mtsTV GO
  • Začetnik teme Začetnik teme McDuck
kada prestane besplatno gledanje ovih kanala, onda ih posle tog perioda gledajte i dalje besplatno, ali ovako:
MTS GO (MTS Multiscrean) - Telekom Srbija
Otvoriti stream u VLC Plejeru!
Kod:
#EXTINF:-1,Novi kanal -
http://93.87.85.70/PLTV/88888888/224/3221226357/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226395/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226570/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226573/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226574/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226575/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226576/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226577/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226578/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226579/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226580/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226581/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226582/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226583/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226585/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226586/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226587/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226588/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226591/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226592/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226593/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226595/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226596/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226597/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226598/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226599/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226600/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226643/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226661/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226662/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226663/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226664/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226665/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226666/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226667/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226668/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226670/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226671/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226672/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226673/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226710/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226711/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226728/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226729/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226730/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226731/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226732/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226734/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226739/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226749/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226750/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226752/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226753/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226755/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226756/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226757/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226758/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226759/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226760/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226761/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226762/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226763/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226764/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226765/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226766/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226767/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226768/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226769/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226770/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226771/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226772/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226773/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226774/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226787/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226788/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226796/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226809/04.m3u8
http://93.87.85.70/PLTV/88888888/224/3221226814/04.m3u8
Ako neko uspe da nađe Arene neka ih izdvoji, ubih se trazeci, ali nema,
Arena 1 je na http://93.87.85.72/PLTV/88888888/224/3221226643/04.m3u8 ali džabe kad je za razliku od većine ostalih kanala (npr Eurosport 1 na http://93.87.85.70/PLTV/88888888/224/3221226583/04.m3u8 ) stream enkriptovan a https adresu na kojoj je key fajl browser neće da otvori. Kao što je slučaj sa svim streamovima na D3Go, svi su enkriptovani sa AES 128 enkripcijom. Same m3u8 fajlove je moguće skinuti bez problema... i kad se otvore vidi se ključna razlika:
Kod:
Eurosport 1:
#EXT-X-KEY:METHOD=NONE
Arena 1:
#EXT-X-KEY:METHOD=AES-128,URI="https://blabla",IV=blabla
Bez ključa nema dekripcije, bez dekripcije nema gledanja u VLC i sličnim playerima.
evo i Arena
Kod:
#EXTINF: -1,Arena 1
http://93.87.85.71/PLTV/88888888/224/3221226643/02.m3u8
#EXTINF: -1,Arena 2
http://93.87.85.71/PLTV/88888888/224/3221226662/02.m3u8
#EXTINF: -1,Arena 3
http://93.87.85.71/PLTV/88888888/224/3221226664/02.m3u8
#EXTINF: -1,Arena 4
http://93.87.85.71/PLTV/88888888/224/3221226661/02.m3u8
#EXTINF: -1,Arena 5
http://93.87.85.71/PLTV/88888888/224/3221226665/02.m3u8
Pošto zvanične objave na sajtu o naplaćivanju usluge MTS TV GO još nema, ja sam ih okrenuo i dobio odgovor koji je već bio poznat, naplaćivanje kreće od sutrašnjeg dana i cena je 250 din. mesečno, može se odjaviti putem sajta Moj Mts nalog ili putem poziva na 0800100100, opcija 3. Znači, godinu dana je ravno bilo besplatno, ali pošto kod njih ništa nije zauvek besplatno onda vele da se malo omaste putem i ove usluge. Od mene neće videti dinara za ovu bezvrednu uslugu, ko hoće i želi da odjavi neka to uradi danas putem jedne od dve malopre navedene opcije.
Kod mene je iva usluga još uvek besplatna
Послато са LG-H850 уз помоћ Тапатока
Produzili su besplatno do kraja godine. Tako stoji na sajtu.
Nije baš profesionalno da njihovi operatori pričaju jedno, a oni rade drugo.
Neverovatni su, jedno pričaju, drugo rade, u svakom slučaju bolje što je ostalo besplatno za onoga ko koristi, ali tolika neprofesionalst neka im služi na čast.
Ima li neki ovakav link za sportklubove? ili neki program koji radi isto? Hvala.
hehe carski... Nisam ni hteo da ga odjavim, znao sam... I opet će 31-og da ga produže.
