Sony Xperia X Performance, X, XA
nikola1970
Sony Xperia X Performance Key Features:
- 3G Network: HSDPA 850 / 900 / 1900 / 2100
- 4G Network: LTE 700 / 900 / 1800 / 2100 / 2600
- Dual SIM (Nano-SIM, Dual Stand-By, Dual Call)
- Connectivity: Wi-Fi 802.11 a/b/g/n, DLNA, Wi - Fi HotSpot, Wi - Fi Direct, Bluetooth v4.2 With A2DP, MicroUSB v2.0 And NFC
- GPS With A-GPS Support And GLONASS
- Dimensions: 144.8 x 71.1 x 7.6 mm
- Weight: 164.4 Grams.
- Display 5" TFT LCD FULLHD TRILUMINOS Curved (~441 Ppi Pixel Density) With X-Reality Mobile
- 32 GigaBytes Memory Internal
- Expansive Memory Up To 200 Gigabytes
- 3 GigaBytes Ram LPDDR4
- CPU Qualcomm MSM8996 Snapdragon 820 Kyro Dual Core 2.15 GHz And Dual Core 1.59 GHz (SemiConductor Technology 14 nm FinFET LPP)
- GPU Adreno 530 (Quad - Core Graphics @624 MHz)
- Android 6.0.1 (Marshmallow) With Sony UI
- Office Document Viewer (Word, Excel, PowerPoint And Reader PDF)
- Camera 23 MP With SteadyShot And Pulse Led Flash
- CamCorder UltraHD (2160p @30 FPS)
- 13 MP Front Facing Camera Wide Angle Lens With SteadyShot And CamCorder FullHD (1080p @30 FPS)
Sony Xperia X
- Qualcomm MSM8956 Snapdragon 650
- GPU Adreno 510
- OS Android OS, v6.0.1 (Marshmallow)
- 32/64 GB, 3 GB RAM
- 5.0 inches (~69.6% screen-to-body ratio)
- 23 MP, f/2.0, 24mm, phase detection autofocus, LED flash
Sony Xperia XA
- 5.0 inches (~71.8% screen-to-body ratio)
- 720 x 1280 pixels (~294 ppi pixel density)
- Mediatek MT6755 Helio P10
- 16 GB, 2 GB RAM
- 13 MP, phase detection autofocus, LED flash
http://www.gsmarena.com/sony_mwc_2016-review-1386.php
Jesu li oni to izbacili vodootpornost? Nigde niko ne pominje da je ima.
Pa od kada je sony prestao da uvazava garanciju na vlaznost to ti je kao i da nema iako ustvari ima ;)
Mislim da je kod ovih naglaseno da nemaju vodootpornost..
Ovaj obican X sa s650 uopste nije los.
Izgleda da samo taj ''Performance'' ima IP68.
Ovako sa papira nisu losi telefoni ali mislim da ce biti skupi. I stvarno su trebali bar malo da osveze dizajn, ovako previse lice na dosadasnje sony telefone (posebno Z3/Z5 i M4/5) sto samo po sebi nije lose ali pocinje da smara.
[YOUTUBE]hU2uhnESTHY[/YOUTUBE]
[YOUTUBE]8_3oK7K8BaI[/YOUTUBE]
Ima jos klipova na btektu, lik kaze da su materijali i izrada u skladu sa flagship klasom a zvanicno su ovi ''X'' neka mid klasa (od low -XA do high mid X-Performance).
Sad sam izvalio da imaju neko zakrivljeno staklo preko displeja.. ne svidja mi se to.
Evo ih i cene, preskupi su: Xperia X family priced in Europe; pre-orders now live
Nesto vise vezano za punjenje i baterije - http://www.marketwired.com/press-release/qnovos-innovative-adaptive-battery-charging-included-sony-mobiles-newest-xperia-smartphones-2098615.htm
http://www.sonyrumors.net/2016/02/22/sony-xperia-x-family-includes-breakthrough-qnovo-battery-tech/
Sony’s Predictive Hybrid Autofocus in action
[YOUTUBE]fGHcFKACZtc[/YOUTUBE]
Mada slicnu opciju imaju cak i stari Z telefoni ali ovde je senzor noviji i sa boljim AF-om.
