Izvor: GSMArenaNetwork Technology
GSM / CDMA / HSPA / LTE
2G bands GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2
3G bands HSDPA 850 / 900 / 1900 / 2100
4G bands LTE
Speed HSPA 42.2/5.76 Mbps, LTE-A (2CA) Cat6 300/50 Mbps
GPRS Yes
EDGE Yes
Launch Announced 2018, December
Status Available. Released 2018, December
Body Dimensions 154.8 x 75.8 x 8 mm (6.09 x 2.98 x 0.31 in)
Weight 180 g (6.35 oz)
Build Front/back glass, aluminum frame
SIM Hybrid Dual SIM (Nano-SIM, dual stand-by)
Display Type IPS LCD capacitive touchscreen, 16M colors
Size 6.18 inches, 95.3 cm2 (~81.2% screen-to-body ratio)
Resolution 1080 x 2280 pixels, 19:9 ratio (~408 ppi density)
Protection NEG
Platform OS Android 9.0 (Pie); Android One
Chipset Qualcomm SDM710 Snapdragon 710 (10 nm)
CPU Octa-core (2x2.2 GHz 360 Gold & 6x1.7 GHz Kryo 360 Silver)
GPU Adreno 616
Memory Card slot microSD, up to 400 GB (uses SIM 2 slot)
Internal 64 GB, 4 GB RAM
Main Camera Dual 12 MP, f/1.8, 1/2.55", 1.4µm, dual pixel PDAF, OIS
13 MP
Features Zeiss optics, dual-LED dual-tone flash, panorama, HDR
Video 2160p@30fps, 1080p@30fps (gyro-EIS)
Selfie camera Single 20 MP, f/2.0, 0.9µm
Video
Sound Loudspeaker Yes
3.5mm jack Yes
- Active noise cancellation with dedicated mic
Comms WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, WiFi Direct, hotspot
Bluetooth 5.0, A2DP, LE
GPS Yes, with A-GPS, GLONASS, BDS
NFC Yes
Radio No
USB 2.0, Type-C 1.0 reversible connector, USB On-The-Go
Features Sensors Fingerprint (rear-mounted), accelerometer, gyro, proximity, compass
Battery Non-removable Li-Ion 3500 mAh battery
Charging Fast battery charging 2A/9V (18W)
Misc Colors Blue, Silver, Steel, Copper, Iron, Steel
Price About 400 EUR
