Windows mobile 10 INSIDER buildovi
Ma nije da puca, nego kad otvoris aplikaciju i udjes na neku stranicu on je smanji i ne reaguje, pa mora novi tab da radi. Na CU je to radio jednom u tri puta, izludjivalo me. Jedino na edge radi chat na fejsu, na androidu na chrome otvara google play da se instalira messenger [emoji1]
Samo neka nastave ovako, mislim da ce da se dovedu u red.
Sent from mTalk
Sent from mTalk
Dobro kod tebe je tako, kod mene puca, kao force close na droidu... Ne znaci da je na svakom telefonu isto / isti simtomi [emoji6]
Neka samo pegglaju, koji ti imas fon? Posto na nekim je potreban trik za instaliranje ovih insajder buildova - nisu podrzani telefoni pa zato.
Svake nedelje dolazi novi build, u proseku po 5 znacajnih ispravki, *** bolje ista nego nista.
Sent from Kin :(
Ma, da, razumeli smo se potpuno. [emoji4]
Imam L640SS, bas ono kad smo pricali, aktivirao insider, potrazio update i instalirao bez problema. Region mi je na USA ako se ne varam, nisam ga menjao odavno.
Sent from mTalk
15228 fast
What's new for Mobile?
We have fixed notifications (SMS, Calendar) with all Fitbit trackers.
We have fixed crashes reported while using Photos app.
We have fixed a deployment issue in where if an admin uses ActiveSyncCSP to provisioning email account on device running the Windows 10 Creators - Update without providing a valid password, and the email server enforces a limited number of denied access retries, then the server will lock out the email account.
We have improved battery performance by fixing a bug in a scenario where 30% more power was used during Camera app preview and capture mode.
Some Insiders provided feedback that playing video on phone resulted in a black flash and/or stuttering when in landscape mode. We have fixed this issue.
We have improved Bluetooth connectivity with Garmin Wearable devices.
General improvement in reliability of phones by fixing top crash issues.
https://blogs.windows.com/windowsex...32-pc-build-15228-mobile/#x5vGzARLTbeEFj6c.97
edit: 38MB zauzima ;)
Na poslednjem buildu mi ne radi Cellular data. Ima li jos neko problema? L640.
Sent from mTalk
Sent from mTalk
Vidis da nema vise ni insajdera xd sem nas dvoje.
Radi sve lepo bez greske, barem kod mene na 950.
Pretrazi feedback hub, mozda ipak zavisi od modela do modela :(
Sent from Kin :(
Hahahahahahah sad smo kao Buc Kasidi i Sandens kid. [emoji23]
Moracu da vidim, radilo je u pocetku sad nesto zeza, restartovao sam, palio i gasio Airplane mode ali slaba vajda.
Sent from mTalk
Sent from mTalk
Podesavanja za net su ok? Parametri?
Sent from Kin :(
Sad sam proverio, iz nekog razloga u Default connecting profile imam dva izbora, MTS i Telekom, kad izaberem Telekom, onda radi. Samo mi nije jasno zasto se promenio taj parametar nisam ni ulazio u ta podesavanja.
Sent from mTalk
Sent from mTalk
Hehe :) insider je to, ocekuj svasta.
Sent from Kin :(
Ja sam na insajderu ,nego se ne javljam jer sve radi perfektno pa nemam razloga :) A verujem da nas ima jos mnogo,nego niko nema nikakav problem pa se stice utisak kao da nas nema :)
Istina , ja nikad do sada nisam koristio stabilniji build na fast ringu :) neka nastave da peglaju, i mozda nekad i nesto ubace nowo [emoji847]
Sent from Kin :(
Po meni, da srede Edge, koliko vidim ima dosta u feedback hub zalbi na njega, i za mene je dosta. [emoji16] Ocekivao sam FB da sredi svoje aplikacije kao Insta, ali avaj...
Sent from mTalk
15230 fast
We fixed an issue where VPN profile appeared to be always ON.
We fixed a notification issue between the Bluetooth Support Service and device background services for fitness bands.
We fixed issues with Caller ID matching in Japan & Denmark.
https://blogs.windows.com/windowsex...41-pc-build-15230-mobile/#iYwFqIJFHAA55wIB.97
Ovo je postalo presmesno, kad vidim sta sve ima za PC a sta za Mobile (nista) [emoji19]
Sent from Mumia 950
Biće i za mobile,ne očajavaj [emoji6]
Sent from mTalk
15235 fast
LOL skoro nisam video ovoliki update, da skoro 1GB zauzima.
https://blogs.windows.com/windowsex...51-pc-build-15235-mobile/#4JYLFaVG1rwa3D0P.97
Sent from Mumia 950
Toliko toga za PC, za Mobile slabo... Jos ne resavaju Edge *****i...
Sent from mTalk
15240 fast
Emoji 5.0
Chinese Lunar Calendar
General changes, improvements, and fixes for Mobile
We fixed the issue where trying to update Windows Store apps saved to your SD card resulted in an 8007000B error. Apps installed on SD cards should update without any issue.
We fixed an issue where there was no icon shown for Windows Update for either new notifications or on the settings page under Settings > System > Notifications & actions.
Known issues for Mobile
Occasionally, Narrator speaks phrases in English rather than the chosen non-English language.
There is a problem with the HP Elite X3 with wired docks where the portrait orientation setting is lost when the external display is disconnected and reconnected. A workaround for this is to reboot the phone after tapping the “OK” button instead of disconnecting and reconnecting. This workaround must be performed every time you connect to an external display you want to use with Continuum in portrait orientation.
