Je li izašao LTSC sa 1903? Verovatno još nije, ali ko zna...
Nije i niti će.
Enterprise LTSB/LTSC prate Windows Server, a pružanje podrške deset godina podrške za svaku Windows 10 verziju bi bilo previše naporno i komplikovano. Sljedeći LTSC očekuj na jesen 2021.
Može li mi neko reći šta su ove dve nesrećne plave strelice i kako se iste isključuju?!...
Pitam za brata (mada ni ja nikad nisam video iste)
It is supposed to indicate NTFS compression. Right click on the partition/volume in question select properties, and see if it is on?
To ti je kompresija, mogao si sam da je uključiš ako si išao na Clean disk i čekirao Compress your os to save space. Mogu biti virusi, a možda ti disk pun pa Windows to sam odlučio.
Prvo je moraš ugasiti:
iz command prompt-a:
compact /compactos:never
Zatim dekompresovati:
Pokreni WinPE 10-8 Sergei Strelec , Hiren ili sl.
Idi na command prompt, zatim u root problematičnog diska diska ako već nije(npr cd c:, cd\ ), zatim compact /u /s /i *.* (možeš compact /u /s /i /a *.* ili compact /u /s:"C:" /i /a , compact /u /s:Windows /i /a *.* ako je samo Windows zahvaćen). Važno je iz Winpe-a jer će sistemski fajlovi ostati upakovani.
/C Compress the specified files. Directories will be marked
so that files added afterward will be compressed.
/U Uncompress the specified files. Directories will be marked
so that files added afterward will not be compressed.
/S Perform the specified operation on files in the given
directory and all subdirectories.
Default "dir" is the current directory.
/A Display files with the hidden or system attributes.
These files are omitted by default.
/I Continue performing the specified operation even after errors
have occurred. By default, COMPACT will stop when an error is
encountered.
/F Force the compress operation on all specified files, even
those which are already compressed. Already-compressed files
are skipped by default.
/Q Report only the most essential information.
Da...upravo mi brat poslao da mu je isključena opcija ali i dalje ima problem...
@Rick hvala nadam se da će buraz uspeti sve ovo da izvede.
Meni je posle majske nadogradnje nestao brghtness slider tako da ne mogu da menjam osvetljenje monitora preko slidera...doduše mogu preko drivera za grafičku i naravno hardverski...ali opet nešto me to iritira 🙂...
@Rick, WinSXS i slicni Windows podfolderi i trebaju ostati kompresovani, jer im je jedina svrha backup.
Komresija se može uključiti na nivou foldera ili fajla, ne mora nužno biti na nivou diska.
Izgleda je samo za desktop nekako uspeo da upali. Nadam se da je rešio problematiku. Hvala svima na pomoći
http://prntscr.com/nvzclz
od nedavno mi se ovo desava, samo na d particiji koja je poseban hard, dakle sistem ne i 3 hard ne, samo ovaj, sve radi na njemu ali mi ide na zivce ovi brojevi i opcija ona gore da poredjas fajlove, tipa ubacim neki film mimo foldera on mi razdvoji fajlove/primer ovako http://prntscr.com/nvze0g
Kako ugasiti bing maps u Outlook 2013,pod actions? Nema takvog addina za isključivanje.
Pre tri godine sam prešao na W10, sa piratske sedmice dok je moglo, radio je normalno, sve do večeras. Malopre mi izbacio poruku da Windows nije aktiviran. Wtf, otkud sad to! Je l' se desilo još nekome?
OnePlus 6/Tapatalk
OnePlus 6/Tapatalk
Ja sam pre par godina išao na onu foru sa legalizacijom sa rupom u win 8. Zaboravih kako se zove. Posle toga tam povezao win na hotmail. Da li si i ti povezao mail.
Uredno mi je Windows bio povezan sa Microsoftom, dobijao sam sve apdejte itd, kao da sam kupio W10.
Tad kad sam prešao sa sedmice, imali su nekoliko meseci prozor tokom kojeg je svako mogao da pređe na W10 potpuno legalno i to sam iskoristio.
OnePlus 6/Tapatalk
Теоретски свако, то је важило за легалне седмице али су пролазили неки заобилазни путеви. Можда су почели и то да проверавају?
Ne bih rekao. Onda bi 2/3 otplao 😀 (ebay, g2a i slični ključevi).
Само претпостављам, ти кључеви свакако нису легални и реално није ни требало да прођу. Можда је овде неки баналан разлог а можда је неки део почео да се проверава. Нестаје пара па да натерају неке да им мало уплате. 😉
Moguće da je do toga, sećam se da je ta sedmica bila aktivirana pomoću KMSPico i da je prelazak na W10 prošao kao da sam imao original, bez ikakvih dodatnih stvari.
Rešen problem zahvaljujući djalfu.
Skoro sam primetio da mi od marta ne kupi update-ove.
Boga mi sam dobar broj sati potrošio dok nisam skontoa šta se dešava. Nestaje windows update service kao i reg key. Uspeo sam to da rešim, tj našao komandu preko koje se u CMD pravi windows update service kao i reg key od drugara. Unesem jednom drugo, aktiviram - skida update, ali problem je što isti nestaje posle svakog reseta...
Šta može da bude uzrok?
Ljudi, u novom Win 1903, kao mogu da izbrišem iz searsh dugmeta histori 😀
