Xiaomi Redmi Note 4
  • Začetnik teme Začetnik teme ZAP
sa ethereala se vratio na žiletov, stvarno je najbolji. ethereal štuca dosta čak i kad input boost pojačam na max. žile je izvukao maksimum i perf i dobra baterija, taman za 2 dana
Ethereal Kernel r10
Changelog:
Compiled Using DragonTC/Clang 9.0.0 with Polyhedral Optimizations
Upstreamed to Linux 3.18.136
Merged in Latest F2FS Changes
Dropped Non-Treble Support // Updated the Flasher as well
Stop Shipping Modified Thermal Config (Temps Skyrocket Because of It)
Removed Darkness CPU Governor
Removed Boeffla Wakelock Blocker (Does Nothing Significant. If Anything, Having it Only Makes Idle Drain Worse)
Added Devfreq Boost Driver
Tune Default Boost Parameters
Bump Up Swappiness to 20
Completely Disable I/O Stats Accounting
Experimental: Replaced Android LMK with Simple LMK
NEON Accelerated ChaCha20 Crypto Algorithm for Random Data Generation
Switch to 300 Hz Kernel Timer Tick Rate
We /LightAF/ Now, ZIP Size Down to Only 10 MiB
Updated Spectrum and FKM Profiles
A lot More Under-the-hood Changes
https://forum.xda-developers.com/showpost.php?p=79132599&postcount=304
1 GHz je boost freq. Izbacio je LMK i ubacio Simple LMK od SultanXDA. Možda je bolji multitasking.
DDR frekvencija mu je zakucana na max. SELinux je permissive sa ovim kernelom.
I izgleda da seckaju recents kartice na oreo. Testirajte, jedan od boljih kernela uz Englezos i Franco.
Ovaj android ne voli Simple LMK 😀
A evo i novog builda kamere od bulkin043
Google camera Version: 6.1.021.220943556
• Returned the stock Google gamma, because AWB worked with Gmm17 without stabili.
• Removed the selection of "Configuration settings", transferred to the Auto mode.
• Added noise reduction settings.
• New noise reduction settings for Google Camera 6.1.021.
• Transferred all the settings from the "Other settings" sub-category to "Experimental settings".
• Removed BSGConfigNSPlusPixel config.
• New version of the patch of departure in the sun.
• Corrected the default settings of many items, somewhere they were maximum, and somewhere they were not selected at all.
• Minor improvements under the soot.
https://t.me/googlecamera_mod/320
Ljudi,kako i gde mogu da iskljucim auto fokus u gcam kada se snima video,stvarno me nervira!
probao novi ethereal i puca na ovoj novoj gugl kameri. i to tako zaglavi da mora hard reset telefona
Хоће ли шаоми пустити званични апдејт за 8.0 или 9.0?
Ne, mido ostaje na 7.0.
Izgleda da će dobiti update na MIUI 11.
Jel si mozda probao ovo?
Ja pokusao prvo standardni apk ali iz nekog razloga Cant open file ....
A fajl za twrp sam flashovao ali puca kad otvori apk tj crashuje.
Update-ovao sam franco custom r18. Mislim da je najbolji release do sada, dosta je optimizovan. Probajte https://goo.gl/LGJZQw
Samo da pohvalim jos jednom bateriju na rn4, aex rom franco kernel. 7h navigacije + 15ak uslikanih slika i baterija na 35%.
Ima li neko iskustva sa oxygen os za redmi?Citam i gledam recenzije po netu, prica se da je fluidan? [emoji16]
Probao..ima bagova...face lock..ambient screen...widi..inace dobro radi..i oreo i pie
Meni najfluidniji bio samsung exp port..
stvarno je dobar, ALI🙂 dropovao mi wifi jednom do sad. videćemo da li će i dalje
Nadam se da neće. Možda odradim rebase Underground kernela, franco custom može biti baza.
Oba su vrhunska, svakako. Na custom r18 primećujem malo veću fluidnost vezano otvaranje share prozora i izabrane aplikacije (LOS 15.1). To mi je nekakvo merilo [emoji16]. Ta akcija je na LOS 14.1 radila baš smooth.
Ljudi, kakva je situacija sa GCam na MiUI 10 ? Npr xiaomi.eu rom ?
Ne radi gcam na MIUI 10 za mido (osim GSI portova)
Mozda sam samo umislio ali meni opet underground nekako bolje radi
Ne bi me čudilo, zato što je UG napravljen kao performance kernel, ali ipak ima dobar battery life.
Evo gpu profile testa FK vs UG, sličan je % dropovanih frejmova kada se koriste iste aplikacije na isti način par puta. Meren je Play Store jer je vrlo zahtevna app i SystemUI (share dugme, notification bar swipe, skrolovanje kroz QS tiles itd.). Gledao sam da bude približan broj frejmova istim korišćenjem aplikacija.
PlayStore (prve dve slike) i SystemUI UG vs FK
FK oko 9% više janky Play Store frejmova i SystemUI oko 5% više. U playstore-u se neznatno primećuje veći broj frame drop-ova. U radu su vrlo slični.
    14.3 KB · Pregleda: 78
    15.3 KB · Pregleda: 78
    14.8 KB · Pregleda: 70
    14.6 KB · Pregleda: 73
