Ja ocekujem da se u sledecih mesec-dva performanse dobrano poboljsaju kad se ispeglaju i driveri i BIOSi.
Da li smatraš da je potrebna Hero ploča za 4.0-4.2GHz?
Best buy? Po toj ceni nikako.
Nisam znao da Crysis 3 koristi sve raspolozive resurse. Tu je klok za klok maltene egal sa i7-5960X. Znacice za Star Citizen.
Ko ne voli Poljake i Ruse bolje da ne gleda testove za gaming :shock::
http://www.purepc.pl/procesory/premiera_i_test_procesora_amd_ryzen_r7_1800x_dobra_zmiana?page=0,31
Da vidimo testove i na drugim sajtovima....
zar nije bila pricha da R5 nece ici preko 4 GHZ da ce se losije klokovati od jace brace i svima nam je bilo cudno ?
Samo u nekim deonicama igre, recimo, kod one travuljke.
Valjda je logičnije da se bolje overklokuje od 8/16?
So here is where we need to write an entire paragraph. You have been able to see that the Ryzen 7 1800X performance is good, but not just yet 100% where it needs to be. During the past week we have been going back and forth to figure out what could be causing the relatively lower game performance. To date, we have no valid answer to that. The graphics card runs properly at PCI-Express x16 3.0. We know from the RAW and synthetic performance benchmarks that the cores are fast enough, in fact VERY fast. Somehow that does not relate to game performance. It will be interesting to see if other media / websites will show similar results to ours. It rather feels and smells a little like what Nvidia has been fighting a while ago, a DPC latency issue. Next to that we find Ryzen 7 rather memory bound with fairly high memory latency in the 80 to 100ns+ ranges depending on your configuration. It is what it is though, the performance definitely is good enough for what it needs to be, but currently at 1080P with a fast enough GPU the performance lacks a little compared to where it needs to be and can be. I will need to give AMD the benefit of the doubt here, the platform is young and everything is new. The processor certainly is fast enough compared to the Intel 59xx / 69xx counterparts. We will keep an eye on this and when we have to report anything about it we'll update this content. And also in closing on this topic, if you are a little GPU bound or use 2560x1440, this really is a non-issue as perf there is top notch.
BF1 ne koristi sva jezgra vec 10-ak thread-ova. Nazalost nismo probali SMT OFF, iako smo imali info da ce dosta igara bolje raditi, ali nazalost vreme nije dozvoljavalo. Verovatno cemo se na to vise okrenuti kada budemo testirali 4/6core modele.Toliko o gaming-u, famozni BF1 koji koristi sva jezgra i onda kao pobednik izađe i i5. Witcher 3 i Fallout 4 nemojte ni gledati 🙂
Eh da, koliko je smesan 8350 u odnosu na Ryzen. Smesan je i onaj 2C/4T Pentium, takozvani best buy.
Nije neophodna, Hero je tako dobro napravljena ploca da je vise za ln2. Ali opet da kupujem i da ocu da OCujem, uzeo bih Hero. 45C VRM tokom stres testa, haos.
To je cisto do mene i toga sto se lozim na kvalitetne ploce 😀
Ima li nekih testova sa renderingom?
Meni se čini da je moj budući procesor 7700k od 355E na KP najbolja kupovina za igranje. Tuče ili je rame uz rame sa najskupljim Rajzenom. Rispekt.