[YOUTUBE]HRwBDRtRfQ8[/YOUTUBE]
Sve svemu ok telefoni ali previsoke cene po mom misljenju.
Naravno da ce biti visoke cene jer je to Sony. Sad, da li to kvalitet opravdava, ne znamo. Meni se licno svidja kako izgleda XA sa skoro nepostojecim bocnim ivicama, a i malo zakrivljene ekrana, zaista lepo. Ovaj X je super, samo da ima veci ekran. Performance je isti, mislim jaci, ali isti djavo. Jedino sto mrzim kod Sonyja su ove ogromne ivice gore i dole, ne znam zasto to ne smanjuju. Generalno, lepo iznenadjenje, nadam se da ce neko od operatera kod nas imati u ponudi pa da vidimo kako ce stajati sa cenama.
Ne razumem tu logiku da najlepši telefon bude najgori.
Bas, mozda idu u tom pravcu da prosecan korisnik ne gleda toliko detaljno specifikacije nego vise izgled, pa jos ako je niza cena onda ce uzeti. Ne znam u kom rangu je P10 sa Snapdragon, ostali aspekti i nisu toliko losi, osim rezolucije, ne znam zasto svi boluju od toga da midrange mora da ima 720p.
Sad tek vidim temu... X performance je biser sajma. Samo da je jeftinije.
Sony.. Kod njih ni toster ne moze da ima konkurentnu cenu
Bas me zanima da li ''Performance'' ima pravi S820 ili osakacenu verziju. Ako je ''full'' onda ce u kombinaciji sa fhd ekranom i MM softverom pokidati a i baterija od 2700 mAh ce biti dovoljna za autonomiju u stilu Z2/Z3.
http://www.sonymobile.com/global-en/products/phones/xperia-x-performance/specifications/
Ovde pise samo S820. Onda sam pogledao specifikacije koje su pisali na Esatu:
X-Performance -
A sad kopiram iz specs. za S7 (snapdragon) sa istog sajta -
Znaci za oba pise dual core (2.15Ghz) and dual core (1.59Ghz), iz svega toga deluje da imaju potpuno isti S820 soc, moguce da je gsm arena pogresno prenela vest jer su oni jedini pomenuli da ima navodno osakacenu verziju a sta je istina videce se uskoro :)
Pa ja ne znam o kom vi to osakacenom s820 pisete.. Prvi put to cujem ovde od vas. :)
Pa bugari su to napisali, da ima dual core verziju S820. I meni je bilo cudno al' reko oni znaju bolje, bili su na MWC :)
Za te pare biće da je sve kako treba [emoji1]
Ma ne postoji "osakacena" verzija SD820, sve je to punokrvni SD820, mora da je neka greska bila jer nigde ni ja nisam video ta tako nesto postoji. :)
I ja mislim da je to 820 sto bi bzvz bunili narod, a cene NC čak su i "zastareli" z2 i z3 papreni za naše uslove...
Cisto da se vidi kako izgleda i radi sony 6.0.1 UI..
[YOUTUBE]BeI_m4kC_-o[/YOUTUBE]
[YOUTUBE]8Id4l062W7I[/YOUTUBE]
Inace ovaj X Performance me malo podseca na htc A9 s tim sto ovaj sony ima dosta brzi cipset, IP68, stereo zvucnike, vecu bateriju i verovatno bolju kameru (mada nema OIS).
Hoću ga na svom telefonu, skoro mesec dana čekam da uđem u beta program. Za 10 Mobile mi je trebalo pola minuta.
Ne mogu sad da trazim, danas sam negde video da kazu za Performance Asia only, i jos negde da ga nece biti u UK i Nemackoj... Valjda ce ga biti na ostalom evropskom trzistu? :trust:
Sad jos i ovo:"All three phones are not scheduled to launch until Summer 2016. Yep, you read that right - these phones aren't coming out for at least four months."
Bice super sad kad ne puste marshmalow za z5 seriju i ostale dok se ne pojave ovi x telefoni da im ne bi urusili prodaju :D
I ne znam za vas ali mene pocinje strasno da nervira ova strategija proizvodjaca sa ne pustanjem telefona u sve regione (samsung krenuo sa note 5 i sad ce sve gore i gore izgleda da bude)!!
