D
Deleted member 16483
Guest
Da li neko korisiti Sygic za navigaciju i kako ste zadovoljni, deluje dibro pa mozda kupim?
We are retiring the existing Windows Mobile App on 08/31/2017, which means the app icon will remain on your phone but will no longer work. You can continue to use LinkedIn on your Windows phone by going to www.linkedin.com from your mobile web browser (Edge, Internet Explorer). From here you'll be able to access the full range of LinkedIn features, including search and profile editing, which were not available on the app.
For easy access to LinkedIn mobile web, you can pin the website to your start screen on your mobile device and open it with a single tap. Instructions on how to do so below.
1.Open the web browser on your Windows phone.
2.Enter www.linkedin.com and navigate to the site.
3.Tap the three-dot menu button at the top right.
4.Select "Pin To Start"
Additionally, we will be launching a new LinkedIn Windows desktop app in a few weeks on the Microsoft Windows App store.
Probao i zadnju, kuje aplikacija i na pc-u
A imam povoljne iptv liste sa svim domacim i stranim filmskim i sportskim kanalima medjutim nikako da nadjem za win odgovarajucu aplikaciju
Sent from mTalk
Upravo skidam update pa cu da testiram
Sent from mTalk
Nisam stigao da probam ali mi je izbacio obavijest da instaliram mpeg2 video extension
Sent from mTalk
Iptv viewer ima update ali mi izbacuje gresku nece da skine i instalira
Sent from mTalk
Nece iptv viewer ni na taj nacin. Rade kod mene ove liste bez stekanja, probacu ovu novu iptv app kasnije. Ni telegram app nije htio da mi azurira pretpostavljam da je do njih neki bug, do MS
Edit: Uspio sam instalirati ali sam prvo morao deinstalirati app
Sent from mTalk
Sent from mTalk
Na prvu loptu deluje ok.
Maps me je izludjivao jer na n925 na win10 nece da crta konture ulica, a Sygic radi ok na starom hardweru.
Da odlicna je izgleda ce uskoro poprimiti novi ui kao na droidu, mislim korak po korak ali to im je cilj.Nova verzija Skypa (11.19.820.0), koju inače koristim i za SMS poruke, pored novog izgleda, omogućeno je i deljenje iz drugih app (konačno), kao i reakcije na Skype poruke...
