Xiaomi Redmi Note 4
ZAP
posle note 3 i note pro stigao je i
Note 4
http://www.xiaomidevice.com/xiaomi-redmi-note-4.html
Razlike između modela
http://forum.benchmark.rs/showthread.php?p=5195957
Otključavanje bootloadera
http://forum.benchmark.rs/showthread.php?t=384474
http://en.miui.com/thread-335803-1-1.html
We've just launched Redmi Note 4 in Beijing China in collaboration with China Mobile this morning. Redmi Note 4 comes with powerful Helio X20 10-core processor, metal unibody design, chamfered edges. If you notice this device carefully, the placement of the front sensors are now symmetry and neat. Redmi Note 4 sports with 4100mAh high-capacity battery that gives you peace of mind knowing you get a full day of use. 5.5” full HD display supports sunlight and night display. Redmi Note 4 is priced at ¥899 ($135),64GB priced at ¥1199 ($180), affrodable yet powerful device to everyone !
Highlights:
-Helio X20 10-core processor
-Metal unibody design, chamfered edges
-4100mAh high-capacity battery
-5.5” full HD display, 2.5D curved glass
-13MP PDAF camera, f/2.0
-Fingerprint sensor
-16GB priced at ¥899 ($135),64GB priced at ¥1199 ($180)
PS
sem kamere na prvi pogled i nema neke velike razlike sa Note pro :-(
Xiaomi Redmi Note 4 Smartphone Specs
ModelXiaomi Redmi Note 4
Band2G: GSM B2/B3/B8
3G: WCDMA B1/B2/B5/B8; TD-SCDMA B34/B39; CDMA2000/1X BC0
4G: FDD-LTE B1/B3/ B5/B7/ B8; TD-LTE B38/B39/B40/B41(2555-2655MHz)
Sim CardDual SIM Card Dual Standby(1*Micro-SIM , 1*Nano-SIM / Micro-SD)
Release DateAugust 25
Service ProvideUnlocked
ColorGrey
OSMIUI 8
CPUHelio X20
ROM64GB
RAM3GB
Display Size5.5 inch, 450nit
TypeIPS, 178 wide angle
Resolution1920 x 1080 pixels, 401PPI
Card ExtendSupport TF card up to 128GB extended
CameraDual Cameras, 5.0MP front camera; 13.0MP back camera with flashlight and auto focus
Xiaomi Redmi Note 4 Mobile Phone Basic Function
Ringtones TypePolyphonic/MP3
Audio File Formatmp3, aac, aac+, eaac+, amr, wb-amr, midi, ogg
Video File Format1080p (1920x1080), mpeg4, h.263, h.264
Image File FormatJPEG/BMP/GIF/PNG
FlashSupport
FM RadioYes, earphone needed
Earphone Port3.5mm
GPSYes, built in, also support A-GPS and Glonass
With EPO assistance to speed up postioning
WIFIYes, 802.11 a/b/g/n/ac, dual band, 2.4GHz/5GHz, WiFi Display, WiFi Direct
BluetoothBluetooth 4.2, suppoer HID
OTGSupport
SensorsInfrared, Gyro, Acceleration sensors, Proximity sensor, Ambient light sensor, Hall Sensor
Multi-TouchSupport
Dimensions151 x 76 x 8.35mm
Net weight(Including battery)175g
LanguageEnglish, Simplified/Traditional Chinese
Other Feature4G, WIFI, GPS, FM, Bluetooth, Ebook, Email, Messaging, wallpapers, calendar,calculator, clock, camera, tethering & portable hotspot, dual mic for noise reduction,OTG, gyroscope, compass, LED notification, Mitalk, etc
Xiaomi Redmi Note 4 Mobile Phone Accessories:
1 x 4100mAh Battery(5V / 2A)
1 x USB Cable
1 x Charger We will send adapter plugs according to the shipping address of the buyer.
PSS
razlika je i u
4pro
IPS LCD capacitive touchscreen, 16M colorsLTPS-AMOLED capacitive touchscreen, 16M colors
microUSB USB-C 1.0
4100 mAh 4050 mAh --- ako je bitno
Amoled i c tipe usb , nije to mala razlika
Fino poboljšanje. Cena od $135 za 16GB model je odlična.
Gde piše da je oled ? Nema ni oled ni usb c..
Očekujem uskoro rn4 sa s650 ili s652. To će biti ok kupovina.
Sent from my Kinez
Pitanje je samo koliko ce kineski trgovci povecati cifru u odnosu na tih 135$. Bez recimo 170-180$ nece biti prva dva do tri meseca.
Edit: fantacy vec prodaje za 153e...nisam mnogo omanuo :)
Ko ima rn3/rn3 pro,mislim da nema potrebe razmatrati ovaj rn4 (iako je po meni lepse odradjen nego rn3)....
Sent from my Kinez
KO nema ????
procitaj malo bolje ...
