Benchmark Computing for Research - Folding@Home
Šta čekaš, uleći :). Ja sam se ponovo aktivirao pre neki dan, pa koliko budem u mogućnosti.
Ne secam se vise ni gde imam nalog ni koji je login....
Svi smo tu :d,cekam sa nekim malo da se jurim :D
Nikako da zamenim slabaški LC 120 sa Raijintek Ereboss cooler-om (stoji u kutiji već godinu dana), pa da pustim malo WCG. Ovako sa dva jezgra na 100% je temp. 60 stepeni, sa sva četiri preko 70, a još nisam prešao ni 4GHz. :wall:
Kod:
root@homelab:/home/igor# ps uax | grep wcgrid
boinc     7629 95.2  0.4 184600 122040 ?       RNl  18:14   3:17 ../../projects/www.worldcommunitygrid.org/wcgrid_mip1_rosetta_7.16_x86_64-pc-linux-gnu -in::file::zip MIP1_databasev2.zip @./MIP1_00147040.flags -out::file::silent result_silent.out -run:jran 1747305897 -nstruct 8 -out::level 100 -run::no_scorefile true
boinc     7630 97.0  0.4 184620 121996 ?       RNl  18:14   3:20 ../../projects/www.worldcommunitygrid.org/wcgrid_mip1_rosetta_7.16_x86_64-pc-linux-gnu -in::file::zip MIP1_databasev2.zip @./MIP1_00147040.flags -out::file::silent result_silent.out -run:jran 1942327049 -nstruct 8 -out::level 100 -run::no_scorefile true
boinc     7631 96.3  0.5 188300 125868 ?       RNl  18:14   3:19 ../../projects/www.worldcommunitygrid.org/wcgrid_mip1_rosetta_7.16_x86_64-pc-linux-gnu -in::file::zip MIP1_databasev2.zip @./MIP1_00147040.flags -out::file::silent result_silent.out -run:jran 776292564 -nstruct 8 -out::level 100 -run::no_scorefile true
boinc     7930 97.5  0.1 107144 32740 ?        SNl  18:15   2:23 ../../projects/www.worldcommunitygrid.org/wcgrid_zika_vina_7.20_x86_64-pc-linux-gnu -jobfile ZIKA_000378222_x1r6r_DENV2_capsid_NMR_17_s2_1248.job -inputfile ZIKA_000378222_x1r6r_DENV2_capsid_NMR_17_s2_1248.zip -seed 903289485
boinc     8006 97.4  0.4 182388 119804 ?       RNl  18:15   2:18 ../../projects/www.worldcommunitygrid.org/wcgrid_mip1_rosetta_7.16_x86_64-pc-linux-gnu -in::file::zip MIP1_databasev2.zip @./MIP1_00146681.flags -out::file::silent result_silent.out -run:jran 797313310 -nstruct 8 -out::level 100 -run::no_scorefile true
boinc     8007 97.0  0.4 182104 119616 ?       RNl  18:15   2:17 ../../projects/www.worldcommunitygrid.org/wcgrid_mip1_rosetta_7.16_x86_64-pc-linux-gnu -in::file::zip MIP1_databasev2.zip @./MIP1_00146681.flags -out::file::silent result_silent.out -run:jran 1581172431 -nstruct 8 -out::level 100 -run::no_scorefile true
boinc     8032 95.0  0.2 128196 70424 ?        RNl  18:15   2:06 ../../projects/www.worldcommunitygrid.org/wcgrid_fahb_bedam_7.28_x86_64-pc-linux-gnu -seed 973124794 -trickle 0 -upload 0 -wcgval 10000
boinc     8058 93.9  0.1 108416 34012 ?        SNl  18:15   2:04 ../../projects/www.worldcommunitygrid.org/wcgrid_zika_vina_7.20_x86_64-pc-linux-gnu -jobfile ZIKA_000378222_x1r6r_DENV2_capsid_NMR_17_s2_1194.job -inputfile ZIKA_000378222_x1r6r_DENV2_capsid_NMR_17_s2_1194.zip -seed 514390153
boinc     8059 92.1  0.1  76728 36488 ?        RNl  18:15   2:01 ../../projects/www.worldcommunitygrid.org/wcgrid_mcm1_map_7.43_x86_64-pc-linux-gnu -SettingsFile MCM1_0147729_4201.txt -DatabaseFile dataset-curatedOvarian_EarlyLate_v1.0.txt
