Nisam zapamtio hbga... sad gledam. Pitaću ovog lika što je postovao. Izbrisan Telegram kanal gde je bio info...
Edit: Nađoh, ubacio post u Notepad [emoji846]
I bought this one and it's original and working fine:
https://www.aliexpress.com/item/32861428664.html
My original one was made by Sunwoda Electronic Co., Ltd., this new one is made by Desay. The original Sunwoda has a serial number starting with SWBN43, the original Desay is starting with DSBN43. I have two advises if you are planning to buy genuine parts (not 3rd party or aftermarket): check the manufacturing date if you can and don't buy it if you see that the picture says manufacturer is Sunwoda and the serial is starting with DSBN43.. or vice versa.. those are counterfeit for sure. Good luck.
/url]
	Evo jednog objedinjenog posta na XDA za onog ko želi da proba LOS 17.1 sa 4.9 kernelom:
https://forum.xda-developers.com/showpost.php?p=82699117&postcount=1167
