Ova moja slika je od 01.08.2019 godine.
:smash:
To ispada da svake godine povećavaju kvotu FUP koja se može koristiti za neki procenat!?
Dakle u budućnosti žće biti u EU sve što imaš moćićeš i da potrošiš u EU.
Tačno. Tako je dogovoreno pre ukidanja naknada za roaming unutar EU. Tvoja mreža ti da onoliko GB za korišćenje u EU koliko tvoja tarifa košta u €.
“EU negotiators agreed on the following wholesale caps:
- 3.2 cents per minute of voice call, as of 15 June 2017
- 1 cent per SMS, as of 15 June 2017
- A step by step reduction over 5 years for data caps decreasing from €7.7 per GB (as of 15 June 2017) to €6 per GB (as of 1 January 2018), €4.5 per GB (as of 1 January 2019), €3.5 per GB (as of 1 January 2020), €3 per GB (as of 1 January 2021) and €2.5 per GB (as of 1 January 2022).”
“Data limits - national bundles with limited data
If you have a data allowance in your domestic bundle, this allowance is fully available when you "roam like at home", with no extra charge. This means that your domestic allowance is your limit when roaming.
However, if you have a very cheap mobile data unit price (less than €2.25 / GB in 2019), your operator may apply a "fair use" limit for data that is lower than your domestic allowance when you are roaming. The limit is calculated on the basis of the retail price of your domestic mobile bundle as in the case of unlimited data (below). Your operator must inform you in advance about this limit and will have to alert you when you reach it. Be aware that you can continue data roaming but your operator will apply a surcharge. This surcharge will be the wholesale data cap = €4.50 / GB plus VAT in 2019. The data cap will decrease further after 2019.”
https://europa.eu/youreurope/citizens/consumers/internet-telecoms/mobile-roaming-costs/index_en.htm