boinc     8065 96.9  0.1  77560 37784 ?        RNl  18:15   2:06 ../../projects/www.worldcommunitygrid.org/wcgrid_mcm1_map_7.43_x86_64-pc-linux-gnu -SettingsFile MCM1_0147675_4031.txt -DatabaseFile dataset-curatedOvarian_EarlyLate_v1.0.txt
boinc     8084 93.4  0.4 180188 117684 ?       RNl  18:15   1:56 ../../projects/www.worldcommunitygrid.org/wcgrid_mip1_rosetta_7.16_x86_64-pc-linux-gnu -in::file::zip MIP1_databasev2.zip @./MIP1_00146995.flags -out::file::silent result_silent.out -run:jran 1326319446 -nstruct 9 -out::level 100 -run::no_scorefile true
boinc     8085 95.4  0.1  77004 36752 ?        RNl  18:15   1:59 ../../projects/www.worldcommunitygrid.org/wcgrid_mcm1_map_7.43_x86_64-pc-linux-gnu -SettingsFile MCM1_0147748_3353.txt -DatabaseFile dataset-curatedOvarian_EarlyLate_v1.0.txt
root      8752  0.0  0.0  12788   936 pts/1    S+   18:17   0:00 grep wcgrid
I tako :)
Ko je vlasnik nase grupe? Mogli bi da izbacimo ove koji imaju nule duze od godinu dana?
E bre kutija ti bi samo da izbacujes, pa ovo je humanitarni projekat,ne postoji opcija da izbacis nekog :)
Sudeci po rezultatima, ima ljudi koji su samo probali i odustali.
@ness: postoji li opcija da se posalje grupni mejl svim clanovima, pa da se izjasne? Ko ne odgovori u razumnom roku ili kaze da nece ucestvovati, da se brise.
Postoji nacin da se posalje grupni mail,ali ne postoji nacin nekoga da izbacim iz grupe. Tako da i nema smisla da to radim.
Ok.
Jel neko cuo za Gridcoin? Navodno dobijas te coin-e kao nadoknadu za ucestvovanje u BOINC programu, ali fora je sto moras biti u njihovom timu :).
Ih bre kutija pustio si jedan dan WCG odma si spalio racunar.
Pa sta cu kad se koristi nonstop :)
Bas bi bilo dobro da ubace neki novi projekat sad kad je SCC presisao
U čemu je fora sa GPUGRID-om? Juče sam tri WU-a obradio i od tad ništa novo, a stoje mi u računaru GTX1070 i P106 neiskorišćene...
Meni je davno crkla gtx460 tako da ne radim :D . A i bilo je onih problema sa bitcoinom.
Bitcoin euforija prosla, a ponesto od kartica ostalo, mozda vreme da se opet krene u GPUGRID, Seti i sl.?
Nije lose staviti 2-3 projekta, pa kad neki privremeno nema work unite, radi se drugi... A kad ima posla svuda, koji % vreme 'e koji da radi se regulise sa "Resource share" podesavanjem u svakom projektu.
Ja sam za jedan komp uzeo rx560,ali nazalost ne radi GPUGRID na njemu?
Da, radi samo na nVidia kartama, mada ima i CPU zadataka... Možda SETI, on radi i na AMD kartama...
Pokusavam da pustim GPUGRID sa jednom nV1070 ali je GPU usage svega 2%. Je l' treba tu nesto jos da se podesi? U BOINC menadzeru je sve na 100%, sve na max, ali GPU usage ostaje isti.
U paraleli radi i WCG, ali se nista ne menja ako ga pauziram.
Jel ti povukao uopste WU?
Jeste, i to radi samo sa long term WUovima koji traju od 8 do 12 sati. One kratke od 2-3 sata uopšte ne povuče.
Sent from S9+ using Tapatalk
Izgleda da Task Manager ne prikazuje dobro opterecenje GPU-a. On pokazuje 4%, dok je u GPU-Z opterecenje oko 83%.
Samo da se javim da sam se vratio na Boinc. Nisam radio par godina vec. Drago mi je da vidim da ima jos aktivnih ljudi ovde. Pozz
Pa ima nas oko 6-7 ,tu smo negde :D
