fkloznica
Uticajan
The way that Xiaomi pulled it off is pretty innovative. It uses neodymium magnets to lock the phone in the open and closed positions and also to provide the "springy" feel in between. This is a more durable solution than actual springs, Xiaomi says the Mix has been tested through 300,000 open/close cycles and you can use it as a fidget toy.
Still, pressing down on the top edge of the phone, we can feel the top half of the slider bend a bit. Drop tests with the Mix 3 will be interesting.
https://www.gsmarena.com/xiaomi_mi_mix_3_handson-review-1844.php
GSM arena . Bice zanimljivo videti da li taj mehanizam može da se rasklima posle par meseci 🙂
Sent from my MI 8 SE using Tapatalk
