Pa isti je senzor samo mn3 ima f1.8 a mix2 f2.0(obe imx386)Ahahah, dobar sibacicu jedno poredjenje MN3 vs Mix 2 stock vs stock da vidimo razlike...
Sent from my MI MIX 2 @MIUI 10
The leak also shows the alleged Mi Mix 3 device with an under-display fingerprint sensor and under display front camera
The leak also suggests that Xiaomi Mi Mix may come with two variants of the device with one variant featuring a under-display front camera while a second variant may feature a popup camera similar to what we have seen in Vivo Nex
It suggests that one variant will be backed by a 3500 mAh battery while the second variant may be backed by 4000 mAh battery
6GB RAM + 64GB ROM: 437 €
6GB RAM + 128GB ROM: 476 €
8GB RAM + 128GB ROM: 514 €
8GB RAM + 256GB ROM: 553 €
Whereas the Ceramic variant will be priced at:
6GB RAM + 64GB ROM: 566 €
6GB RAM + 128GB ROM: 604 €
8GB RAM + 128GB ROM: 643€
8GB RAM + 256GB ROM: 681 €
Mene je sestra udavila zbog toga (note 4 global telefon)je li moguce eliminisati pocelo je da me bas nervira. pokusao sam razno ali on je i dalje tu ...
ili da prelazim na Novu![]()
Sent from my Mi MIX 2 using Tapatalk
