Ono sto me raduje je i to sto su podrzani najnoviji HDMI i DP standardi, nesto sto Polaris po najavama nece imati.
Nesto mi ne sluti na 100% podrsku najnovijih standarda.DisplayPort 1.2 Certified, DisplayPort 1.3/1.4 Ready.
Officially the cards are being called “DisplayPort 1.2 Certified, DisplayPort 1.3/1.4 Ready,” the distinction being that the latter is not currently certified, though I suspect the DP 1.3/1.4 certification process may itself not be ready yet.
Koga briga za 1080 🙂 Odlična cena i performanse za 1070, svakako novi best buy
Ona moja nagadjanja se ispostavise prilicno tacnim ,)
Treba sacekati launch day, odnosno nezavisne testove (realna potrosnja, DX12 performanse i slicno). Ovo "brze od 980SLI" ce se verovatno odnositi na specificne slucajeve.
BTW, founders edition mi se prilicno dopada, da su mi bitne takve stvari kod komponenti verovatn bih razmisljao o jednoj 🙂
For pricing and availability, NVIDIA has announced that the card will be available on May 27th. There will be two versions of the card, the base/MSRP card at $599, and then a more expensive Founders Edition card at $699. At the base level this is a slight price increase over the GTX 980, which launched at $549. Information on the differences between these versions is limited, but based on NVIDIA’s press release it would appear that only the Founders Edition card will ship with NVIDIA’s full reference design, cooler and all. Meanwhile the base cards will feature custom designs from NVIDIA’s partners. NVIDIA’s press release was also very careful to only attach the May 27th launch date to the Founders Edition cards.
Consequently, at this point it’s unclear whether the $599 card will be available on the 27th. In previous generations all of the initial launch cards were full reference cards, and if that were the case here then all of the cards on launch day will be the $699 cards, but we are looking to get confirmation of this situation ASAP. Otherwise, I expect that the base cards will forgo the vapor chamber cooler and embrace the dual/triple fan open air coolers that most of NVIDIA’s partners use. Though with any luck these cards will use the reference PCB, at least for the early runs.
On a final observation, if the new NVIDIA reference design and cooler will only be available with the Founders Edition card, this means that customers who prefer the NVIDIA reference card will be seeing a greater de-facto price increase. In that case we’re looking at $699 versus $549 for a launch window reference GTX 980.
Koja tacno nagadjanja posto si menjao iskaze? 😉
With simultaneous multi-projection in VR, we can go from ~60FPS to ~90FPS, a roughly 30% jump in performance.
A pricalo se, nema GDDR5X i HBM2 pre Q1 2017 😉
Nije da branim cenu 1080, karta jeste skupa, tj. 50$ skuplja nego GTX 980 kad je izasao, ali ce i performanse biti 20%+ vece od GTX 980Ti dok je GTX 980 nudio ~8% jace performanse od GTX 780Ti, tako da je price/performance barem na nivou GTX 980 kad se pojavio ako ne i bolji. Ali dobro, za tacnu racunicu, moramo da sacekamo testove.
GTX 1070 ce biti dosta slabiji od GTX 1080 (6.5 naspram 9 TFLOPS i obicna GDDR5 memorija) ali ako da GTX 980Ti snagu za 379$ mislim da ce ponoviti uspeh GTX 970-ke.
A taktovi su bukvalno nestvarni 🙂
NV Link nema veze sa Geforce-ovima. To je tehnologija povecavanja bandwidth komunikacije izmedju GPU-ova i raste sa brojem GPU-ova i mora da bude podrzana na maticnoj ploci kao i na samom GPU-u. Mislim da ce se primenjivati iskljucivo na Tesla rigovima. Umesto NV Link na Geforce-ovima sad promovisu SLI HB Bridge.
Izgleda da ima 2048 cores ali ne znaju se klokovi. Medjutim ako se zna da ima 6.5 TFLOPS onda moze da se izracuna boost clock i trebao bi da bude oko 1580Mhz. Sto je dobra vest jer znaci da ce oveclock biti dobar.
