSD-ove.
Sent from my M2002J9G using Tapatalk
Kako nisu?
Sent from my GM1910 using Tapatalk
O ceni tog 980 pro je i pisao @Corvus Corax gore, ali svakako Sony je taj koji daje glavnu rec za compatibility jer Cerny je rekao da ce da rade benchmarke i ispitivanja pre nego sto daju approval.
Za eksterni drajv ce verovatno donji limit biti i standardni hard diskovi ali ce normalno biti ograniceni samo na PS4 igre i nize, uglavnom na sve igre koje minimalno ne zahtevaju boost tog internog SSD-a.
Svi koji su probali kažu da je buka konačno rešena i da je konzola ultra tiha... Ne čudi me posle ovoga. Konačno, baš značajna stvar, jedan od retkih većih problema koji je stalno smarao.
Tih 120FPS je u 1080p. To je lepo prezentovao jedino Devil May Cry 5 Special Edition.
I nije neka šteta što ne dobijamo PS5 u novembru. Beskorisna sprava do jula sledeće godine [emoji3]
Počelo je
Sent from my Oneplus 8
Jesu optimizovane ali je hardver već pregazen, neke igre bas loše rade i imaju dosta frame dropova.
Sent from OnePlus 7 Pro
Ne moze typo da bude kad su Z i S na pola tastature razmaku 🙂
No dobro...
Jel najavljena neka PS5 ekskluziva za 2021. godinu ?
Znaci ne remake/remaster nego nova igra.
Za M.2 upgrade bolje gledajte Phison E18 Gen4 diskove, koji su solidno brži od Samsunga 980Pro. Ja sam se baš razočarao sa ciframa 980-ke. Ono što je bitno nije ni trunku brže od Gen3 serije.