Pa naravno, već viđeno. Tek kad prođe nedelju dana a da nema novog datuma na sajtu onda ću da isključim uslugu i platim za tih par dana što više nije bilo besplatno 😀
Al baš su papci, non stop produživanje za 2 meseca... umesto da lepo stave da je besplatno za Box/IPTV korisnike dok traje ugovorna obaveza ili besplatno do 31.12.2017. kao fora posle toga će "uskoro" da se naplaćuje, osim ako opet uzmete novi Box ugovor.
Jel beše ako ovaj "tv na više uređaja" gledam na telefonu preko mts mreže saobraćaj se ne naplaćuje? Ili nije tako?
Bio sam deaktivirao za svaki slučaj dok nisu produžili promo. Sad sam ponovo aktivirao i kaže
Broj uređaja je dostigao maksimalno ograničenje. Zameni uređaj i pokušaj ponovno logovanje.
Kad kliknem OK na trenutak krene da pokazuje listu uređaja gde bi mogla da se izvrši zamena ali me odma izbaci nazad na logovanje. Šta da mu radim?
edit: nekako se pojavila lista i kod svakog piše oflajn, teško da može da se razlikuje koji je koji 😀 ali nema veze proradilo.
Malo se nešto naplaćuje, valjda samo za logovanje, ako imaš MB ili GB u paketu onda ti skine možda megabajt-dva, a ako nemaš net u paketu onda ti skine možda neki dinar, baš je nešto simbolično u pitanju, tako je barem meni bilo.
Ali nista nisu uradili povodom one greske koja se javlja na telefonima.
Zvao i isao u poslovnicu, oni napisali i prosledili i evo vec nedelju dana nista.
Samo kazu vidimo da ste prijavili, i kolege rade na vasem slucaju, pa sta rade nedelju dana?
I oni hoce da to naplacuju jos, ma dobro to jos i koristimo za Dz kako "radi" tj. ne radi, trebali bi oni nama da placaju za koriscenje tog sr@nja od aplikacije sto su napravili.
Ne mogu da verujem da ne umeju da rese a sve je radilo odlicno sta su cackali kad ne znaju da nameste.
Podesecaju me na dev Tapatalka, svaku novu nadogradnju nesto z@jebu.
Hoće neko da mi objasni kad aktiviram mts na više uređaja gde idem/kliknem da gledam preko pc? Dakle usluga je aktivirana a kako i gde da idem da bi gledao kanale?
Edit: Pronašao. Preko mts go 😉
Čačkali su da bi kao zaštitli kanale pošto se lista sa kanalima vija po netu već mesecima. E otkako su to počeli čačkati Arene pre svega su počele da zezaju. Najpre nisu radile uopšte a sad rade kao i da ne rade. Pet puta secnu u toku jednog minuta tako da su praktično neupotrebljieve. Pretpostavljam da su svesni problema te da su zbog toga odustali od naplaćivanja usluge dok se to ne reši. Pa ko bi to ovako kupio - nekom ne radi na telefonu, nekom na PC-ju ne rade pojedini kanali...
Kod mene radi i na telefonu i na kompu...
Jako zadovoljan, nekako nisam očekivao ovako nešto od mts-a... 😀
Znam zasto ne rade i znam da su zastitili, nije to problem, vec je problem sto to ne resavaju. Nisam se ja zalio sto su zastitili, neka su ako se nelegalno skida stream, ali je problem sto legalno ne mozes da gledas.
A sto se tice zastite prosle nedelje sam bas devojku iz poslovnice obavestio da su im Arene zasticene(nije znala kaze) i da od tada imam problem na telefonima.
Kazi mi jel ti rootovan telefon? Ako nije mozda je to problem, meni su telefoni kojima pristupam nalogu svi rootovani, ako kod tebe nisu mozda je to kvaka, a ako jeste i tvoj rootovan, onda je nesto drugo u pitanju sto ne znaju da rese kad su sjeb@li.
Ma kapiram o čemu pričaš i slažem se u potpunosti sa tobom. Problem će rešiti kad zaposle nekog informatički pismenog koji će to da im odradi.
Nije rootovan...
Nadam se da ce to biti pre, s obzirom da je zabrana zaposljavanja jos uvek na snazi u javnom sektoru, znacilo bi da bi se bas nacekali da nam srede, ako ga budemo cekali takav ce se naci mozda za 7-8 godinama.
