Hmm... U terminalu kaže da je 2.1 verzija, ali po brzinama bi trebalo da je 2.0... Samsung senzor i odličan je...
Pogledajte prilog 234105
http://www.samsung.com/semiconductor/products/flash-storage/ufs/KLUCG4J1ED-B0C1?ia=2413
Bolje od ovoga po ovoj ceni ne postoji - http://www.ebay.com/itm/301692556869^samo baterija i ekran.
uzgred da pitam: neka preporuka za sd karticu, tj da li neko ima neka posebno loša/dobra iskustva sa nekom c10?
Sent from my SM-G950F using Tapatalk
64gb 4k ima kod nas po oglasima za po 30e, originali. Ima raznih proizvdjaca.Bolje od ovoga po ovoj ceni ne postoji - http://www.ebay.com/itm/301692556869
Vrhunska kartica [emoji106]
Ovlašćeni servis, platiš, imaš novu...ipak je to potrošna roba ***, još na s8 seriji kažu da su poradili na (ne)degradaciji!Dobra je baterija i na s8, dok ne krene da slabi. Standardna Samsung boljka... :sceptic:
Ne radi u srbiji. Za sada samo ove domaće bankeDa li je neko koristio Samsung pay u Srbiji i kako funkcioniše? jako malo informacija o tome
Dobar izbor. Neka te služi!Narucio S8+ orchid gray, prvi Samsung u zivotu![]()
Gde ima to u11 za 450e ?Videcu kako ce da mi legne, ako ne legne odma ga menjam za onaj U11 za 450e![]()
Specifically, in terms of upgrades, the body of the S8 Active is much more rugged than the all-glass Galaxy S8 as it includes military-grade shock, shatter, water, and dust resistance. It can handle 5-foot drops likely better than any phone on the market, while its screen is all but guaranteed never to crack. You can also submerge the device in up to 5 feet of water for up to 30 minutes and it’ll survive.
As for specs, there’s still a Snapdragon 835 processor, 4GB of RAM, 64GB of storage, a 12MP camera, Android Nougat, and a 5.8-inch Infinity Display onboard. Regarding that last spec, Samsung has removed the curves from the screen for the S8 Active in favor of a flatter form factor for added protection. Luckily, to compensate, the company includes a massive 4,000mAh battery that dwarfs both the S8 and S8+’s 3,000mAh and 3,500mAh cells, respectively.
