Tomiprunet
Pa to, dimenzije i kamera su najveci adut, ali izgleda da nista od toga.
So what does this mean? So far, evidence has pointed to bramble using the Snapdragon 765G chip, which is of course equipped for 5G networking. That would mean that this “Pixel 4a (5G)” and the Pixel 5 — which could very well launch side by side this fall — will run on the same main hardware.
But how will Google differentiate these two seemingly very similar devices? The most obvious ways they could do this are through cost and build quality differences. By using “cheaper” materials like plastic on the Pixel 4a (5G) and more “premium” materials like glass and aluminum on the Pixel 5, the two could look and feel obviously different.
[emoji3532]Google Pixel 4a SPECS[emoji3532]
[emoji336]5.81 inch OLED
[emoji416]6GB RAM/128 GB storage
[emoji367]3140mAh battery 18W Fast Charging
[emoji1017]Snapdragon 730G
[emoji328]12MP main lens
[emoji442]dual speakers + headphone jack
[emoji383]Available only in Just Black for $349
-6+128GB, $349 in the US
-Snapdragon 730G
-Pixel 4a 5G with Pixel 5 fall launch, $499
-5.81" Punch-hole FHD+ HDR 19.5:9 OLED Display, AOD & Now Playing
-144x69.4x8.2mm, 143g
-3140mAH Battery
-12.2MP (F/1.7) 77° FOV Dual Pixel Phase Detection Camera w/ OIS
-8MP (F/2) 84° FOV Front Camera
-Upto 4K 30FPS, 1080p 120FPS
-Titan M Security Module
-Availability: U.S, UK, Ireland, Germany, Austrailia, Japan, Canada
Jeste bedak, ali sd765 je valjda bolji samo nekih 10% + 5g koji nikome realno ne treba.Jedna kamera nije uopste mana,ppgotovo na pixelu. Meni je veci bedak taj sd730g
Bedak na papiru, u praksi razlika samo u GPU performansama, a 730 ima dovoljno jak GPU za sve.Jedna kamera nije uopste mana,ppgotovo na pixelu. Meni je veci bedak taj sd730g