Note pro ima oboje za razliku od 4 !!!
ipak je pro dosta i skuplji od 4
PSSS
i glavna ralika citac otiska sa zadnje strane<> kod pro napred :)
Za najavu sam procitao pre 2-3 meseca..ne vidim neka poboljsanja na ovom telefonu u odnosu na rn3? Verujem da ce rn4 pro biti bolji ako izadje...inace na anututu negde procitah.95.000
Note 4
Pogledajte prilog 207922
PS
PSS
razlika je i u
4<>pro
IPS LCD capacitive touchscreen, 16M colors <>LTPS-AMOLED capacitive touchscreen, 16M colors
microUSB<> USB-C 1.0
4100 mAh <> 4050 mAh --- ako je bitno
Ja ovde procitao, izvinjavam se ako sam pogresno razumeo, a izgleda da jesem. Covek je poredio redmi 4 i mi pro ?
Covek je poredio redmi 4 i mi pro sto nema nikakve svrhe da se poredi i zato je doslo do zabune........
obicno poredimo u ovom slucaju rn3 i sadasnji rn4
Da da izvinjavam se na konfuziji, ja sam mislio da je poredjenje rn3 i rn4.
nema svrhe???
zasto nema svrhe ...
oba telefona izasla u roku od mesec dana, koriste isti CPU, ista dijagonala i sl. tj veoma slicnih karakteristika a razlika u ceni pozamasna. Čak ih stavljaju u dve razlicite klase tj kategorije. Zašto bi ga upoređivao sa RN3 kad je pro izasao posle RN3 pa tek onda RN4.
I da nije rec o telefoni MI pro nego o MI Redmi Note PRO što je ogromna razlika :-devil-:
PS
uporedno Note4 i NotePro
http://www.gsmarena.com/compare.php3?idPhone1=8291&idPhone3=0&sSearch2=&idPhone2=8233
Ispravka
nije Mi pro nego Mi Redmi PRO :)
Već ima da se odradi preorder na Aliju po ok ceni. 160$ i 200$ za 3/64
Original Xiaomi Redmi Note 4 MTK Helio X 20 Deca Core 2GB RAM 16GB ROM Mobile Phone 5.5" 1920x1080 13MP Metal Body Fingerprint
http://s.aliexpress.com/FRfMzEVr
(from AliExpress Android)
Ja lično čekam Redmi 4 pa da zamenim svoj rn3 :)
http://www.phonearena.com/news/Xiao...s-Redmi-Pro-size-and-specs-comparison_id84500
Now, when it comes to the Redmi Pro, it is obviously the upper midrange representative of the budget Redmi portfolio, as it comes with even thinner and more carefully crafted metal chassis, an elaborate dual camera, USB-C port, and the higher versions ship with Helio X25, 3/4 GB RAM and 64/128 GB storage. Naturally, this horese power superiority translates into a tad higher price, though we are talking about $200-$300 phones here, even when sold abroad, so who's counting.
https://www.youtube.com/watch?v=74nqwrunZc4
nesto si pobrkao 4 ne postoji u verziji 32GB
3GB RAM 64GB ???
bez uvrede ali još ga nema, planiran je ali nije napravljen
malo je čudno da taj telefon ima MIUI7 i bateriju od samo 3000mAh???
misli da ce to pretrpeti neke izmene inace tesko da ce se isplatiti pored redmi pro
Xiaomi Redmi Note 4 Pro will be released in October or November,
it has a micro usb.
Kad ce da dodje kod nas? Jos nije dosao ni Redmi Pro a izasao pre mesec dana.......
Ljudi sačekajte Redmi note 4 sa s652.. em će imati global rom em verovatno oficijelnu CM podršku
možemo mi da čekamo koliko hoćeš ali da li će uopšte izaći sa SD-om veliko je pitanje. I ovaj u najavi R N 4 pro ima X25 :wall:
misli da bi prvo redmi pro trebalo da dobije SD ipak tu pucaju i na više cene.
jedino što može da spasi stvar je indija :-devil-: ne konzumiraju MTK :banana:
Pa zbog Indije i pišem ,ja mislim da izlazi u roku od 30ak dana.
Ne isplati im se da gurnu u Redmi pro s652 jer je Indus tržište dosta siromašno i tu prolaze samo extra jeftini mobovi ,znači rn4 sa s652
ispravljeni podaci na xiaomidevice za Redmi Note 4 pro
sad je tu umesto
MTK X25
S652
i
umesto
MIUI7
MIUI8
http://www.xiaomidevice.com/xiaomi-redmi-note-4-pro.html
jos stoji baterija 3000 sto nikako nije logicno, ali nesto se pomera tako da mo\da i bude nekih promena :) ovim tempom do nove godine :-devil-:
PS
Hi!
when will be release Xiaomi Redmi Note 4 Pro? And what kind processor will be in this device snapdragon or Helio X25?
Xiaomi Device
Thank you for your mail.
May be snapdragon 652 processor.
If you have any question, please do not hesitate to contact us.
We will do our best to supply you better products and services!
Thanks, Best regards!
Sada ce neko doci i reci, sve je to lepo...ali nema LTE 800... :)
Dzabe i SD cpu i sve ostalo, ali nema LTE 800 :D Krsina...
Što jes jes nema LTE 800 i jeste kršina :-devil-:
Može netko objasniti što je Magic Mirror mode na prednjoj kameri? Ne kužim svrhu te opcije.
