ZAP
posle note 3 i note pro stigao je i
Note 4
http://www.xiaomidevice.com/xiaomi-redmi-note-4.html
Razlike između modela
http://forum.benchmark.rs/showthread.php?p=5195957
Otključavanje bootloadera
http://forum.benchmark.rs/showthread.php?t=384474
http://en.miui.com/thread-335803-1-1.html
PS
sem kamere na prvi pogled i nema neke velike razlike sa Note pro :-(
Xiaomi Redmi Note 4 Smartphone Specs
ModelXiaomi Redmi Note 4
Band2G: GSM B2/B3/B8
3G: WCDMA B1/B2/B5/B8; TD-SCDMA B34/B39; CDMA2000/1X BC0
4G: FDD-LTE B1/B3/ B5/B7/ B8; TD-LTE B38/B39/B40/B41(2555-2655MHz)
Sim CardDual SIM Card Dual Standby(1*Micro-SIM , 1*Nano-SIM / Micro-SD)
Release DateAugust 25
Service ProvideUnlocked
ColorGrey
OSMIUI 8
CPUHelio X20
ROM64GB
RAM3GB
Display Size5.5 inch, 450nit
TypeIPS, 178 wide angle
Resolution1920 x 1080 pixels, 401PPI
Card ExtendSupport TF card up to 128GB extended
CameraDual Cameras, 5.0MP front camera; 13.0MP back camera with flashlight and auto focus
Xiaomi Redmi Note 4 Mobile Phone Basic Function
Ringtones TypePolyphonic/MP3
Audio File Formatmp3, aac, aac+, eaac+, amr, wb-amr, midi, ogg
Video File Format1080p (1920x1080), mpeg4, h.263, h.264
Image File FormatJPEG/BMP/GIF/PNG
FlashSupport
FM RadioYes, earphone needed
Earphone Port3.5mm
GPSYes, built in, also support A-GPS and Glonass
With EPO assistance to speed up postioning
WIFIYes, 802.11 a/b/g/n/ac, dual band, 2.4GHz/5GHz, WiFi Display, WiFi Direct
BluetoothBluetooth 4.2, suppoer HID
OTGSupport
SensorsInfrared, Gyro, Acceleration sensors, Proximity sensor, Ambient light sensor, Hall Sensor
Multi-TouchSupport
Dimensions151 x 76 x 8.35mm
Net weight(Including battery)175g
LanguageEnglish, Simplified/Traditional Chinese
Other Feature4G, WIFI, GPS, FM, Bluetooth, Ebook, Email, Messaging, wallpapers, calendar,calculator, clock, camera, tethering & portable hotspot, dual mic for noise reduction,OTG, gyroscope, compass, LED notification, Mitalk, etc
Xiaomi Redmi Note 4 Mobile Phone Accessories:
1 x 4100mAh Battery(5V / 2A)
1 x USB Cable
1 x Charger We will send adapter plugs according to the shipping address of the buyer.
PSS
razlika je i u
4pro
IPS LCD capacitive touchscreen, 16M colorsLTPS-AMOLED capacitive touchscreen, 16M colors
microUSB USB-C 1.0
4100 mAh 4050 mAh --- ako je bitno
Note 4
We've just launched Redmi Note 4 in Beijing China in collaboration with China Mobile this morning. Redmi Note 4 comes with powerful Helio X20 10-core processor, metal unibody design, chamfered edges. If you notice this device carefully, the placement of the front sensors are now symmetry and neat. Redmi Note 4 sports with 4100mAh high-capacity battery that gives you peace of mind knowing you get a full day of use. 5.5” full HD display supports sunlight and night display. Redmi Note 4 is priced at ¥899 ($135),64GB priced at ¥1199 ($180), affrodable yet powerful device to everyone !
Highlights:
-Helio X20 10-core processor
-Metal unibody design, chamfered edges
-4100mAh high-capacity battery
-5.5” full HD display, 2.5D curved glass
-13MP PDAF camera, f/2.0
-Fingerprint sensor
-16GB priced at ¥899 ($135),64GB priced at ¥1199 ($180)
PS
ColorGrey
OSMIUI 8
CPUHelio X20
ROM64GB
RAM3GB
FlashSupport
Earphone Port3.5mm
OTGSupport
Multi-TouchSupport
1 x USB Cable
PSS
razlika je i u
4pro
microUSB USB-C 1.0