When installing or updating a Windows Store app, you may see error 80070057. As a workaround, you can get the latest app by uninstalling the older version of the app from your device and reinstall latest version from Store.
https://blogs.windows.com/windowsex...eview-build-15240-mobile/#LhMthCaRPhTSQHyj.97
15245 fast
This build also includes all the improvements from KB4034674.
We fixed an issue where the MTP service would sometimes crash when you disconnected your phone while a file transfer is in progress.
We fixed a spin loop that was occasionally triggered by deleting a VPN profile.
We fixed an issue where apps which call into the firewall (such as Microsoft Edge) have the potential of becoming deadlocked and the app hangs until you reboot your phone.
We fixed an issue in the routing engine used by apps like Maps where the initial direction was always set to North which could result in unnecessary route segments.
We fixed an issue where Silverlight apps that use GPS would either not start or crash.
We fixed an issue where a non-default Messaging app (e.g. Skype) would crash with an Access Denied error when changing Download messages settings.
We fixed an issue where the new Privacy Consent popup would block loading of apps which used the activity detection and pedometer sensors.
We fixed an issue where turning on/off Reset Protection could cause the phone to reboot.
https://blogs.windows.com/windowsex...75-pc-build-15245-mobile/#LLWGpsI33r3tMULA.97
15250 fast
Two factor Authentication: We are excited to announce that we’ve introduced a two factor authentication unlock mechanism for Windows 10 Mobile. With two factor unlock, an enterprise can enforce an additional security layer to their sensitive data via an MDM policy. Once two factor unlock is enabled, a phone user will have to enter a numeric pin followed by an enterprise-defined factor to unlock the phone. An example of an enterprise-defined factor is a companion device such as an NFC tag which can be used to unlock a phone using our Companion Device Framework sample app and documentation.
AppLocker Improvements: A number of customers have provided feedback on the warning prompts for apps that are blocked by enterprise policies. We’ve improved the UX and updated the MDM SyncML scripts associated with the policies. Application restrictions can be configured by either the ApplicationManagement CSP or AppLocker CSP.
VPN Improvements: In the modern corporate workplace, mobility is mainstream and secure access to corporate data via VPN has become the norm. We are bringing a range of improvements and features that enhance the reliability of VPN on Windows 10 Mobile. The key updates to our VPN capability are:
Lots of reliability improvements for VPN connectivity in Windows 10 Mobile.
IKEv2 Sleep and Power Enhancements.
VPN completes all pending actions before sleep and disconnects.
Automatic reconnection on resume.
Force tunneled improvements for UWP platform.
Proxy improvements for UWP VPN profile.
Enabling MMS usage when VPN is connected.
We fixed a regression that was introduced in build 15245 where the fingerprint reader on the HP Elite X3 did not turn on the screen. You needed to turn on the screen before you could use Windows Hello.
We fixed some issues where the Maps app navigation would start navigating a route and after performing a reroute, would present a list of possible routes instead of adjusting to the current route.
We also improved map-matching particularly for routes using ferries.
We fixed an issue where an app using the routing engine (e.g. Maps) would timeout on providing the route if suspended for more than 30 seconds.
We fixed an issue where tiles on the Start screen would occasionally be blank.
We fixed an issue where a VPN profile that was created via the VPN Management API would always be a dial-up profile.
We fixed an issue with the MDM policy used to control Build Flighting by Mobile Enterprise.
We fixed a couple of navigation issues when changing from highway to highway (occasionally, signposts were copied from the original highway to the destination highway) and highway to non-highway (erroneous instruction to “enter highway”).
We fixed a rare issue where the user’s call history was shown as corrupt after an upgrade.
https://blogs.windows.com/windowsex...er-preview-build-16288-pc-build-15250-mobile/
Drugari sta je ovo, samo ja ovde ostavljam changelogove :trust: jeste li zivi ?!
Ja pratim temu
I ja pratim tvoj lik i delo
Iskreno ne čitam najpažljivije CL-ove, ali mi tvoji postovi redovno budu indikacija za traženje novog apdejta.
15252 fast
This build includes all the improvements from KB4038788.
In preparation for the release of the Windows 10 Fall Creators Update, the product version number has been updated to 1709 just like PC.
We fixed an issue where, on powering the screen off/on, high demand for CPU could cause several apps to crash. Background processing of photos is an example of high CPU demand. In a photo shoot session, you may have seen the Camera app crash.
We fixed an issue with the Messaging app where conversation text was displayed incorrectly. Thanks to our Insiders that quickly highlighted this issue.
https://blogs.windows.com/windowsex...ws-10-insider-preview-build-15252-mobile/amp/
1709 dolazi i za mobile [emoji3]
Prebacio L550 na insider-fast, odmah glatko prosao update Outlook.
Sent from mTalk
На инсајдеру бржи начин сам, неће да ми скине српске тастатуре, јел има неко тај проблем? Лумиа 640
15254.1 fast+slow ovo je rtm build... uskoro i za sve u toku meseca , pojavio se skoro na build feed'u.
Evo i link https://www.windowslatest.com/2017/...ators-update-rtm-build-15254-1-now-available/
Windows 10 Mobile Fall Creators Update is not a major upgrade as Microsoft is no longer developing its mobile platform. Earlier this week Microsoft’s Joe Belfiore confirmed that Windows 10 Mobile is no longer the company’s focus and it will only receive bugs. On the other hand, the future of Windows 10 Mobile Insider Program remains to be seen.
Iako sam ocekivao da dignu ruke od platforme, i iako najavljuju mesecima, bio sam tuzan kad su izdali saopstenje. Dve godine me savrseno sluzio, vala koristicu ga dok god mi rade aplikacije. Jedino je ****** sto ce i developeri da dignu ruke od aplikacija.
Sent from mTalk