Nisam gledao stream, ali dosta ljudi koji su gledali su rekli da se to odnosilo na VR a ne na "regularne" igre.I ja sam o tome razmisljao pogotovu sto je turbo folker rekao da su performanse GTX 1080 na nivou Titan X SLI.
E sada ne znam da li se nesto zeznuo ali dva puta je ponovio to isto.
I nije baš tako. Prvo, 1080 kreće od 600$, a 700$ će biti ova njihova fensi varijanta, koja ne dotiče mnogo većinu kupaca.Moze pricat sta god ko hoce GTX 1080 je precjenjen proizvod, istina ljudi ce kupovat GTX 1070, ali sigurno da je postojala i postoji i dalje ciljna skupina ljudi koji uzimaju full chipove a ne njihove derivate, i takvi trebaju bas da se isprse pa da uzmu zeljeni proizvod.
Manje vise sve je poznato i po mom nekom sudu GTX 1080 je trebala maximalno da preuzme cjenu GTX 980 jer u konacnici i jeste zamjena za GTX 980.
Proizvodni proces im je omogucio ogroman napredak, ali u konacnici GP 104 je manji cip od GM 204 ne vidim osnova za dizanje cjene na 700$. Lopovluk, "Šišaj dok ima ovaca"- stara navika.
http://www.overclock.net/t/1599440/geforce-nvidia-gtx-1080-unveiled/820#post_25137276
Ako bude ova cena za 1080,ja sam lično prezadovoljan i jedna će biti moja.
Što se tiče cene, ako su sve informacije tačne, ona je na nivou na kom i treba da bude. Tu je GDDR5X, a i ona sama je brža u odnosu na 980ti, nego što je 980 bila u odnosu na 780 ti, samim time nudi više nego što je nudila 980 na izlasku. A i sama 980 ti je bila dobra karta za cenu za koju je išla,a ova karta bi komotno mogla i u njen cenovni rang.
Naravno sve pod uslovom da su informacije o ceni i perf tačne.
Moracemo za 1070gtx ili 1080gtx menjati cpu izgleda ....
Drugo x70 klasa je odavno u rasponu 350-400$, tako da tu nema ništa novo. 570 je bila 350$, zatim 670 i 770 su 400$, da bi 970 spustili na 330$. Tako da je ova cena za 1070 sasvim na mestu.
Kod x80 je malo drugačija priča, pošto su 580 i 680 bili 500$, ali je zato 780 bila 650$ na izlasku, da bi 980 spustili na 550$. Može se reći da je 1080 neopravdano veća, ali to je trenutno flasghip, brža i bolja karta od aktuelnih (Fury X i 980 Ti), tako da je i to manje više ok. Ko želi da plati 50% veću cenu za 20% veće performanse, njegov izbor.
Što se procesa tiče, istina je da da manju površinu zauzima 7,2 milijarde tranzistora u 16nm, nego 5,2 u 28nm (mada ne znamo tačno koliko), ali su 16nm FinFET vaferi skoro duplo skuplji od ustaljenih 28nm. Tako da je moguće da ih ovaj čip košta i više nego GM204
Ja čekam da vidim kako će se pokazati i7-6800/6850, tu su iza ćoška. Sandy teram evo već 5 godina, sem "redovnog" menjanja grafika, dodavanja memorije i ssd-ova ništa nije čačkano, služilo je odlično, ali je vreme da se osveži osnova za narednih toliko.Moracemo za 1070gtx ili 1080gtx menjati cpu izgleda ....
Cena pre svega zavisi od AMD, a posto isti ne ciljaju na isti segment ona je danas realna iako je naduvana za 1080
e sad ostaje jedino pitanje da li ce polaris 10 uspeti da se priblizi 1070 i koliko
po svemu sudeci 1070 je dobro osakacen sto memorijom sto disablovanim jedinicama
Sta mu dodje ovaj founder edition?
Sent from my ASUS_Z00UD using Tapatalk
